Question about Toys
Touch screen on cricut expression not working
I can turn my expressions 2 machine on. All the lights come on, the magnifying, home, pause and the on button lights. The touch screen lights up but doesn't move after that. I can touch anywhere on the screen and the touch screen does not leave the Cricut Expression 2 screen. The reset instructions are for the Cricut with the manual dials on and the red button, the instructions do not address the Expression 2 which does not have dials and looks like the reset button may be the white button on the inside right of the machine.
I have a Cricut expression 2. It turns on but I'm unable to get the home screen to come on. The screen just freezes on Cricut expression 2
  • Turn on the machine, with no cartridge installed. Roll the Speed, Size and Pressure dials all the way down to the lowest possible setting on each.
  • Grab the blade assembly with two fingers and pull the carriage gently all the way to the left. Behind where the carriage usually sits is a red button. Press and hold the button for three to five seconds and release.
  • Go back to the three dials marked Speed, Size and Pressure, and roll each one all the way up and down three or four times.
  • Press the Cut button, then turn off the machine. Let the machine sit for 15 to 20 minutes to clear the memory.
  • Load a cartridge, turn the machine back on and try it out. If you are still experiencing problems, you may have a defective machine. Return it to the manufacturer with the original receipt.
Jan 15, 2017 | Crafts & Hobbies
When using a design in Cricut Craft Room, and select cut, my Expression 2 begins, but does not complete, the cut. The arm moves to the paper and then makes a croaking sound and then nothing.
Search cricut.com for support faq go to expression 2 search format and reset. Watch the video on format and reset and do as it says. Calibrate when it's finished. If this doesn't work re download ccr after deleting it from your computer.
Jan 10, 2016 | Provo Craft Cricut Expression 2 Electronic...
Cricut expressions 2 pressure wheel
You say you have a Cricut expression 2 but you say quote"...of how to reset the machine including the rolling of the dials up and down three times!" The problem I have in sorting your problem is that the Cricut expression 2 does not have wheels which work the speed, pressure and size. If you have an expression version 1 machine then there would be 3 wheels on it to adjust the speed pressure and size. Obviously if you have had the machine for 4 years it is out of warranty and I am not sure just what the person did to "fix" your problem. I do recollect a video on you tube with a similar problem however looking at the video he mentions that once it is fixed the blade housing should bounce up if you push it down, does your housing now do the same as the video. In the video Evan did he mentions at the end that the soldering of these wires may not take the first time so this may be a point to check as he mentions that it was travelling the machine that caused the wires to break in the first place. The youtube.com video I am speaking of is http://youtu.be/n7LJnfPdd08, by Evan Craftman. I am assuming that when you called cricut support you called the UK support line. I often speak with support in the USA being from New Zealand it is an overseas call however I have found them very good. If you are able to I would like to see a video of just what your machine is doing. If you dont want to post it here you could email me flohillrennie@gmail.com.
I do feel very sad that you don't wish to try the Explore as I find it a surpurb machine. I have had my Expression version 1 since early 2009, I have added every Cricut to my family of cricuts and own 3 expression 2's and now an explore. If you had bought a computer 4 years ago and you currently took it to a repair person to get it fixed I am sure their first response would be it would be better to get a new one. Your computer boards appear to be fine maybe you need to take the video to the person who did your fixing as most people who do this sort of work would not understand how the machine runs. I hope this helps and you can get your Cricut working again. If all else fails you may be able to buy a 2nd hand one cheep and have your repair person change the carriages completly.
Jun 13, 2014 | Cricut Expression Cutting Machine
My Cricut Expression is not working. When i pressed the cut point on the screen all it did was a loading screen and would not cut. What should i do?
fruchey10 you have not given me enough info to help you but if you contact me I will try to work out a solution to your problem. exactly what are you doing ie do you have images loaded onto the image queue. contact me via my website OhSoManyCrafts
Feb 02, 2014 | Cricut Expression Cutting Machine
My cricut wont turn on
Hi, My cricut expression is more then 5 years old. I used it one day and the next day I would not come on (it dose Nothing at all). I brought a new power cord from cricut and still nothing. I'm unable to buy a new one Please help if you can. Thanks!!
Jan 26, 2014 | Cricut Expression Cutting Machine
Cricut expression 2
Cricket is hung up on the first small cut and keeps repeating that same cut over and over
Aug 09, 2012 | Toys
Cricut expression 2 has no power, will not turn on
Any resolution to this issue? I like stone234 have narrowed it down to the cricut not getting power past the power board. I tested the two prongs that feed the red and black power for the main board and no voltage. Cricut Exp 2. Powered on as soon as I plugged it in. Plugged in usb to computer, I didnt have the software so i searched for it then started downloading it and noticed the screen on the unit was frozen. unplugged it and after plugging it back in it wouldn't power back on.
Nov 05, 2011 | Cricut Expression Cutting Machine
Brand new cricut doesn't turn on, just clicks with lights blinkin
Yes, I was just going to recommend contacting them. I see you have contacted them already. Good luck with getting it fixed~they are prompt in helping with machines. If you have any further questions about the cricut feel free to ask.
Aug 20, 2009 | Provo Craft Cricut Disney Font Cartridge
I have a cricut expression die cut machine, the green power light is on but the LCD and other control buttons are not working can you help
there is a relay on the under side of the keyboard that goes out. ther is a release on the left side of the keyboard on the cricket expression that lets you remove the keyboard for a tall cutter or something. Turn the keyboard over and take the back off.there is a square area that protrudes from the back of the key board. that's where the relay is. it can be replaced. or bypassed.
Aug 28, 2008 | Computers & Internet
Toys Logo
1,081 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
