Question about Sanyo Televison & Video
My sanyo tv odel ce37ld33-B turns itself off and blue light flashes when i turn it back on
Turns itself off and if i turn it on strat away the blue light flashes after abit its turn on ok then dose it all again
  • 1,238 Answers
You have bulged capacitors on the power supply board that need to be replace in order to fix the problem
Posted on Nov 04, 2012
SOURCE: TV turns off
Fixed it !!! Used the approach by Guest; replaced both of the capacitors with 0.1 microfared caps from Ratshack. It's been working for two days. Thanks Guest.
Posted on Dec 17, 2007
SOURCE: model 60p8241 magnavox big screen tv
your screen My have two power supplys in it you might waht to check there. We have a Sync Master and kind of the same thing was happing - there is a Sub power supply and a main power supply. check you model and see if this could be the reason
Posted on Sep 23, 2008
SOURCE: Tv cuts off and green light flashes
If your set was manufactured around July 2005, you may need a firmware upgrade to solve this issue. On the Sony website you can enter your model # and serial # to see if you TV is affected. If so, it is easy to have done and may be free from Sony. It sounds like the issue they described in the writeup on the required formware update. I had mine done within few months of when i bought it (purchased in Dec 2005) and it has been working flawlessly since.
Donnieboy999
Posted on Oct 21, 2008
  • 718 Answers
SOURCE: TV was playing, then the screen turned black.
If the screen is black and you have sound then lightly press and shine a strong flashlight against the screen. If you see an image around the edge of the flashlight, an image is being 'displayed'. The problem is probably in the Inverter/CCFT or the power going to the Inverter.
Posted on Feb 24, 2009
ginko
  • 19396 Answers
SOURCE: HITATCHI ULTRAVISION P50S601...POWER LIGHT BLINKING...WONT COME O
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Posted on May 22, 2009
Sanyo 37 LCD ce37ld33-b
Sounds like display panel fault. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Aug 21, 2015 | Sanyo Televison & Video
Sanyo ce32ld81-b has no picture or sound just flashes green, blue and red. It was working when I went to bed woke up and went to turn it on nd it wasn't working.
Tries tv unplug,replug it back in like about an hour later for the tv to do a resetting itself back to the factory setting.The tv now should be working again.If the tv still have the same result.Mean ur tv the tv power supply board it is the problems and the causes.That the board where the tv power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish tv power supply board for the replacement.
Sep 04, 2011 | Sanyo Televison & Video
My television turned itself off and will not turn back on again, the blue light is constantly flashing.
Hi
How many times does the light flash... i.e. flash flash flash flash flash...pause, then repeats?
If you include the make and model of the TV in your reply this would be helpful.
Regards,
HillElectronix
Aug 04, 2011 | Televison & Video
Hi gud noon.just want some advice i have a problem with our tv sanyo flat screen if we try to turn it on it only appears blue screen theres no picture....thats our problem... we try to call already the...
  1. Try changing the input on the TV to see if the Blue screen goes away. Can you access the TV menu on the screen? If so, try running a channel scan until it is complete. Then check if the blue screen is still there.
  2. Disconnect any RCA cables, or other input cables from the back and see if you still have a blue screen.
Here is the link to Sanyo's Support site: http://us.sanyo.com/Customer-Support
E-mail: support@sanyotv.com
Phone: (800) 877-5032
Fax: (870) 630-4223
Feb 25, 2011 | Sanyo DP32648 32 in. LCD TV
My sanyo tv stand by light keeps flashing and it wont turn on can you tell me whats up with it
i have 32inch sanyo tv i have blue light on front whitch comes on when on stand by it wount come of standby eney idears on how mutch it will cost to get fixed x
Nov 13, 2010 | Sanyo PDP-42H2W 42 in. HD-Ready Plasma...
Blue light flashes on front of tv cannot get set to turn on
my sanyo 37 inch was workin fine put it on the wall now the blue light on the front is flashin like mad screen wont *** on got the clicky sound as if i was turnin it over by the side any ideas ??
Aug 21, 2010 | Sanyo 42 in. LCD TV
Why is my sanyo tv flashing green, blue, and red ?
i turned it on nd it was still like that nd i gt more mad. i was gna throw the remote bt i presed the menu button randomly once or twice i dunno bt it came back(normal tv)
hope that helps
Apr 11, 2010 | Sanyo DS31520 31" TV
No pic or sound
First unplug set and let set for several minutes the plug in and turn on. Could be in a serv mode.
Jul 13, 2009 | Hitachi 51F59 51" HDTV Projection...
Televison & Video Logo
335 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
