Turn off radio n car, then turn on key, hold sown numbers 1 and 6 with power button at same time, it will show u a letter with 4 numbers and then it will show u a second letter with four numbers. Go to web site https://radio-navicode.honda.com/ put in ur car vin # and ur 8 numbers without the letters, n it will give u the code to put in , or try 33346 or 9774b ??
I hate to say this but you need to prove to a honda car dealer that you own the car, then remove the radio. their is a code # on the tag on the radio that the honda dealer can use to figure out your unlock code....
Good Evening, I am sorry to hear you're having problems with your radio. Unfortunately the only real way to get the radio code is pull out the radio and get the serial number off of it then call your local honda dealer and they will be more than happy to give you the code once you explain your situation. Any more questions please feel free to ask.
if you dont have your radio code then we need to get your serial number,
there 3 ways to get it. * First try looking in your glove box for a
sticker which will be a 7 or 8 digit number (your serial number) if its
not there, then try this - With the radio off hold in buttons ' 1 ' and '
6 ', while holding those in turn on the power button, that should give
you your serial number, * If that still dosnt work then you will have to
pull the radio out of the dash and get the serial number off of the back
of the radio. * Once you have your serial number contact your local honda
dealer and tell them your situation and they will be able to give you
the code to unlock your radio.
Also, you will have to contact your Honda Dealer. The original selling dealer
may have the code on file. If not you will have to remove the radio and
get the serial number of the chassis. With this serial number, any Honda dealer
can provide the correct code. There is no other way to unlock the radio
than with that code.
If the code is not written on the radio casing or inside the glove compartment, in/under the ashtray, behind the sun visor (or similar “hidden” place inside your car ) then the majority of HONDA codes may be available here
You will require the car VIN number and Radio serial Number
If they cannot provide your code then you will have to try your HONDA Main Dealer .....or a Decode Service who will plug in a laptop to read/recode the memory chip (EEPROM) =
FREE and EASY methods to get your Honda radio UNLOCK CODE. (Dealerships usually charge)
Assuming you don't have the Anti-Theft Code and Serial Number that is found on the credit card sized Anti-Theft Radio Identification Card that comes with the vehicle at the time of purchase and is usually found in the glove compartment....
You have FREE options to retrieve that code by phone or on the internet BUT, the RADIO SERIAL NUMBER is REQUIRED (no matter what). (see bottom about removing ERROR E3)
***IF your Honda was made BEFORE 2001 the serial number MAY not be accessible without removing the radio from the vehicle.***
* TO GET THE SERIAL NUMBER (so that you can get the unlock code)
1. Get something to write with and on (you'll need it to write down the serial number) 2. Put the ignition key in and turn it until your able to turn your radio on (accessories position). 3. Then turn your radio OFF by it's knob/button (but leave the ignition key in place). 4. Hold down the preset buttons 1 and 6 at the same time. 5. Turn the radio on while pressing down both the 1 and 6buttons.(***IF your Honda doesn't have preset buttons on the radio then hold down the top part of the 'Seek/Skip' button AND the top part of the 'Change Disk' button instead.*** ) 6. Write down the 4 numbers you see first and then 4 more that display. These eight numbers are the SERIAL NUMBER. This is NOT your CODE. 7. Make sure your VIN (Vehicle Identification Number) is handy to get the unlock code. (can be found on your insurance card, driver's side door jam, small plate on dashboard by registration and inspection stickers, etc)
* TO GET THE UNLOCK CODE (using the radio Serial Number and VIN)
---Internet option:
1. Go to https://radio-navicode.honda.com/ (YES, it's run BY HONDA and IT'S FREE) 2. Follow on screen instructions (Serial Number and VIN required) 3. Type in the 5 digit code into your radio. This will unlock the radio and return it to a functional state.
-OR-
---Telephone option:
1. Call American Honda Customer Relations (800) 999-1009 2. When the automated message starts 'Press 3' for 'Radio and Navigation Codes'. 3. Tell the Customer ServiceAgent you need your radio code. (They will ask for your name, your radio's serial number, VIN, etc) 4. When they give you your radio unlock code--WRITE IT DOWN and KEEP IT SAFE! 5. Type in the 5 digit code into your radio. This will unlock the radio and return it to a functional state.
* REMOVING ERROR E3
****If you entered too many wrong codesand got an ERROR E3 message displaying you'll need to do an additional step for even the correct unlock code to work.****
Disconnect your negative battery terminal (or pull the radio fuse out if that's easier for you) for 30 seconds then reconnect it and then the radio will say "CODE" again and you can put in your correct unlock code.
*** Please click the "Was this helpful" Yes thumbs up! ***
1. Get something to write with and on (you'll need it to write down the serial number) 2. Put the ingnition key in and turn it until your able to turn your radio on (accessories position). 3. Then turn your radio OFF by it's knob/button (but leave the ingition key in place). 4. Hold down the preset buttons 1 and 6 at the same time. 5. Turn the radio on while pressing down both the 1 and 6 buttons.(***IF your Honda doesn't have preset buttons on the radio then hold down the top part of the 'Seek/Skip' button AND the top part of the 'Change Disk' button instead.*** ) 6. Write down the 4 numbers you see first and then 4 more that display. These eight numbers are the SERIAL NUMBER. This is NOT your CODE. 7. Make sure your VIN (Vehicle Identification Number) is handy to get the unlock code. (can be found on your insurance card, driver's side door jam, small plate on dashboard by registration and inspection stickers, etc)
---Internet option:
-OR-
1. Call American Honda Customer Relations (800) 999-1009 2. When the automated message starts 'Press 3' for 'Radio and Navigation Codes'. 3. Tell the Customer Service Agent you need your radio code. (They will ask for your name, your radio's serial number, VIN, etc) 4. When they give you your radio unlock code--WRITE IT DOWN and KEEP IT SAFE! 5. Type in the 5 digit code into your radio. This will unlock the radio and return it to a functional state.
* REMOVING ERROR E3
****If you entered too many wrong codes and got an ERROR E3 message displaying you'll need to do an additional step for even the correct unlock code to work.****
----------------------------------------------------------------------------------- So what happened to begin with? See also: http://automobiles.honda.com/information/frequently-asked-questions.aspx?Question=2
If the power from your battery to the Honda radio is interrupted the Anti-Theft feature kicks in, the radio is rendered inoperable and the screen reads 'CODE'. You must enter in the Anti-Theft Radio Unlock Code (usually 5 digits) to make it operational again. You know that much by now.
What you have is the SERIAL NUMBER. Your almost there!!! The hard part is over! Go to the bottom below for the website option or phone number option you need to get the unlock code!!!
*** Please click the "Was this helpful? Yes" (thumbs up)! ***
CODE.
stickers, etc)
---Internet option:
-OR-
* REMOVING ERROR E3
now.
if you do not have original anti-theft radio code you will need to remove radio and retrieve s/n off of radio. once you have that you can go into nearest honda dealer and with s/n they can give you correct radio code
Find the 5 digit radio code or remove the radio to get the serial number. A Honda dealership can get you the code if you have the serial number.Or they can get both.
I need help fixing my radio on a 2006 Honda Accord...I could not find the code and after so many attempts my radio is saying ErrE and now i have found the code and now i can't start over with codes again....what can i do?
