Question about Craftsman 675 Series 190cc 22" Briggs Stratton Rear Bag Front Propelled Lawn Mower ()
Lawn mower starts ok but sputters and dies after a few minutes. it never actually runs at full strength.
    Welcome Back:
    Visited the website for 2 consecutive days.
Water in
Posted on Oct 12, 2013
  • 6 Answers
SOURCE: Lawn mower will not start and run
Sounds like a clogged carb or a cracked primer bulb. I would install a carb rebuild kit and new primer bulb if your mower uses one.
Posted on May 31, 2009
  • 376 Answers
SOURCE: My lawn mower tries to start but then dies shortly thereafter.
Probably. Does it start after you push the primer and then die? If so, yes, it's the carb. For any more info, I'd have to have the model and type #'s off the engine. Dwain
Posted on May 17, 2009
  • 93 Answers
SOURCE: I have a 2003 craftsman 6hp lawn mower. It would
Fuel Problem, Pull off the Carb bowl you will see the problem (Green Gunk and Varnish. When you drop the Carb Bowl you will see a hole in the carb assy. below the float, use a paperclip or other small object to clean it out........its probably plugged.
Posted on Sep 15, 2009
SOURCE: I have a Craftsman 650 series lawn mower. It
I have a similar issue in that my Craftsman 650 in that it sputters and smokes out of the muffler and spits oil out from there as well. It does not die, but I cannot operate the lawn mower with all the smoke and oil blowing out. Plus, I get oil leakage on the deck of the lawn mower (top). What would I check for here?
Posted on Mar 28, 2010
SOURCE: 10 year-old lawn mower Craftman Eagle 1, 6.5 horse
sounds like the main jet is blocked. remove it and run a piece of fine wire through it and retest.
Posted on Nov 28, 2010
Was mowing the lawn about 20 minutes then mower stopped. It is a craftsman platinum 7.25
sounds like the spark plug may be fouled or the fuel filter or carburetor is dirty.
Sep 17, 2016 | Craftsman Garden
Have a Briggs and Stratten 4.0hp Lawnmower that starts but sputters. What can I do to get it running smooth...What is the Spark Plug GAP?
How old is the fuel? Drain old fuel, use premium fuel and change spark plug and maybe air filter. I start mine in the Spring using quickstart. It also starts and dies a few times and eventually keep running. Winterizing the machine in the Fall prevents most starting problems in the Spring. If this does not solve the problem, see a mechanic.
Jun 24, 2014 | Briggs & Stratton Briggs Stratton...
The engine sputter and dies after running for about 2 minutes.
I had this puzzler too! Turned out the problem is caused by the fuel-bowl needle valve. It may look OK but looks are deceiving. It gets a coating on the tip that causes a poor seal ... poor enough to allow fuel to flood the engine after a short run time. The flooded engine dies, but restarts OK after a delay that clears (cooks off) the excess fuel that flooded/killed the engine. SOLUTION: Remove the needle valve and carefully wipe and clean the tip with a white cloth soaked in solvent (gas is OK). The cloth will show the deposits that cause the problem. Carefully re-install the needle valve and float parts, start the engine, confirm that it runs OK and continuously. Simple fix .... puzzling problem.
Aug 13, 2012 | Craftsman Garden
My mower starts when cold and runs for a while OK
it sounds like the ignition coil is shorting out inside once it gets hot. or it could be the spark plug as well.
May 01, 2010 | Toro Lawn Mower With Toro Power Tools
Husqvarna 2009 Tractor Run 30 minutes, sputter, loses power, dies
hi it seems to me either a lack of compression when she is warm /hot /check tappets or a weak mixture /air leak on the inlet someware hope this is of some help merlinv12
Aug 20, 2009 | Parks Optical 13.5hp Briggs And Stratton...
Mower dies after running for a few minutes
It sounds like the carburetor is running out of fuel.First make sure the tank is full then loosen or remove the gas cap when it starts sputtering to see if that corrects the problem. Then with engine off remove the fuel line that goes from the tank to the fuel pump,hold it low and see if any fuel flows out of it,if not lightly blow air backwards to the tank,(with fuel cap off),then see if the line is plugged. Next remove the fuel line that goes to carburetor from the fuel pump,crank the engine and see if any fuel flows,if so the carburetor should be cleaned by removing it and disassembling it.
Aug 09, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Have to choke MTD to keep it running
check fuel pump diaphram is not streched or hard, check fuel filter for blockage, or fuel tank cap might be not venting, if none work drain and clean out carby bowl.
Jul 19, 2009 | Mtd LAWN MOWER PART # 787-01341...
Lawn mower dies
Find the fuel air mixture screw and while the mower is running turn so mower almost stops then turn them back till the moter is running smoother.Give it some throtle to see & hear how it is running
Nov 02, 2008 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 675 Series 190cc 22" Briggs  Stratton Rear Bag Front Propelled Lawn Mower () Logo
255 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
