Techwood tv with built in dvd player
Require regional codes please
  • 13 Answers
SOURCE: No sound from built-in DVD player on TV?
It sounds like the audio cable from the DVD drive may be loose or damaged. Did you wall mount the TV and this is when the problem started or has it always been like this? If its under warranty, contact the helpline on 0871 2000 463, be warned, if its becuase the cable is damaged by a wall mounting screw, its clearly evident and they will charge for repair.
Posted on Jun 10, 2009
  • 4090 Answers
SOURCE: Region code error for my LG RC388 DVD/VCR player & recorder
1) Power on player with no disc in tray
2) Press PAUSE
3) Key in 314159
5) For multi-region, select 0
6) Press PAUSE again
7) Power off player
8) Wait a minute turn it on.
Please rate our Free help to keep the service online ++++
Posted on Aug 30, 2009
SOURCE: Have moved from the UK to New Zealaand and need to
Typically it is rare to find a region hack for a TV with built in DVD player. I have searched my sources including private websites to look for a solution. There was only one that was "Close" to the model number you have. Your best bet would be to try this procedure, basically this is your only hope unless you contact someone at Bush and get them to let you in on there secrets.
  • Turn On the player and Eject the disc tray
  • On the remote press 2, 8, 1, 2 followed by Enter
  • This gets you to the engineers menu
  • Press Down until you reach COUNTRY CODE and press Enter
  • The current region code will change to four dashes (----)
  • Input one number (0=Region Free, 1=USA 2=Europe, etc) and press Enter again
  • The new region code will now be displayed. You can exit by just pressing the Eject button once more
Thank you for trying Fixya, please come again.
-Daniel
Posted on Oct 18, 2010
SOURCE: I have Technika TV (model Number 15.4-311) with
  • Remove any DVD in the player.
  • At the blue screen type 9735.
  • A menu should pop up. select region and then select the top option which should be region 0 (0= multi-region).
  • Next select exit setup then power off the tv. It should now play all regions.
I just did this myself so i know it works.
Posted on Jan 13, 2011
muntejaya
  • 10421 Answers
SOURCE: Looking for region free code for TV/DVD combi
Hello, please get the code here : www.regionfreedvd.net/ www.dvdripper.org/dvd-region-codes-vs-ntscpal/ www.regionfreedvd.net/players.html
www.dvdreviewer.co.uk/Forums/...region_code/page1
Best Regards, Jay_34d
Posted on Feb 27, 2011
Is there a region code magnavox dv220mw9a
Yes there is a region code built into the dv220mw9a depending on the region where the unit was sold. The version sold in the US will only read region 1 or All region DVDs.
Where was your DVD player purchased and what region code is on the DVDs? Please add a comment with more information on your problem.
Jan 21, 2013 | Magnavox DV225MG9 DVD Player VCR
Region codes
dvd players are suitable for all regions but the pins may vary region to region
May 13, 2008 | Sharp DV-NC200
Require to unlock Region Codes for an RCA Portable DVD player code DRC6318E. Can you help please
I'm sorry for the difficulties you're experiencing in playing other region disc in the RCA Portable DVD player. Please follow the below steps to unlock the region code and check the operation:
  1. Turn on the player without any disc inside
  2. Enter the code "321 789 456" before the player menu appears
  3. Select 'all' in the appearing list for region free
  4. Turn the player off
Thanks for understanding. Please let me know the result after performing the steps. Also let me know if you require further assistance.
Sep 11, 2011 | RCA DRC6318E Player
Cant play a region 1 dvd
The DVD and *and* the DVD player both have a region code embedded in each. A map of the regions used appears below:
Regions 0, 7, 8 & 9 do not appear as they represent "No Region Coding" "Unused" "Cruise Lines" and "Region Free" respectively.
A DVD player will only play a matching region code DVD, or the player OR DVD have one (or more) 0, 7, 8, or 9 region codes imbedded. You'll not be able to change the DVD code, but you *might* be able to change the region code of your player. Computer DVD players can sometimes be flashed to a new region more readily than the entertainment system DVD players, but it relies solely on the manufacturer and model of the player. Some require file be downloaded and run, while others require a DVD or CD be created and played with a specific file saved on it. Here's a link to results that discuss how to change the region code for DVD players. You'll need to know at the very least the manufacturer and model number of you player to begin.
I hope this helps and good luck! If you found this helpful, please rate my reply 4 "thumbs up". Thanks!
Jul 12, 2011 | Audio Players & Recorders
Hi I have a samsung DVD player model number p181 & when I insert DVD message comes up wrong regioncan you please help, thanks
Hi,on most of the DVD players regional set up cannot be changed.
As an easy solution ,you can play them in your Laptop and with proper connection you can watch them on your TV as well..
Hope this helps! Take care and please Remember to rate/vote and give me 4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
DVD region codes are a digital-rights management technique designed to allow film distributors to control aspects of a release, including content, release date, and price, according to the region.DVD video discs may be encoded with a region code restricting the area of the world in which they can be played.
The American DVD Copy Control Association in California requires that DVD-player manufacturers incorporate the regional-playback control (RPC) system - according to the Australian Competition and Consumer Commission, an Australian government agency.[1]
There are six different official regions and two informal variations.[citation needed] DVDs may use one code, a combination of codes (Multi-Region), most codes (Region 0) or every code/no codes (Region All). The commercial DVD player specification requires that a player to be sold in a given place not play discs encoded for a different region; however, region-free DVD players are also commercially available.[2] In addition, many DVD players can be modified to be region-free, allowing playback of all discs.[3]
Jun 27, 2011 | Audio Players & Recorders
What region is the DVD player that comes with the new TEAC TV that I bought? I can't find the info on the manual or the internet. Please help. I live in Australia. Thanks.
It depends if the DVD player is separate to the TV or built into it. Assuming the DVD is a separate unit, it must be region 4 for Australia, unless specified otherwise (on the player's rear panel or in the operation manual). The only types of DVD players/recorders allowable in Australia are region 4, and multi-region. If the player plays region 4 DVDs, but not other regions, there's your answer. A model number and/or brand of the DVD player would help.
May 17, 2011 | Televison & Video
Is there a code to change a Thomson TV DVD combo to multi region - Model L26D?
In a word....NO.
Only DVD's themselves can be multi-region (region code 0).
I always advise on this site that you NEVER change the region code on your DVD player! Here is why....
To prevent DVD copy piracy, every DVD player from EVERY manufacturer allows (if it is allowed at all) only TWO changes to the region code. A third attempt to change the region code permanently locks the player and turns it into a paperweight.
If you happen to be the rare exception to the rule.... that you have moved to a new place that requires you to change the region code to view locally purchased DVD's, then by all means change it ONCE to be able to use your DVD player. Please remember that you can only change it one more time after that though! You will unfortunately not be able to watch DVD's that are from your old region.
Feb 15, 2011 | Televison & Video
Region code
I have a region Code For A Philips HTS-3544 which is 1 model Down. You can try it, it may work or it May Not.
Heres How:- power on the TV/DVD without any disk in the player.Press open/close eject.
Press Stop 7.3.4.4.6.6 ( on the Remote )
The menu code appears On The Screen.
Press 0 for region Free, or the region Code Required.
Power Off and then on Again, if the codes have worked, your dvd player is now region free.
If this works please rate as Fixya.
many thanks mike @ Compurepair.
Aug 28, 2008 | Philips HTS-3555 System
Televison & Video Logo
166 people viewed this question
Top Televison & Video Experts
Electro Med Services...
