A network cable is unplugged
I've been trying to set up a wireless network at home using the Netgear RangeMax dual band Wireless-N Router. After inserting the setup CD and began running the network wizard I received the message ''Unable to connect, a network cable is unplugged''. As I looked in my network connections I noticed that the ''Realtek RTL8139/810x Family Fast Ethernet Nic network cable is unplugged''. I've already replaced my network adapter with ''Nextgear gigabit PCI adapter 10/100/1000 GA311'' with no luck. I've also replaced my cable 5 times. Now I also have 7 local area connections with the ''Realtek RTL8169/8110 Family Gigabit Ethernet connection'' and 9 local area connections with the ''Realtek RTL8139/810x Family Fast Ethernet Nic''. I've read so forums and some suggest deleting the connections from my registry, but I'm not comfortable with deleting items from there. Thanks in advance for any help you can give me.
  • 33 Answers
OK, in order to solve this problem, I will need more information:
1) What is your operating system (i.e. Windows XP? Windows Vista?)
2) Is this a laptop or a desktop computer?
3) If it is a laptop, is there a switch on the case that turns on and off the wireless ability? Check your user manual - it might be as simple as turning on the wireless switch.
4) If it is a desktop, what kind of wireless adapter did you install?
I'll be able to help more when I get this information. In the meantime, here are a few things you can do:
First of all, you need to delete all of the duplicate connections from Network Connections. They won't really hurt, but they're not helping either. To delete them, just right-click on them one at a time and choose "delete."
Next, you need to understand what the message "a network cable is unplugged" refers to: this has nothing to do with wireless. If there is no actual hard-wire cable connected to your computer, the port (that's the opening that you plug a network cable into) will tell Windows that it is empty. This results in the message "a network cable is unplugged." You can ignore it, or - if you plan to use this computer with a wireless connection only - you can right-click on the connection in Network Connections and choose "disable." This stops the message from appearing, and can be reversed (enable) at any time.
I look forward to hearing from you.
Posted on Jan 08, 2009
How to install to att 2wire 2701hgb modem router
Plug one end of an Ethernet cable into the modem's Ethernet output port and plug the other end into the router's single WAN/Internet input port.
Nov 09, 2017 | NetGear RangeMax Dual Band Wireless-N...
Netgear 3300 does it work as a wireless repeater?
sounds like that router isn't really well liked.
I do not recommend using wireless repeaters because your "second" network is only as good as the uplink to it, and I find you often can't move the repeater too far from the first router without sacraficing a lot of quality.
plus that router has bad range to start from what I hear
Oct 14, 2012 | NetGear WNDR3300 - RangeMax Dual Band...
What would be the best ethernet cable to connect my dual band 5ghz wireless n600 router
What do you wan to connect?
This is a router so it should have internet connectivity and is wireless so you should be able to connect it using wireless.
If you want wired connection you can use any cat5 cable.
Sep 03, 2012 | NetGear RangeMax Dual-Band Wireless-N...
How do i turn off mac filtering on my netgear wndr3300 rangemax dual band router through my computer/
MAC address filtering is configured in the wireless settings.
Connect a LAN cable from the Netgear to the LAN port on yourcomputer, open a browser and enter the Netgear configuration URL -
The default login = admin
The default PW = password You can now change the default admin password and configurethe wireless settings.
Go to the wireless configuration and set up the SSID and WPA or WPA2encryption.
Apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on thislink and follow my instructions :-
Aug 24, 2011 | NetGear WNDR3300 - RangeMax Dual Band...
My netgear wndr 3300 wont broadcast the n network and my laptop has a n network adapter
Check with the Settings on Router
Since u have a Dual band Router, Check which is Enabled
make Sure u have the N Network Enabled or Not......
Check and All the Best...........
Oct 05, 2010 | NetGear WNDR3300 - RangeMax Dual Band...
How fix wireless drop. why does my netgear wireless router seem to drop or just no connection to my laptop? I'm currently using this model NETGEAR- RangeMax Dual-Band Wireless-N Router with 4-Port...
Try turn OFF DHCP, START>>RUN>>service,msc enter, scroll down to DHCP, set to OFF & Disabled, also further down Windows Zero configuration, again OFF & Disabled.. reboot,try that.
Feb 28, 2010 | NetGear RangeMax WPN824 Router
NetGear NETGEAR WNDR3300 RangeMax Dual Band router
The Netgear wireless router wireless settings need to be configured and the the wireless card in the computer and XBox needs to be configured with the Netgear wireless settings.
Follow these steps. : -
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL
3. Enter the router setup login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WAP2
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router.
Oct 11, 2009 | NetGear WNDR3300 - RangeMax Dual Band...
IPAQ RX3715 can't log on to home network
Try upgrading the firmware on the router and then connect the IPAQ and computer to the wireless network
Jun 11, 2009 | NetGear RangeMax Dual-Band Wireless-N...
Where do I find the WPA key for my new Netgear RangeMax Dual BAND Wireless-N Router?
A WPA ket is a password that you create. If you didnt create one, you shouldnt have one. If one is set and you dont remember, reset the router to factory settings.
Dec 29, 2008 | NetGear WNDR3300 - RangeMax Dual Band...
Setting up Netgear Wireless-N router
try this plug up a line to laptop to modem to check to see if you can get connected if so then make sure you are on the same network and if so then call comcast to help you setup the laptop wireless settings in sound like the settings online doesn't have the laptop enable to accept the laptop
Dec 01, 2008 | NetGear WNDR3300 - RangeMax Dual Band...
Televison & Video Logo
644 people viewed this question
Top Televison & Video Experts
