Question about iRiver E100 Digital Media Player
How to charge the battery
I understand that to charge the e100's battery the device must be connected to the computer. But does it have to be turned on or should it bed turned off? Will it charge with the computer in 'sleep' mode?
  • fastermaster Jan 04, 2009
    Thanks for the response. The screen reads 'power and connected' with an option to scroll down to 'power and play'. I guess those both mean it is charging. I have it set to 'power and play' but it does not do anything when I try to play it.
  • fastermaster Jan 10, 2009
    If you are talking about recording a song verses downloading it I do not know the answer. You may want to post this as a seperate question.
How do you name each song that's recorded in the E100 and also how does one hear the playback?
Posted on Jan 09, 2009
If you turn the e100 on, make sure the computer registers that it is connected, and you should see somthing on the screen of the e100 that shows it is connected and charging. It should charge both on and off, and it will charge if the computer is in 'sleep' mode but will not charge if the computer is off
Posted on Jan 04, 2009
How to fix my razor scooter e100?
The E100 is a Kick Start scooter, the Rear Wheel has to be Spun for it to start. This scooter will not start from a motionless position.
Could be the battery.
Put the Scooter on a block so the rear tire is raised. Remove the standing plate to reveal the battery compartment.
Charge the Unit completely
1. Using a multimeter measure the voltage across the batteries. If the voltage is below 20 volts batteries are dead - Replace batteries.
2. Now for a running test. Turn the throttle and spin the rear tire to preform a kick start. Still measuring the voltage. If the voltage is Below 20 volts or if the voltage drops quickly batteries are dead - Replace batteries.
3. If the voltage is remaining around 24 volts for a long period - then you could have connector problems, clean and tighten all connectors.
I use a fiberglass electronic cleaning brush, as contact cleaners leave residue that interfere with electrical connections.
The control module is simple and can be replaced with only a 24 volt relay without the kick start feature or Brake. If you want the brake then you can use two 24 volt relays still no Kick Start.
For those of you who know electrical, below is circuits I developed to replace the controller. This diagram will also give you a better understanding on the Razor circuit.
NOTE : This is not a schematic diagram of the Razor E100 Control Module. I designed this circuit. for my Great Nephew's Scooter.
1. The Brake is a normally closed switch that opens when you squeeze the Brake handle.
2. The throttle is two normally open switches that close when you turn the throttle.
3. The Kick Start circuit is described in the Diagram below.
4. The resistors values may need to be tweaked for best performance.
Google Link to what could be the Electrical Diagrams for E-100
Aug 13, 2014 | Sport & Outdoor - Others
No power
Apr 21, 2014 | Razor E100 Electric Scooter
What is the charging votage for iriver E100.
MP3 players usually charge by the USB cable connected to a computer or a USB charging adapter.
The charging voltage for MP3 players is 5 volts.
May 19, 2011 | iRiver E100 Digital Media Player
I have a sansa E100 seriers MP3 player. I was using it fine yesterday , and it just stopped working in the middle of a song. Today I changed to a new battery and it will not turn on. If I plug into the...
Run the recovery tool from the SanDisk website .
Download Sansa Disk Recovery tool
How to use Sansa Recovery tool(instructions)
Download Adobe reader
You need to put the device into "recovery mode" before you run the tool.
- Turn the device off (hold power for 20 seconds)
- Slide the hold switch into "hold" position.
- Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer.
Then run the recovery tool. Select format when prompted.
Mar 20, 2011 | SanDisk Sansa e100 MP3 Player
Razor E100 reset button and no charge
Hi... My son hasnt used his Razor E100 for nearly a year as couldnt find the charger.. I finally found it and as soon as I plugged it in the plug was showing green light as that it was fully charged... When we turn the unit on it lights up but its dead... Where can I get the cheapest battery (and does it have 1 or 2)? Or you mention a reset button? Many Thanks...
Jan 24, 2010 | Razor E100 Electric Scooter
Iriver E100 freezes on statup - has become unusable
I am have the the same problem but when it freezes u lock it then reset it says hold the turns off
Oct 02, 2009 | iRiver E100 Digital Media Player
Computer doesn't recognise device
Either corrupted windows, or bad motherboard. One thing you can do is unplug power cable and all usb devices, wait about 10 mins... plug everything back in and try it....
Aug 13, 2009 | iRiver E100 Digital Media Player
My e100 just died
The internal battery will need to be replaced. Before doing so, make sure the ribbon cable the connects battery to circuit board is fully connected
Jul 08, 2009 | iRiver E100 Digital Media Player
Charging the battery on iriver E100
Yes, you use a USB cable to charge it from your PC.
Jun 18, 2009 | iRiver E100 Digital Media Player
iRiver E100  Digital Media Player Logo
125 people viewed this question
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
