Question about HP Pavilion dv7-1130us laptop
After installing Windows 8 I have lost the functionality for the number keys on the typewriter section of the keyboard. How do I reactivate them?
When I type a number key the last alpha character that I typed is displayed.
    Scholar:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 43 Answers
Out of curiosity, did you install win 8 over a win 7 operating system? And did everything work all right before? Not sure if this could be a driver issue. Have you noticed any other things acting different or wrong? You may need to get updated drivers for your machine. Hope this helps you..
Posted on Nov 03, 2012
  • Leslie Lauer Nov 03, 2012
    I did install over Windows 7. All was well before. I will look online for drivers that I may need.
3 Suggested Answers
  • 61 Answers
SOURCE: my laptop keyboard is typing different letters and numbers
It sounds like your keyboard is starting to go. Try plugging a usb keyboard and using that. If your keyboard needs replacing, it may be around $50, but that will depend.
Posted on Mar 18, 2009
  • 39 Answers
SOURCE: hp mini keyboard shift key 2 does not type @
it has to do with your keyboard setting, currently you are set to the united kingdom keyboard layout, you will need to change this to Unite States settings assuming that you got vista, you will need to do the following
goto control panel
click on regional and language option (there will be a pop up)
click on the keyboard and languages tab
click on the change keyboard button (another pop up will appear)
click on add
and add the United States Keyboard
change the keyboard setting on the upper drop down menu to United States, and then click ok.....this should solve your problem.
Posted on Sep 27, 2009
Why have ive lost the function to use the at key
Hi Diane Andrews
You stated as you have lost the @ function on your keyboard . And by looking at your DP i suppose its a laptop . Well then if so you might need to reset the keyboard layout settings for your laptop . Different OS has its different settings . You might have changed your language settings which may or might have caused it . Steps on how to its here . But if you have lost the @ key itself then ... you might need to get it change at your nearest computer repair shop or bring it to the vendor . Or maybe for time being you can use the on screen keyboard
CLick start - under the search - type On screen Keyboard and select it to use it .
Basic .. Fix an external keyboard and try if it works on that keyboard . If it does then your laptop keyboard might be at fault or need to change the settings .
Method 1 of 3: Changing the Language Settings (Windows)
If your keyboard is not displaying the correct characters when you press keys, your language settings may have gotten changed. If you have the incorrect region selected, your keyboard will act differently. To change it back, open the Control Panel.
You can access the Control Panel from the Start menu. Windows 8 users can right-click on the Windows button and select Control Panel from the menu
Open the Language settings. How you access this depends on which version of Windows you are using.
Windows 8 - If you are in Category mode, select "Change input methods" under the "Clock, Language, and Region" section. If you are in Icon mode, select "Languages".
Windows Vista and 7 - If you are in Category mode, select "Change keyboards and other input methods" under the "Clock, Language, and Region" section. If you are in Icon mode, select "Region and Language" and then click the "Keyboards and Languages" tab. Click the Change keyboards... button.
Windows XP - select "Regional and Language Options", click the Languages tab, and then click Details..
Select your language. Use the menu to select the default input language you want to use. In Windows Vista and 7, select your preferred language from the "Default input language" drop-down menu. In Windows 8, move your preferred input language to the top of the list.
Sep 15, 2014 | Acer C7 Chromebook
What do the f keys mean
On each keyboard there are additional sets of keys delineated as "Function" Keys. These keys are used for additional programmed functions, such as "F8" or "Function 8" which will allow a Windows user to access a boot menu when Windows first starts up. On a regular 102 key keyboard, such as those on a desktop computer, the function keys are located at the top of the keyboard with the letter "F" preceding the number of the key. On a laptop, generally the function keys are accessed by holding down a blue "Fn" down at the bottom of the keyboard and the specific number on the numeric portion of the keyboard. So in the above example of "F8" the combination of holding down "Fn + 8" would accomplish the same action.
I hope this help and if you require additional assistance, please do not hesitate to ask.
May 21, 2011 | Computers & Internet
My number pad on my keyboard is not working, how can I reactivate it?
At the top, left corner of the number pad, there should be a key that says "Num Lock." This key toggles the functionality of the number pad keys between Numbers and Directions.
Press Num Lock once and the numbers should start working again.
Press it again, and the keys should go back to the Directions (up, down, left, right, Page Up, etc.)
Jan 11, 2011 | Gateway Computers & Internet
Definition for keyboard
As the name implies, a keyboard is basically a board of keys. Along with the mouse, the keyboard is one of the primary input devices used with a computer. The keyboard's design comes from the original typewriter keyboards, which arranged letters and numbers in a way that prevented the type-bars from getting jammed when typing quickly. This keyboard layout is known as the QWERTY design, which gets its name from the first six letters across in the upper-left-hand corner of the keyboard.
While the design of computer keyboards may have come from typewriters, today's keyboards have many other keys as well. Modifier keys, such as Control, Alt/Option, and Command (Mac) or the Windows key (Windows) can be used in conjunction with other keys as "shortcuts" to perform certain operations. For example, pressing Command-S (Mac), or Control-S (Windows) typically saves a document or project you are working on. Most of today's computer keyboards also have a row of function keys (F1 through F16) along the top of the keyboard, arrow keys arranged in an upside-down T, and a numeric keypad on the right-hand side. Some keyboards have even more buttons, allowing you to change the system volume, eject a CD, or open programs such as your e-mail or Web browser.
Nov 05, 2010 | Computers & Internet
Typewriter keys malfunctionE
Al these keys are at the right side of the keyboard andwould seem to indicate a broken track on the keyboard printed circuit board. It is repairable with a soldering iron and great care.
Apr 13, 2010 | Smith Corona Wordsmith 200 Typewriter
I have a swintec 8014 s and I would like to use the less than carrots and the more than carrots above the 7 and 8 on the number line. they are not the usual shift key characters, so that is what I want to...
You need to activate "keyboard II) (keyboard 2). There is either a separate KBII key you need to press OR it's a 'code' function in which case you hold down the 'code' key then press the kb2 code key, then release the 'code' key.
Feb 24, 2010 | Swintec Office Equipment & Supplies
Will not Type letter or numbers only types small things in upper corner of keys (blue), tried to reset but still no luck -Smith corona Model KA13
Their is a mode or function key on the keyboard somewhere. Use it to activate or deactivate the keyboard features.
Dec 17, 2009 | Smith Corona Wordsmith 200 Typewriter
How to use the memory function
hit the "Mode" button on the left of the keyboard until the indicator in the display points to "store", and follow directions.
to recall files hold down the "Code" key and hit he key under where it says "Recall"(above the number keys on the keyboard. again follow directions experiment. you can't hurt the T/W by hitting keys.
Nov 11, 2008 | Office Equipment & Supplies
I need help in understanding the keyboard functions
dear,
what does it mean. do you want to know the hotkeys of just want to speed up your typing speed.
if you mean is to speed up you typing speed. then use softwares like typing tutor etc. i used typing tutor 6. it is an old version but is simple too. now i can type very fastly.
or if you want hotkeys then visit this links:
http://users.sa.chariot.net.au/~kday/keyboardtips.html
http://www.helpwithpcs.com/tipsandtricks/keyboard_shortcuts_microsoft_word.htm
http://wiki.blender.org/index.php/Manual/Hotkeys/Hotkey_Keyboard_Map,
the last one is impressive.
regards,
salman
Jul 22, 2008 | Computers & Internet
HP Pavilion dv7-1130us laptop Logo
73 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
