Question about Amana ACS3350AS Gas Kitchen Range
Remove top of amana acs3350
I need to remove top
3 Suggested Answers
  • 3 Answers
SOURCE: Igniter of Gas Burner does not ignite gas
Does your Amana range get very very hot on the exterior part mostly by the control panel?
Posted on Aug 21, 2009
SOURCE: Amana, ACS3350, gas slid - in range, the oven will not turn
I just had the same problem. I had it repaired and it was the oven ignitor. Labor and Parts $185. I now have an additional problem and I have to call the repair person back. The oven starts up and preheats to temp I set of 350 degrees. Then after awhile it will shut off and after another few minutes the clock will come back on and blink. I will repress oven bake and it will go for a short time and then shut off. I don't know what the problem is yet. I am totaly dis gusted with this stove. The stove is only 8 years old!
Posted on Jun 17, 2010
Amana ACS3350 Control Units shuts down when over heats up
Sounds like a bad safety valve Test for 3.2-3.6 volts AC at the gas safety valve with the igniter turned on. If the voltage is there, you have a bad safety valve. If the voltage is low, you have a weak igniter and the igniter will need to be replaced. You can test this with a multi-meter.
Post back your results.
Nov 27, 2012 | Amana ACS3350 Gas Kitchen Range
Amana Model ACS3350AS Oven temp is 25 degrees hoter than display. What do I need to repair it? How do I find a manual for this. This came with the house.
Oven temperature can be adjusted for a maximum of 35 degrees farenheight.
Refer to the page 11 of your owner's manual.
A PDF version of the owner's manual can easily be find at
http://shop.amana.com
Jan 11, 2011 | Amana ACS3350 Gas Kitchen Range
The spark on all four top burners stopped working. How do you I know if it is the igniter? And how do I replace it, if it is?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote to give details about why your cooktop will not spark to light the burners..
Cooktop Range Stove spark ignition does not work
heatman101
Sep 01, 2010 | Amana ACS3350 Gas Kitchen Range
Jun 08, 2010 | Amana ACS3350 Gas Kitchen Range
IWANT TO CONVERT TO PROPANE
It's probably not quite as easy as everyone says. Most gas appliances use a different control valve for LP (propane) and natural gas. You most likely will have to eplace the control valve with an LP one. I would contact Amana to see if they offer a conversion kit -- it would probably come with detailed instructions.
Nov 17, 2009 | Amana ACS3350 Gas Kitchen Range
Gas oven doesn't light ACS3350
While the ignitor is glowing, tap on the valve with the plastic handle of a large screwdriver. If the burner lights the ignitor is weak and needs replaced. If it does not the valve is bad and it is advisable to change the ignitor also although not required.
Eric
Aug 28, 2009 | Amana ACS3350 Gas Kitchen Range
Model ACS3350 oven stops heating up mid cycle
Does your range ever get very very hot on the exterior, mostly by the control panels?
Nov 15, 2008 | Amana ACS3350 Gas Kitchen Range
Amana ACS3350AS Gas Kitchen Range Logo
132 people viewed this question
Top Amana Kitchen Ranges Experts
Sal De
Ismael Rodriguez...
Oloyede Monsuru
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
