Question about Brother MFC 240C All-In-One InkJet Printer
Won't scan will not scan keeps saying "mydvd le does not support importing pictures from a digital cam must upgrade to mydvd deluxe" but am just trying to scan from brother mfc-240c ??? just a week ogo i scanned a document straight off with no troubles
  • 827 Answers
I would uninstall the dodgy mydvd program, and use Spybot to clean up the malware it has spread on your system.
But you can still scan and copy by using Windows Photo Gallery.
1. Click on files tab at the top in Window Photo Gallery.
2. Click on import from camera or scanner.
3. Highlight your scanner icon (ie Brother MFC240c) then click import.
4. New scan window will popup, now you can preview or scan using this basic looking Vista utility.
Hope that helps.
Chris (ziraffa)
Posted on Jan 04, 2009
How can I import digital pictures from my digital camera when I get an error saying that thwere are no pictures to import
maybe the files are hidden. You need to check -show all hidden files. What windows version you are currently using?
Mar 05, 2015 | Sony Vaio Vgn-fz140e / Vgn-fz140e/b /...
Need to upgrade CPU to AMD Athlon X2 7850. Is this possible?
Yes it is possible but confirm that your motherboard will able to support AMD Athlon X2 7850 if it won't then you need to upgrade the Motherboard too.
Keep tuned
Sep 10, 2011 | ASUS M2N-SLI Deluxe Motherboard
Hello, I am attempting to scan an important document and the printer keeps saying "set the document on the platen glass" the document is there but it keeps saying the message
The best way to scan images to save on yourcomputer is to use the scanner software on the computer. Not the scan functionon the scanner.
You don't say what type of scanner software you have but usually scannersoftware works this way:
1) Place photo on scanner
2) Open scanner software
3) Using the software, Initiate scan
4) Name the Scanned item and save it to your desired location/folder
Note: some applications will automatically save to --My Documents--My Pictures
5) Repeat process for each pic to be scanned
May 01, 2011 | Canon Pixma MP480 All-In-One InkJet...
I have a Fuji F30 Camera. When I try to import the pictures on to my system, it says "insufficient Disk Capacity". I have over 700 MB available. It imports the first two pictures, then gives me this error....
Are you saying the hard drive on your system is so full, you only have 700MB left? That's barely how much your system needs to carry on daily activities. That's why it won't let you download any more.
Jan 01, 2010 | Fuji FinePix F30 Digital Camera
Stops taking pictures after approx. 128-130
Hi, Sue,
Not really sure on this, but if where he bought cam will take it back,try it...
However, it may not be the cam, but different resolution settings on the two different cams. Digital cams by different manufacturers format SD cards using different means; some allow more memory space on card for formatting than others..and if the game cam is set at a higher resolution than the other cam, then the 2nd cam might use space 1st cam left avail.i.e., say cam "sets aside 4mb of memory to format card, but only uses 2mb of this space. Now, the game cam is set for high resolution and take 130 pics @ 15mb each..15x130=1950mb,+ 2mb left by game cam=1952mb(1.952gb), or about 50mb of space left on card...put it into cam set for lower res. and might get several more pics before card was really full...be sure all is equal...both cams, and card,ect. 128-130 pics @ high resolution ain't bad....on a 4gb SDHC card with my I-40's set for High Res., I can get 1000 pics;@ enhanced and I get only about 300. Set at low res., and # goes way up.Hope you understand all this.
ron
Mar 11, 2009 | Moultrie GameSpy 4.0 Digital Camera Deluxe
UNABLE TO VIEW PICTURES
no disc for these cams...should be able to view pics straight from SD card thru a card reader to pc...(may have to go thru START..MY COMPUTER...LOCATE DRIVE CARD READER IS DESIGNATED AS....
also should be able to view pics on tv thru video cable attached to cam.
Jan 24, 2009 | Moultrie GameSpy 4.0 Digital Camera Deluxe
I have problem importing videos to my computer using (Roxio MyDVD for Canon)
be sure that you installed the cd driver camed with your camcorder and also try using ULEAD MOVIE MAKER as im using now with my camcorder. its very easy to use. hope that helps!
CHARCOIS
Sep 24, 2008 | Canon DC10 DVD Camcorder
Mercury camera driver
Hello! I have not used my cam as Webcam for many years, but I think all you have to do is connect the cam with PC, move the SELECT NOB / SWITCH on WEBCAM mood and the Windows (XP) will automatically detect NEW HARDWARE (Webcam). Provide the drivers information and files from the disk and you are done.
BTW, its webcam result is not as good as its still picture quality.
Best of Luck
Hassan
Jun 29, 2008 | Kobian Mercury 3.1 Deluxe Classic Digital...
Won't scan
You have to go to Windows Photo Gallery. Click on "File". Select "Import" and it will prompt you from there
Dec 31, 2007 | HP PSC 2410 All-In-One InkJet Printer
Importer photo
Oui oui! Avec le cable: USB entre the Jazz et ton ordi.. S'apparait comme un cle de memoire (si c'est le mot) dans ton 'My_Computer' ...
..m'excuse mon franglais, bonne chance. G-M
Nov 06, 2007 | Jazz DV-179 Digital Camera
Brother MFC 240C All-In-One InkJet Printer Logo
139 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
