Question about Pioneer SD-P50A3-K TV
Pioneer SD-P502/SD-P452 projection TV does not fully power on...
I was given this as is. When you push the power button it sounds like it is coming on, you can hear the high frequency from the electricity/magnetic field, but then nothing else happens. It is pretty much clean inside, no great amount of dust. I saw a panel with a few fuses in it, they look good. Anybody know what I should do? Any help will be appreciated!
rgkeeney
  • skeptick239 Jan 19, 2009
    i found the 5A fuse blown so i replaced it now the red light stays on and the high pitch noise repeats at about 1hz but no loght form any of the tubes
5 Suggested Answers
  • 68 Answers
SOURCE: Pioneer SD-P6091K problem with turning it on
Is this set several years old, and has it been good till now? There is one on the internet, 8 years old for sale with the same symptoms as your friends. There is an internet site `tv-forums.com. Presumably you have already looked with the back off. Make sure there is not a build up of dust, which will cause overheating. If it has a 150 watt UHP lamp, or similar,(expensive!) it may need replacing. The lamp must be cooled by a fan, so make sure this is srill working. There should be a thermal cutout which automatically resets.
Posted on Oct 25, 2006
snakehead
  • 1074 Answers
SOURCE: help
Hi tedski have a tech look at your tv the problem is in the power supply or related circuit.good luck
Posted on Apr 26, 2007
SOURCE: tv turns off
cant solve, but my problem is identical!
Posted on Nov 13, 2010
  • 608 Answers
SOURCE: Pioneer SD-P6091 Projection TV - TV turns off by itself
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Posted on Dec 09, 2010
Tv wont turn on
awesome tv's but by now would have connection troubles look around on the main board for bad connections, use a magnifier for best results
Jun 21, 2010 | Pioneer SD-P50A5-K 50" Rear Projection...
SD P50A3 Q red Standby is on....will not power up.
ok sir you have defective power supply at hot side section! and the power oscillstion circuit! your unit need to diagnos to know the exact defective parts!
Oct 21, 2007 | Pioneer SD-P50A5-K 50" Rear Projection...
Pioneer SD-P5181 will not power up
pioneer sd p5181 will not power up redlight on stand by works when i hit the power button makes a funny sound and then nothing anyone plz!!!! help thnks
Jul 11, 2009 | Pioneer Televison & Video
Tv turns off
Oct 05, 2008 | Pioneer SD-P50A3-K TV
55" PIONEER SD-P5795W REAR..
yeah, I have the same issue... The tv worked fine, and now it will not turn on... the light turns green, then turns off and goes red...
Aug 03, 2008 | Pioneer SD-P5795W 57" Rear Projection...
Power
same problem here
Dec 20, 2007 | Pioneer SD-P50A3-K TV
Pioneer SD-P40
Check your hori out put transistor if shorted replace NTE2973, this should be output number.if you need any more help let me know!
Oct 12, 2007 | Pioneer SD-P50A5-K 50" Rear Projection...
Tv refuses to turn on
your tv is defected need to take in to the tech for repairs.power supply problem or related circuit.good luck
May 20, 2007 | Pioneer SD-P62A5-K TV
Pioneer SD-P50A3-K TV Logo
197 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
