Question about Refrigerators
106.74254400 No water from cup dispenser. Ice maker is ok.
    Top Expert:
  • Refrigerators Master
  • 9,472 Answers
You will need to replace the micro-switch on the water dispenser. Here is the part to order.
Posted on Nov 04, 2012
Buffalo12980
  • 625 Answers
SOURCE: Water dispenser
the slide switch ice - water may not be making up. the paddle inside the door operates a common microswitch to either dispense ice or operates the water solenoid. check out the selector switch.
Posted on Aug 22, 2007
  • 489 Answers
SOURCE: LG Ice maker
You may have a broken ice maker and it needs to be replaced. You will need to have a qualified LG technician assist you.
Posted on May 11, 2008
maklean
  • 1665 Answers
SOURCE: no water to ice maker
  • The water line that's attached to the back of the refrigerator. Make sure you have good water flow. If the flow is poor, repair, clean, or replace the tubing or the shut-off valve that supplies the water.
  • The water-inlet valve. Replace it if it has failed.
  • Posted on Jul 28, 2008
    SOURCE: GE GSH22SGRE - water dispenser not working but ice cube maker working fine
    I just used the hair dryer and it worked the water is flowing again out of the dispenser
    Posted on Dec 19, 2008
    • 142 Answers
    SOURCE: water dispenser on front of refrigerator door does not dispense water. Ice Cube maker continues to make ice cubes. Defrosting doesn't fix problem.
    Water dispensing solenoid is bad. You need to replace the solenoid valve. This typically is independent of the ice maker.
    Posted on Jun 02, 2009
    Water dispenser takes a long time to shut off.
    Sounds like the water valve needs to be replaced. If you move your cup and it continues to pour out water valve is, leaking through
    May 27, 2015 | Scotsman MDT5N40W-1J Touchfree Water...
    Ice maker makes ice but freezes before it can be dispensed so the dispenser is always clogged with frozen ice. Cleaned out the ice maker and started over but same results. The temp is set at 38 for the...
    Hi, The freezer should be "0", the possible clogging you have could be a leaking water valve or an over filling ice maker. I would have the ice maker checked for volume of water dispenser during harvest, should be 5.5 oz. (2/3 cup), if more the 6 oz. the ice maker is bad. If fails to stop filling or leaks/drips, replace the water valve behind the unit.
    I hope this helps.
    Aug 27, 2011 | KitchenAid KBFA25ER Bottom Freezer French...
    Everything seems to work just fine except the ice maker which stopped for no reason. I have checked everything. The water dispenser works well, the water pressure is more than sufficient. We lost power,...
    I know of one trick that might solve your problem . First , make sure the lever that swings up and down during cycle is all the way down . Then , pour one eight ounce cup of water into the ice maker where the slots are . Hopefully , when the water freezes , the ice maker's sensor will detect the ice and start the dump cycle . If it does , and everything is OK inside the unit itself , it should be OK after it ejects the ice .
    Oct 08, 2010 | Refrigerators
    The water dispenser in my refrigerator ice maker is leaking
    if you have recently changed your filter, had the water turned off, or disconnected from the ref this is a common problem. you have air in your water line. fill 5-6 large cups of water or until it stops spurting and your drip should go away
    Apr 23, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
    My maytag is model MFD2560HES serial number
    does the water dispenser work OK ? if yes , a try this : pour 3/4 of a cup of water into the ice maker, right into where the ejection fingers are. also , take all of the ice out of the ice bin. then , give the freezer time to freeze the water you have poured into the ice maker and see if the ice maker ejects the ice into the bin. if it does, it might reset itself and refill the unit and work normally.
    Mar 17, 2010 | Refrigerators
    Samsung RS277 ice maker not filling with water but have water through dispenser
    Pour about 1/2 cup of water into ice maker . If it dumps , replace the water valve . If doesn't dump , replace the ice maker . Also make sure the coils are clean of dust , lint , etc...
    Aug 21, 2009 | Samsung Refrigerators
    Ice Maker stopped making Water Whirlpool model (ed5phexnq00)
    Aug 15, 2009 | Refrigerators
    No water to the ice maker mdl tfx20jrbk water comes out of water dispenser on front of door
    Aug 10, 2009 | Refrigerators
    Maytag MSD 2432GR Water not feeding into Ice Maker
    one possible solution is that the ice maker water valve has failed (solenoid). I would try switching the wires on the water valves and see if water goes into the ice maker when you push the water dispenser button, if it does the valve is ok. If you go this far go ahead and fill the ice maker with water ( about half to two thirds full) switch wiring back as first found and see if maker will freeze and dump ice, if it does ok, if not the problem is probably in the ice maker.
    Jul 06, 2008 | Maytag MSD2436GR Side by Side Refrigerator
    Water dispenser spontaneously erupts when making ice
    I had to fix a problem like this the other day you need a inlet solenoid
    Aug 29, 2007 | Frigidaire FRS26KR4A Side by Side...
    Refrigerators Logo
    Top Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
