Question about Coffee Makers & Espresso Machines
My Vienna Superautomatica machine fromSaeco doesn't make coffee ! It is grinding, but water doesn't mix with coffee, and it just goes to the waste! Please see the video attached an let me know! There
  • 3 Answers
Hope I could help u
Posted on Nov 08, 2012
  • Antonio Cerda
    Antonio Cerda Nov 23, 2013
    I can hear the water pump noise and I think Your coffe machine needs to purge ,open hot water until go out if hot water doesn,t come out
  • Antonio Cerda
    if hot water does not come out may be obstructed internal hidraulic system
    New Friend:
One solution is pull the brew unit out of the machine. Behind where the brew unit sits is a small compartment. Stick your finger down in the bottom of the compartment. If it is clogged, clean. If the problem still exists after you have checked this, you most likely have a clog in the steam valve area. This is highly common, which you would need to rip apart yourself or send into a repair center.
Posted on Dec 09, 2012
espressonist
  • 1711 Answers
SOURCE: water not pumping out of coffee machine
It seems that the coffee solenoid valve is blocked or broken. Cofffe solenoid valve is the valve which open to deliver the water after the pump to the coffee shower.
Posted on Feb 18, 2010
The Machine
  • 788 Answers
SOURCE: I have a Krup Orchestro
When you ran the cleaning cycle did you use the Krups cleaning tabs?
Posted on May 21, 2008
SOURCE: saeco vienna deluxe espresso machine
adjust the water flow look for a knob that turn right to left minus less water plus more water
Posted on Dec 30, 2007
espressonist
  • 1711 Answers
SOURCE: how do I clean my Saeco Vienna SuperAutomatica
In order to proceed with decaling of the espresso machine you need to have the solution appropriate for decaling an espresso machine.
Different brands of espresso machines, like Krups, Saeco, Gaggia e.t.a. have their own brands of decaling solutions. You should know that all of these are similar products so you can use them in all different bands if you don't have the one of you specific brand without any problem. So if you have Krups machine and you can only find Saeco decaling solution you can use it with the same results.
One thing you should have in mind Never use any Vinegar as a decaling solution since this will destroy some parts of the machines not instantly but in long term since vinegar is corrosive to this parts.
So the first thing is to remove any water fitters or small softeners that are included in you water tank. Fill the water tank with water up to maximum, dissolve your solution in the water you do need only two to three spoonfuls of solution.
Switch on the machine and wait to warm up. When the machine is ready you can turn the water knob and start getting some water in a pot. Leave it for a couple of minutes and then again the same. Do these until you draw off all the water with dissolve solution. After that leave the machine for more than 20 minutes. Remove then the remaining water with solution from the water tank, rinse it and fill it with fresh water. Now draw again continuously hot water from the machine in order to rinse it completely.
The last portion of hot water taste it to be sure that is pure clean and if not refill the water tank again and perform another rinsing.
Now the machine is ready to be used again.
Try to do decaling every 20 to 30 days.
If you plan to leave the machine unused for along time perform a decaling in order to avoid the possibilities of having the machine stuck when you will try using it again after a long time.
A machine which is used frequently every day is more secure to work fine even without any decaling but machines which are used rarely is more possible to have problems of stacking out in water outlet or coffee outlet.
Posted on Jul 01, 2010
  • 1089 Answers
SOURCE: I just received a used Saeco Vienna
HI
You must have 2 knobs in the bean hopper, or the grinds are more like French Press (very large grinds) If yoou just have 2 knobs turn the small one towards the minus (-) a little, and see idf that helps. If you hqve very large grinds you grinder has seperated and needs to be replaced.
Posted on Oct 06, 2010
Saeco Vienna superautomatica leaks when making coffee
This is an easy fix for a 14$. The seal at the water tank connection is worn. Take the water tank off. There is a round flat topped plastic retainer. Pry off the retainer (comes off easily). You will see a black round o-ring made to fit on a channel. Remove the o-ring and replace.Two minutes and you are without water leaks. I do not remove the tank to fill anymore, I use a pitcher instead. Part number 3 in this diagram.
http://www.partsguru.com/user/VIENNA%20PLUS%20DIAGRAM.pdf
Jan 21, 2013 | Saeco Vienna Espresso Machine
Having a problem with the mix. In the disposed grind container I am getting a lot of water mixed in with the grinds. Tried to clean screen and a glass bead fell out. I am assuming this came out of the...
The glass bead is part of the pressure system. It goes under the long tapered spring. The bead goes in first, then the small end of the spring, then the Oring goes around the spring on the plastic part of the head. Then the manifold goes on with the L shaped tube going towards the handle side. Hold down the manifold when you puty the screws in.
water in the dredge drawer is a sign of a coarse grind. The finer the grind the less water in the dredge drawer. Don't go too fine or you will be cleaning the brew head a lot.
Nov 09, 2010 | Saeco Vienna SuperAutomatica Coffee...
I just received a used Saeco Vienna SuperAutomatica and I can not get coffee to brew. Drive grounds are shot into discard bin
HI
Oct 06, 2010 | Saeco Vienna SuperAutomatica Coffee...
What is the difference between a water tank with & without a magnetic float on a saeco Vienna Superautomatica?
Hi
The magnet tells the machine that the water is low so you don't run the pump dry and cause it to fail. Some Vienna Supers had them and some didn't.
Jan 01, 2010 | Saeco Vienna SuperAutomatica Coffee...
Hot water
Grinds are too fine and or the coffee chute is clogged.
Feb 19, 2009 | Saeco Vienna SuperAutomatica Coffee...
Long time for drip coffee.
Grinder is set to too fine. Lower grinder settings. Keeping the machine at current settings with drip extraction will result in brew group clogging, gear stripping, and/or dulling of grinder burrs.
Jan 30, 2009 | Saeco Vienna SuperAutomatica Coffee...
Saeco vienna superautomatica
oily coffee residue on the grinder prevent the bean from going down be carefull push coffee down in the grinder with anything except our finger by forcing coffee down will making expresso it should grind if it does remove the coffee cointainer little star screw driver after removing the container inside the grinder where the coffee go down you gonna see a steel piece the coffee goes down the slot remove the old coffee residue on that part clean it good with a tooth brusch or somrthing like that put back without old coffee stuck on the grinder you gonna see the coffee gonna go down in the feeder cheers and if it help you dont forget to rate this cheers
Jan 23, 2008 | Saeco Vienna SuperAutomatica Coffee...
Saeco Vienna superautomatica Machine
if you open the steamer, does it work correctly? and if u request hot water does it come out?
if not, then its the pump..
Nov 02, 2007 | Saeco Vienna Espresso Machine
Coffee Makers & Espresso Machines Logo
278 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
