Question about Logitech Alto Cordless Laptop Stand(939000223 Keyboard
Disassembling logitech alto stand
Hi, The place where you plug the power cable into the stand seems not to work properly (turns off and on as I giggle the cable). I am trying to disassembly the stand to take a look and fix it but I have unscrew all the screws I can see but it will not open. Any idea on how to do it? Thanks
  • Pablo Apr 11, 2013
    Thank you Akos, I ended up doing it like that but forgot to post it. It was quite annoying to find out that it was glued instead of screwed.
You need to disassemble the two part on the right side of the stand, where the USB connections are and where you can push the connect button. This is fixed with glue and some kind of tape. Use some force (I used screwdriver) :) Under this you will find 3 and 4 screws. Then you can disassemble it completely (see photo)!
disassembling logitech alto stand - 1386eae6-f9cb-4d9e-a9d5-2f9d3fa3a336.jpg
Posted on Apr 11, 2013
No power to printer
Try moving to another plug. Just for giggles.
Dec 02, 2014 | Canon MG5350 Wireless PIXMA Inkjet...
My M109R stall when I put it into gear, The stand switch is plugged in and seems to be working correctly. I just installed new air filters and a fuel processor. Runs fine in idle.
You should check the kick stand switch with a meter or unplug it and install a jumper wire to be sure. Is your clutch adjusted properly? Is the bike trying to move when it is placed in gear?
Oct 02, 2014 | 2007 Suzuki Boulevard M109R
My monitor will not boot up when my comp has been turned on it just sits there on stand by i really need help says theres no signal
You can try to open the case and remove the cell (battery) on the motherboard, it looks like a coin. Plug it back again. Also, you might wanna un-plug SATA cables and trying again.
Replace RAM chips (change their places if you have two or try with only one RAM plugged) . Also, try starting it without RAM.. if your computer continuously beeps then there might be a sign of recovery. If it still doesn't show anything. Get it checked. The problem could be with PSU (Power supply) or maybe the VGA Cord (doesn't seems like it is problem with that though).
Feb 21, 2013 | E-Machines eMachines Desktop PC
It turns on then the light gose yellow and turns off
The problem with your Console seems to be that either the Console is overheating or it is'nt getting the required power to run.
Solution:
  • Try placing the Console in a more ventilated place.
  • Check the power cable or cord for cuts or check whether the Plug is secure to the Socket.
Thank You.
If the problem persists mail me at :C.RahulX@gmail.com
Feb 10, 2011 | Sony PlayStation® 3 (80GB) Console
I have a coleman cheyenne 2000 pop up camper and none of the lights will turn on to include the carbon monoxide alarm. All of the outlets work fine. We checked the fuzes and flipped the switch. We also...
when towing my camper it seems my running lights do not stay on andmy brake lights and turn signals do not work properly. I can giggle the harness wires and everything works.
Jul 08, 2010 | Camco Battery Fridge Refridgerator Alarm...
HOW DO I INSTAL A TOSHIBA EXTERNAL DVD RECORDER TO SAMSUNG SMT-190DN..
If your are going to install the dvd recorder into your other device, follow this few steps.
  1. Place your external DVD Multi-Recorder drive in the stand. Otherwise, lay it down horizontally if you're not going to be using the stand.
  2. Turn on device.
  3. Plug one end of the USB cable into one of the dvr USB ports. Then connect the other end into the external DVD Multi-Recorder drive.
  4. Plug the power cord into the AC adapter. Then connect the cord into the drive's jack. Connect the other end into the power outlet.
Hope this helps
Nov 23, 2009 | Samsung 4 Channel Dvr
Hp ipaq seems dead
Without know exactly what already you tried to powered it on, I can only especulate on all the possible reasons, so let go one by one throuh them and their possible solutions:
1. The RX3000 Ipaq family has a known mechanical issue on the switch that senses when the back cover lid is properly closed.
When the switch is nor properly depressed, the PDA won't charge the battery if plugged on the cradle or to the USB sync cable, or won't turn on.
Remove the back cover lid and the battery, put them back again. Check the cover lid is placed flush and that there is not any gap between the cover and the PDA body.
Try again in power it on and/or charge the battery, confirming the orange LED light is turning on.
2. Either the cradle/USB sync cable or the AC wall adapter are defective.
The PDA won't power on if the battery is not charged to the minimum voltage for it. If the AC wall adapter or the cable/Cradle are defective, won't power on.
Put to charge the battery and confirm the orange LED light is turning on. If so, the you can discard that the cradle/USB cable or AC wall adapter are defective.
It the orange LED light won't turn on, it may be either one of these three parts that are defective, or that the back cover lid is not properly closed.
3. The battery dried out. If the battery is defective or won't accept charge, the pda won't power on.
To discard a defective battery, put the PDA to charge it, and it will power on when plugged to the USB cable or to the charger, and check in the settings screen, on the power icon, if the battery is charging.
If the back cover lid is properly placed, and the PDA won't power on when plugged to the USB cable or AC wall adapter, then the battery is not the problem.
4. Discarding that the battery or the USB cable or cradle or the back cover lid are the problem for this problem, the only option that is left is that the main board is defective.
Such failure on the mainboard could be caused for several reasons (moisture or humidity or water damage, or a electronic component that is worn out, or a integrated circuit that is shorted, etc) but it can be only verified and confirmed by an electronics technician.
You have the option of send it to be repaired, or try it yourself, which will require to buy a PDA with working mainboard (or the mainboard alone) and swap the parts. It requires a minimum of technical skills to do it.
Best regards,
Dec 10, 2008 | HP iPAQ RX3715 Pocket PC
Stand by mode
Check the display cables , and if you have one test a different monitor on your computer.
If this is not a sceen problem, then it is an internal fault possibly the motherboard.
Try first leaving the PC power cord unplugged for ten, fifteen minutes and check if PC restarts afterwards.
Nov 28, 2008 | Computers & Internet
Logitech MX3200 wireless keyboard and mouse
Hi...
You're probably going to need a Desktop USB Extension stand or cable if, I assume, you have your keyboard USB Receiver plugged into the back USB port of your desktop. These extension stands often come with your cordless devices (i.e., I got one with my Logitech cordless mouse... I don't need it for my laptop, but I do when using my desktop PC). You can make your own extension by purchasing a "Male-to-Female" USB extension cable, 3 to 6 ft in length (or longer if you need it). Plug the cable into your desktop, place the female end of the cable near where your keyboard is, and plug your keyboard USB receiver into the female USB socket of your extension cable.
Hope this helps!
dawog
Aug 05, 2008 | Logitech Computers & Internet
StoreJet 2.5 Spinning properly(sounds) but not detected
try the drive in a new case. if that dosent work the drive is dead.
May 07, 2008 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
Logitech Alto Cordless Laptop Stand(939000223 Keyboard Logo
562 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
