Question about Proscan 42LA45H 42 in. LCD TV
Where is the factory reset button on my proscantv
I need to reset because my colors and pixels are green
  • 1,238 Answers
The factory settings is on the menu.
It possibly you have faulty t-con board that need to be replace
Posted on Nov 04, 2012
The screen turns green after playing videos for 20 minures
The Video Controller works off of the RGB principal. RED/Green/Blue pixels. The mix color is dependent on the formation and density of the pixel and rates. When one or more colors are absent the only functioning color will dominate, and it is Green in your case. The screen liquid crystals in Red and Blue are failing and only a screen replacement will fix the situation.
Jan 04, 2015 | Toshiba C655D-S5200 Amd Dual-Core C-50 3Gb...
When turned on, my Olympus 700 Stylus digital camera shows a thin green vertical line on the right side of the viewfinder--7/16 of an inch to the left of the right edge of the viewing area. Part of this...
this is a problem with your CCD and not any software fault
and so best solution wil be to get this serviced by authorized service center
Oct 05, 2008 | Cameras
We have a Phillips plasma tv and the picture pixelates randomly and freezes for about a second and sound breaks also. We have had everything checked and have been unable to find a solution. The latest...
In my openion, Its problem of hardware in your TV and signal processing circuits are involved. It might be problem of Firmware (programe to control the performence over all) Philips can advise you better in this regard.
Aug 01, 2008 | Televison & Video
RESET DELL MONITOR E1709WC
Instructions
    • 1 Push the "Menu" button on the front or side of your Dell monitor. The button's icon resembles a miniature monitor. This will open the main monitor setting menu. Push the button again to exit the main menu and open the OSD menu.
    • 2 Push the "Down Arrow" button on the monitor to scroll through the OSD menu. Stop at "Factory Reset." Push the "Menu" button to open the factory reset menu.
    • 3 Push the "Down Arrow" button to select "Position Settings Only" to reset the monitor's horizontal and vertical screen settings. Press the "Menu" button to activate the setting changes.
    • 4 Push the "Down Arrow" button to select "Color Settings Only" to reset the monitor's red, blue and green color settings. Press the "Menu" button to activate the setting changes.
    • 5 Push the "Down Arrow" button to select "All Settings" to restore the monitor to its original factory settings. Press the "Menu" button to activate the setting changes.
    • 6 Push the "Up Arrow" button to select "Exit" to leave the monitor reset menu. Press the "Menu" button to exit the OSD menu. Push the "Menu" button again to exit the main settings menu.
Aug 02, 2012 | Dell Computers & Internet
Hitachi ultra vision tv stuck on on moment please screen
Another malady common to plasma TVs are stuck pixels. This is where a red, green or blue pixel will fail to reset and remains conspicuously on the screen in the midst of the new images being displayed. There is a useful third-party program called JScreen Fix. This utility stimulates the pixels in the television through an intensive and prolonged burst of colored static. Many times this is enough to remove the stuck pixel. To utilize this program, you will need to run it off of a laptop that is hooked up to your plasma television. To download JScreen Fix, http://www.jscreenfix.com/
Sincerely God bless young
ernesto cuadra
Dec 17, 2011 | Hitachi Televison & Video
How to fix dead pixels
Cheaper to throw away instead of trying to fix, if green is fading the rest will soon follow, I gather it must be near 4 or 5 years old as this seems to be the life span, sorry I have no solution as even dead pixel fixers will not restore lifeless colour, this is usually worn out caps and backlight.
Dec 01, 2011 | HP Computers & Internet
It doesn't show red color. i tried to do factory reset. but still problem.
1.After turning on the projector, press "+" and "-" buttons on the control panel
simultaneously for 3 seconds and release the buttons when screen goes blank.
2 Press "+" and "-" buttons again to exit the diagnostic mode.
3 While in Self-diagnostic mode, the screen will run a seven-color-cycle test as
following:
Red--> Green--> Blue--> White--> Watchet Blue--> Dark Green--> Yellow.
Ensure that the colors of the test pattern are correct.
Contact Dell if the colors are not displayed correctly.
Mar 01, 2011 | Dell 2400MP DLP Projector
What does it mean by dead cells?
I assume this is related to your LCD monitor.
I think you mean dead pixels. The LCD monitor has tiny pixel elements, one for each red, blue, green color and each one of these colored pixels are turnes on by a transistor. When a transistor fails then the colored pixel it controls does not light up. This is a dead pixel and it shows up as a tiny black dot.
If the screen displays a blue screen, a dead blue pixel will appear as a tiny black dot in the blue screen.
You normally would not notice a few dead pixels unless they are grouped together.
Sep 20, 2010 | Hanns.G Corporation HW191D 19" LCD Monitor
I have a panasonic pt-60dl54, the sound works but green picture
Hi,Yes your problem sounds like the DMD board.This is how it works: http://electronics.howstuffworks.com/dlp1.htm Basically the light of the lamp goes through a tunnel that carries a color wheel(rotating disc with a gamma of colors that creates the colors on your tv)then the light of the lamp goes through the DMD board which is a chip composed of around 2 million pixels that creates the images and colors.When it starts to fail it will create black bars,pixelation,color distortion or white dots on screens.You will need to replace the DMD board. Have a blessed one!
Apr 13, 2010 | Panasonic PT-50DL54 50" Rear Projection...
Can i reset my parrot back to factory settings
yes you can do this by going into settings then scroll all the way down to the bottom and select factory settings the push the middle button in. then push the green button for yes.
Nov 17, 2009 | Parrot 3200 Ls Color Handsfree Bluetooth...
Proscan 42LA45H 42 in. LCD TV Logo
942 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
