I have a york diamond 80 furnace and the led light is flashing 11 time.
5 Suggested Answers
  • 92 Answers
SOURCE: Furnace keeps shutting down after lights
time to call service guy you are cycling on a saftey which means somethings not right in ignition circuit the only thing i would tell a untrained person to try is cleaning the flame rod which is part of the pilot assembly it is a metal rod that gives small electric current to ignition device confirming that you have a pilot lite you can lightly sand with sand cloth
Posted on Apr 15, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: York Diamond 80 furnace (propane conversion),
Check for 24 volts across the two terminals on the gas valve when the ignitor glows. If yes, bad gas valve or blockage in the gas train. If no, bad ignitor or circuit board. Even if the ignitor glows, it still may be bad and not sending the proper signal to the board. If you jump the R and G terminals on the circuit board, does the fan still only run for 90 seconds? If so I would say replace the board.
Posted on Dec 28, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: York Diamond 80 Furnace: blows cold air after
There may be more than 1 limit switch. Look at the wiring diagram and follow it to all switches. Or jump out the complete circuit.
Posted on Jan 21, 2010
  • 117 Answers
SOURCE: I have a York Diamond 80 furnace and am getting a
http://www.ehow.com/list_6543923_york-furnace-error-codes.html heres what i could find on these codes. the falt codes should be posted inside the furnace .
Posted on Feb 14, 2011
York diamond 80 - continuous flashing red
Is there a chart on it somewhere that describes what each mode of flashing means? Most of them do. Inside the front cover,,,somewhere on the inside of the panel that covers the filter? I've never seen one of these without that diafram.
Oct 24, 2013 | Tools & Hardware - Others
York diamond 80 manual
where is the air filter located on a York diamond 80?
May 03, 2013 | Dayton Gas Furnace Heater
York Diamond 90 furnace blows cold air
There maybe a few issues. They have multiple safeties on furnaces. With this in mind this process to find the problem would take a Technician to check these safeties. It could be a flame sensor or thermocoupler each senses a flame or heat to keep the gas going. Also the damper for the flue must open for the gas to stay on. There may be more safeties on this and each safety sends a 24 volt current back to control module in order for the gas valve to stay open. If these aren't being met it will try around three times and go into a lock out mode which will keep gas shut off entirely.
Feb 21, 2012 | Heating & Cooling
I have a 11 year-old york diamond 80 furnace. The flame sensor lights up and ignite the flame for about 5-6 seconds. Soon the flame goes out once again. There's this clicking sound that is heard every
You need to clean the sensor with steel wool so its very clean check sensor connections . If it is still not working you could change sensor also check out the pressure switch .
Jun 20, 2017 | Heating & Cooling
York "high Aux or spill limit switch open"
how can I fix the spill limit switch, also how do I found it
Mar 05, 2010 | York Furnace Draft Inducer Blower Fasco #...
York diamond 80 hvac blower and comp wont start on automatic
Need blower motor for York Diamond 80 Furnace I am in St Louis MO where can i get one
Jun 20, 2009 | York Furnace Draft Inducer Blower Fasco #...
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
