Mitsubishi ic la4270 - Televison & Video
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
Try Suburban Electronics who has online catalog and 800 number.
Posted on Nov 04, 2012
Mitsubishi vertical output chip la4270
Suburban Electronics has 800 and online catalog should have it.
Nov 03, 2012 | Televison & Video
Mitsubishi ic replacement
Try to give enough information such as a model#, which IC you're referring to and a good description of the problem.
Looking forward to help..
www.aaatvservice.com
May 08, 2012 | Mitsubishi Televison & Video
Have a WD-52725 Mitsubishi TV. Notices lines
Ur tv have convergence problems before,that why tv getting colors lines somtimes alot,sometimes not.The 2 STK convergence ICS was defective.Now the 2 STK convergence ICS are now totally dead.The shop will cost u $300-350 for parts and labors for the 2 STK convergence ICS,and it supporting resistors.
May 12, 2010 | Mitsubishi WD-52725 52". Rear Projection...
My Mitsubishi VS-50705 has an all over 3-D effect.
Yes it sounds to be convergence issue .
You have convergence problem in your tv . You need to replace convergence IC . YOu can get from the link below .
Convergence ICs
You need to replace both convergence ICs .It will cost you around $30 .
The IC number is STK392-110 .
Hope this helps .
Mar 03, 2009 | Mitsubishi VS-50705 50" Rear Projection...
Mitsubishi ws55905 needs ics replaced
There will be 2 of them big black ICs will have Part number on them STK392-560 ,570 ect...?? use same # on the ones you have.Make sure you resolder all poor solder connections on board.
Feb 19, 2009 | Mitsubishi WS-55905 55" Rear Projection...
Mitsubishi vs50502
That's a convergence circuit failure. You may have to have the convergence output IC(s) replaced. Sometimes, if you catch it early and its still intermittently doing this, you may get lucky and only have to re-solder the pin connections under the convergence IC(s). If you're not up to doing this yourself, contact a Mitsubishi authorized service center. If the IC(s) need replacing, expect to pay $400-$500 to resolve this issue.
michtech
Feb 14, 2009 | Mitsubishi VS-50502 50" Rear Projection...
Mitsubishi ws 55809
Its a STR-G6632 the mitsubishi part number is 267P151010
Oct 24, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi VS 50607 Problems
Vertical output IC most likely needs to be re-solderd. However this model is famous for the CRT leaking coolant in the area of the Vertical output IC and corroding the solder. Check for a sticky residule near the Vertical IC indicating a leaky CRT seal.
Apr 09, 2008 | Mitsubishi VS-50607 50" Rear Projection...
Convergence IC
The convergence IC's are black in color with white lettering on them and will start with STK. These IC's will be standing up and be about 2" X3" in diameter. These IC's will also be mounted up against a large metal device called a heat sink. good Luck
Apr 08, 2007 | Mitsubishi VS-5043 50" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
