Question about Electrical Supplies
Devilbiss Powerback GT5250 generator won't start
5 Suggested Answers
  • 3 Answers
SOURCE: motor runs wide open but no power from generator
You will need to install new diodes,they are located in the plastic housing behind the receptacles...It looks like little spark plugs..They work to put dc voltage to the rotor,without the exciter voltage applied,you will not get ac power out..The part number is 3483.01....You can buy these online for about $6 each,they have 2 inside the generator,and you should change both.
Posted on Dec 17, 2008
mamicheddy
  • 79 Answers
SOURCE: I own a powerback gt5000 electric generator. It
The best place to obtain manuals at a discount price is -
repairmanual.com
Posted on May 09, 2009
ROMOAS
  • 97 Answers
SOURCE: i own a powerback gb5000-4 generator and need
HERE is the manual for your unit in PDF format please click where it says HERE.
hope this helps
Posted on Sep 03, 2010
Mr BrokRench
  • 1623 Answers
SOURCE: Our Honda EB 3500 generator
It's either not getting enough fuel, or the govenor is not working. When the engine is running, watch the throttle linkage between the carburetor and engine, looks like a bent wire. When you throw a load on it, it should move to give the engine more power, if it dont, try moving it by hand.
If that appears to be working ok, check the fuel line from the tank to the carb for good gas flow.
You can also remove the float bowl on the bottom of the carb, it's a round bowl on the bottom of the carb with a bolt in the middle of it...clean it out and check the float. The float looks like a little catamaran, make sure it is moving freely up and down. That is about all you can do without removing and cleaning the jets in the carb.
Good luck, & i hope this helps.
Posted on Aug 27, 2011
I just bought Power Back GT5250-1 Generator (same thing as a Devilbiss GT250-WK-1) I haven't got it running yet, and before I do I have a question about the wiring. There is a ground lug mounted on th
No way of telling because the pic does not show where wire originate. Nice generator but wires could be from other owners own ideas about connections. Where do these wire come out of? How are they connected, to the gen, or from the outlets? Odd, if the schematics dont show them then how are they commected
Jan 19, 2015 | Electrical Supplies
Powerback gt5250 generator starts but wont keep running
Are you sure the float level is OK? Is the fuel old? Is the air filter dirty?
Jul 04, 2014 | Electrical Supplies
Devilbiss powerback gt5000
no this is caused by a dirty fuel jet and tube which is normally located underneath the fuel solenoid on carburetor
Dec 31, 2013 | Electrical Supplies
Ive a GT5250- WK PowerBack generator and it's leaking oil from I don't know where. Can you help?
usually its the seal were the geny joins the engine u will need to separate generator from engine check the seal and replace with new one,
Oct 11, 2013 | Groove Tubes Power Back 5,250-Watt...
Powerback 5250 no electricity at outlet, alternator hot, pressed reset no change
If alternator is hot without load the generator may have short circuit in windings or on terminals.
Apr 19, 2010 | Groove Tubes Power Back 5,250-Watt...
My 5250 watt Power Back generator will not start, and their is no spark at the spark plug.
Have you check the engine oil level?If it is down on oil you won't get spark because of the oil level switch shutting the ignition down to protect it's self.
Jan 22, 2010 | Groove Tubes Power Back 5,250-Watt...
repairmanual.com
Apr 20, 2009 | Electrical Supplies
Motor runs wide open but no power from generator
Dec 16, 2008 | Electrical Supplies
Electrical Supplies Logo
496 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
