My dryer keeps running after the cycle, I unplug it and open the door. I have also cleaned the lint trap and the sensor but it still does the same thing when I close the door.
If the dryer continues to run when you open the door you will need to replace the door switch. Here is the part to order.
SOURCE: Maytag Dryer not working properly after cleaning lint trap.
where does the noise sound like its coming from??
SOURCE: Maytag dryer timer keeps running
Your dryers timer contacts have fused to gether.
The only repair is to replace the timer.
SOURCE: Keep getting error message AF druing drying cycle and I've cleaned the lint trap.
check for clog or kink in dryer vent
SOURCE: Lint Filter Light comes on and cycle is interupted
I just found that the filter itself was not allowing airflow- I tested by blowing through it with my mouth- no airflow. I cleaned it with a high pressure air hose and noticed that the flow is much better now. I cleaned it by hand several times, and washing in water (which may have made theproblem).
BTW it is electric
