Question about Kodak Easyshare M753 Digital Camera
A black screen is displayed when I turn the camera on.
I take a picture and the picture is a black photo. Why does this happen and what can I do to get back to view what I'm taking a picture of?
SOURCE: Camera Problem
I have been reading a lot of posts from people with similar problems. Apparently, when people try to fix this camera, they are told that the parts are no longer carried and are told to buy or upgrade to a new camera. I am interested in hearing more experiences from people on this camera. I work for a consumer rights law firm and we are investigating this. You can contact me at abby1100ny@yahoo.com. Thanks, Abby
Posted on Apr 12, 2007
Noggin
  • 944 Answers
SOURCE: Kodak EasyShare P850 - Black screen
here is the link to the Kodak support page for your camera; http://www.kodak.com/global/en/service/products/ekn030485.jhtml?pq-path=7546 It has user manuals, FAQs, troubleshooting etc if you select "view in browser" under manuals (the download seems to have a problem) then select "camera problems" under "troubleshooting" First see if anything there helps out (especially check the "EVF/LCD toggle button"). Next thing to try is removing any memory card if you have one inserted and see if this helps. If so then try reformatting the memory card. replace it if this doesn't help - try and borrow a card from someone to check that this makes a difference. Next try resetting the camera to all default values - this is easiest to find by looking under "reset" in the index of the manual - there is a setting in the setup menu of the camera that allows you to select this option. If that doesn't help then i would recommend contacting kodak (all details are on the link page) - they may have a solution for this problem that has not yet been added to the website Hope this helps - please ask for more info if not :)
Posted on May 20, 2007
  • 27 Answers
I have fixed several Kodak models including this one with exactly the same problem. Sometimes tapping on the side will fix it temporally. The fix is to open the back of the camera and snap the connector from the lens. If the camer is dropped the connector can come unsnapped. You should only attempt this if you have had some experence working on electronics. Be careful inside the camera especially in the upper right corner which is where the high voltage is for the flash. You can get a large shock from this camera if your not careful.
Posted on Oct 10, 2007
TampaNative
  • 778 Answers
SOURCE: Black viewing screen and blank pictures
Luckyfourme,
Check to see that the automatic lens protector is opening and/or off when you experience black screen, as it should open letting light in when you power up the Kodak easyshare camera.
Good luck and Congratulations on your Daughters upcoming Wedding!
Posted on Mar 10, 2008
SOURCE: Black LCD screen everytime i turn my camera on
why have the fizya guys when they don't have any answers-good show!!!
Posted on Aug 29, 2008
Screen went black
Think that you might have accidentally pressed the DISP or DISPLAY button on the back of your camera. This manually turns the LCD display on and off to save batteries. You would then use the optical viewfinder in its place. To turn the screen back on, just press the DISP button one more time.
Feb 27, 2010 | Canon PowerShot SD1200 IS / Digital IXUS...
Hi, I have a Canon IXUS 95IS camera.. For some reason, when I attempt to take a photo, the LCD screen isn't displaying what is actually in view? In movie mode it comes up on the screen but when i flick it...
Ah yes! you have pressed the display button. Turn the camera on and you see the icons in the display, look for the Disp button and press it, the display will cycle through its modes icons, black, image and icons.
Jan 22, 2010 | Cameras
A85 camera LCD shows up with pink and black lines every time a picture is taken. LCD screen displays the camera icons on LCD screen but will not take anymore photo's. Lens used to view picture status...
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check this link for more info.
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/V3/300/400/430/500/II/IIs, IXY Digital 200a/300a/320/400/450/500/30/30a
Jan 06, 2010 | Canon PowerShot A85 Digital Camera
Black screen
Try cycling through the Display button until you're able to view photo to be taken.
May 06, 2009 | Sanyo VPC-S500 Digital Camera
IXUS 500 Screen Not Displaying Picture
Did you see the posting regarding the image sensor? I am exibiting the problems which sounds like it could be what you are seeing. I went ahead and send an email to canon. we will see what happens. I suggest you do the same.
-MitchDZJ
Oct 25, 2008 | Canon PowerShot S500 IXUS 500 Digital...
Canon A620 No Picture
First try hitting the DISP button (sorry if this offends, but many people have made this mistake). If this doesn't help, next try resetting the camera. Turn on the camera, and hold the menu button for at least five seconds. Believe reset is also in the menus.
If the above doesn't help, then unfortunately this sounds like your CCD image sensor may have failed. This would then require professional repair. Contact Canon at 1-800-OK-CANON.
Sep 14, 2008 | Canon PowerShot A410 Digital Camera
Black screen
Did you try pressing the DISP button while trying to take pictures? It turns the display on and off.
Nov 20, 2007 | Canon PowerShot SD500 / IXUS 700 Digital...
Black screen when viewing photos taken
When the picture does not display - do you see the normal text and icons that you would expect to see? Or, is the screen completely blank?
Feb 22, 2007 | Panasonic Lumix DMC-TZ1 Digital Camera
Kodak Easyshare M753 Digital Camera Logo
24 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
