Question about Thomson 20LCDB03B 20 in. Television
Thomson TV model 15LCDM30B locked on standby
I have a 2004 Thompson LCD flat screen TV which I have fitted in a stretched limousine. Whilst mucking about with the menu I clicked on lock and now I cannot seem to get the TV to come back on (no green light) The red light comes on for a few seconds then goes off and then back on again etc. Please can anyone tell me how to unlock the TV or where I can download or buy a user guide for this model TV?
  • Geoff Stamp Jun 08, 2007
    Replacing the faulty remote controller did the trick. When in standby mode it appears that the only way of turning the TV on is by the use of the remote control. No sequence of button pushes/holds using buttons on the actual TV work.
4 Suggested Answers
  • 182 Answers
SOURCE: Thomson 27" LCD TV 27LCDB03B
cannot be presise but at worse the lcd back light is failing or the supply to it . this is a job for a service engineer
Posted on Jun 11, 2010
SOURCE: Thomson 27 LCDB 03B
when i turn on my tv the light turns orange green for a few seconds.
Posted on Jul 23, 2010
  • 182 Answers
SOURCE: my Thomson Intuvia 32 does not turn on?
i think you have a fault in the standby power board.
a kit is availalable for this and can be obtained from www.tvs-services.com or cal 01245392539 monday to friday 9 to 5
Posted on Sep 03, 2010
Thomson 27lcdb03b picture upside down
I would suspect main board more than one you replaced--not likely to get help as Thompson is not known for that--possible firmware upgrade seems likely.
On every set I have seen with upside down/inverted or reversed screen etc it has been either a firmware issue or a main board.
Jun 07, 2012 | Televison & Video
I have a Thomson 27LB130S5U TV - have connected to my laptop with a VGA connector (both ends) but no picture coming through to the TV. Same laptop with a different TV no problem. Am I missing something?
It is possible that the VGA interface in the Thompson TV could be deffective. You will need to check for any break in the connectors, bend pins or within the printed circuit board. Since the TV is working fine there is a possibility only to find such a break or a failure of the VGA interface IC. Take help to make a test before you can replace. Hope the selection on the thompson was selected to VGA and still you did not receive the signal Please check this out. Good day
Aug 03, 2010 | Thomson LCDB 03B 27 in. Television
Thomson 32" flat screen periodically switches on and off very qui
the standby power supply is probably faulty . there is a service kit available but needs to be fitted by a tv engineer and is available from www.tvs-services.com or call 01245382539
Jun 04, 2010 | Televison & Video
My Thomson Intuvia 32 does not turn on?
Feb 19, 2010 | Thomson Televison & Video
28VK25US Thomson tv, install menu comes up each time switched on.
My Thompson TV only works on av3 thus I cannot get discs to
accept as this has to be on av1 how do I tune in?
Jan 28, 2010 | Thomson 28VK25US TV
I have a LCD TV THOMSON 32lb040s5, the problem is that the TV start and turn off again and again when I start it
you probably have a fault on the stand by power board.
this normally requires soldering and maybe some componet changes. This is not a job for the unskilled. best carried out by a service engineer(shock hazard)
there is a service kit for this available from tvs-services.com 012453925
Jan 18, 2010 | Thomson 32LB130S5 32 in. LCD TV
Thompson DTR remote codes
Try these two codes the first worked for me 1368 or 1994 best of luck
Nick
Nov 14, 2009 | Televison & Video
Thomson 32WZ610s television stays in standby
It the power inverter supply board 90% of the times.Very comon with LCD tv's design flaws in power inverter boards.Many,not all use the
same designs.
Aug 24, 2009 | Televison & Video
UNABLE TO GET OFF STANDBY
It's now working I went to http://www.topuptv.com/help+centre/setup+and+troubleshooting/Fail+boot+up its working after the 13th attempt lost all my recordings though.
May 03, 2009 | RCA Thompson DVD Recorder
Thomson 20LCDB03B 20 in. Television Logo
50 people viewed this question
Top Thomson Televison & Video Experts
 Grubhead
Grubhead
Are you a Thomson Televison and Video Expert? Answer questions, earn points and help others
