Question about Maytag Centennial 3.2 cu. ft. SuperSize Plus Top Load Washer
Maytag continental washer not filling up with water
When machine is started it just buzzes but no water comes out. I've checked the water supply which is good. Moved it to both hot and cold but still no water comes out.
4 Suggested Answers
  • 1294 Answers
SOURCE: Maytag washer model lat2914aae washer
Click on your model number (below FIXYA) on this website, & search. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, you have your manual on line. If available that is.
And dont forget to rate me on this great site!
Posted on Jan 30, 2008
  • 37 Answers
SOURCE: Maytag Legacy Series Top Load Washer model
Have you tried cleaning out in and around the inlet on the washer (where the cold hooks into the washer)? We had the same problem. When I removed the cold water hose, I cleaned out the end of it and the inlet on the washer-there should be a small screen on the washer side. It does it on cold because with the hot, a hot water heater filters most of the debris out of the water before it comes out and the cold water is not filtered. Hope this helps!
Posted on Apr 03, 2009
  • 3741 Answers
SOURCE: Maytag Performa wont fill hot water
The water fill valve - The water fill valve is a mechanical and electrical part, the coils on the valve need electricity to mechanically open the valve to allow the water to flow into the washer....myth....the washer pumps water into itself...no, it does not. The fill valve opens and the house water pressure pushes the water into the washing machine.
No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can test a fill valve live for 120 volts, power to a fill valve coil and no fill = a bad fill valve. You can also test the coils for continuity, no continuity = a bad fill valve. Some Maytag washers have a fuse in the fill valve circuit, if this fuse let go the washer will not fill. Fill valves can also from time to time stick open and not stop filling. If you have to shut off the fill valves to stop the water from filling in the washer, you have a bad fill valve and you will have to replace it.
Posted on Nov 27, 2009
Washer buzzes and won't agitate or spin. Only will fill with water.
Almost certainly with that sound, the motor start capacitor has failed. It will be located either behind the control panel, or underneath next to the motor.
Dec 17, 2013 | Maytag Parts Washing Machines
Kenmore washer Model A107 is pouring water out from underneath
More then likely it is the dis-charge water from pump hose. But if ya got a new machine why not!
Feb 16, 2013 | Washing Machines
Maytag washing machine no water coming in
check water coming out of hoses. check on hot and cold fill. could be fill valve
Feb 09, 2013 | Maytag Legacy MAV208DAWW Top Load Washer
Maytag top loader not working
check water supplys okay and lid closed properly to activate lid switch....
Jul 01, 2012 | Washing Machines
Hot water is not coming out
I would set the machine to fill on hot water and listen for a buzzing sound. If you can hear this and no water is coming out then your valve is bad and will more than likely need replacing. In some rare cases you can remove the water lines and clear some sediment that could be possibly blocking the water from flowing. If there is no sounds then you've got a control problem or a temperature selector switch issue.
Jun 19, 2012 | Maytag Washing Machines
My Maytag Top Loading Washer stopped filling up with water at the rinse part of the cycle. I have changed the fuse and there is still no water coming in. I've taken the hoses off at the machine and...
Usually at the rinse cycle their is only cold water that comes in.
Now witha a model number i can be more percise.
First try and see if you put your selector at cold at the beginning of the cycle and you d'ont get waterthen thier is a good chance that your water valve is defective.
Good luck
Jun 18, 2011 | Washing Machines
I have a Maytag Neptune Model #MAH5500BWW, and it leaks water only while it's filling. It's almost like it would rather fill my floor than the tub. When I start a spin only cycle to get the water...
Sounds like a leak either in the bottom, connector or water valve for your water inlet line. Visually finding the leak is your best bet, then you know what parts are to be replaced.
May 26, 2011 | Maytag Neptune MAH5500B Front Load Washer
Maytag Centennial 3.2 cu. ft. SuperSize Plus Top Load Washer Logo
115 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
