I CANT GET CH03 OFF MY TV SCREEN
I HAVE TO HAVE TV ON CHANNEL 03 TO WATCH SATELITE BUT NOW CHO3 SHOWS ON BOTTOM RIGHT NOW DO I GET RID OF IT
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
If from the set only the original remote on some models will have a 'display' button which should remove or call this up.
Posted on Nov 04, 2012
  • 89 Answers
SOURCE: channel display
the option is usually in the menu or controlled by "display" button on the remote
Posted on Aug 06, 2007
Buschchris1
  • 474 Answers
SOURCE: Game setting on a Sylvania TV
Most T.V.'s will let you use the front buttons, keep going down to zero and it should go through them. if not ( becasue i know some just roll over) try getting into the menu settings and it might be in there.
You best bet, go to ciruite City or best buy and get a $20 universal remote, check the back and make sure you t.v. is listed as one of the models it can be used on. This is a cheap quick solution. T.V.'s use infered beams to transmit, so there all the same, just different in its signal range. each brand usually has there own that they stick with so you just get the remote, program it according to the instructions and it should work.
Posted on Feb 19, 2008
  • 21 Answers
SOURCE: input problem
If you have the original remote, hit video, source, or input button, if it dont have them, then try to change the tv to channel 00 (zero or zerozero), if not then the channels might have to scroll to it, from channel 02 down to make it loop, if it goes to the next highest channel, then you need a remote. It may be set in the menu options to have the video source not saved to your list of saved channels. when you scan the channels, the tv might not look for the A/V source (audio / video), maybe just the RF source. The 3 DVD RCA wires are 1 video and 2 stereo, one stereo for left and one stereo for right. The TV has only 2 , 1 for video and 1 for mono 1 channel sound. This wouldnt have anything to do with why you cant use the DVD player. but try that with the original remote (or a universal remote that is set to your tv set that has either video, input, source or something similar. It is what tells the tv to change from the cable source (RF) and the AV source (the Red White and Yellow plugs, in your TV's case, 2 plugs, one yellow and the other either red or white or something). Dont really know how to explain it much more but hope it helps.
Posted on Jul 26, 2008
SOURCE: white westinghouse tv model wtv-1903
The display button on your remote should remove this.
Posted on Oct 23, 2008
  • 259 Answers
SOURCE: Can't turn on T.V. @ sign comes on.... next to Channel #03
front panel lock has to be unlocked with original remote....try mrremote.com punch in model# ..........good success...........Meder's tv service
Posted on Aug 10, 2010
I have did the auto scan and the tv screen is still blank. i need some answers asap please!!!!!!!!!!
does a DVD player work on the unit?
if so, be sure you have good connections of your input cables (and you know these connector cables to be good), then see if you can manually program channel 3, or any other channels programmed manually. I suggest channel 3 in case you are using satelite or cable box. Then turn the cable or satelite box & see if you get reception on channel 3.
Apr 01, 2014 | Televison & Video
Error message on screen that says PO 1.15 V100
The error is likely to be from the satellite as the set model listed does not have that kind of error.
Nov 29, 2012 | RCA P52926 52" Rear Projection Television
My tv has to be on ch 03 to watch satelite but now CH03 is on the screen how do i get rid of it
With the original remote you would hit display, if no display on this remote you are out of luck. Sooner or later if display up all the time it will burn that image into the screen.
Nov 03, 2012 | Radio Shack (15-2147) Remote Control
Sanyo 13 or 14 inch TV, C 03 shows on the screen, how to remove
i can't able to oscillate the horizontal output of sanyo tv model no. ST-14se1 tho power indicator keeps on blinking only what component should i consider to replaced?
Sep 30, 2009 | Televison & Video
I am getting a blue screen. It is hooked up to a satlite and is on the same channelas the satlite box. What am I doing wrong?
If the TV is usually viewed on channel 3.
On the remote control (original RCA TV remote) manually enter the digits 0 and 3 -the tv should display 03 and work - if this dosn't work plug three wires from the back of the satellite box which say out to tv - video and audio left right. plug the othe end to video/audio input 1 on the TV (matching the colors then press the video (or source button ) on the remote. Be sure the satelite is on (green light is on)
Sep 26, 2009 | RCA TruFlat 27F520T 27" TV
Feb 21, 2009 | RCA 27F530T 27" TV
SANYO MODEL DS27510, CHANNEL DISPLAY IN CORNER WON'T GO AWAY.
If you can program a Comcast remote or another universal remote that has an info key, you can get rid of it. I just succeeded in programming my comcast remote thanks to Dave Taylor:
http://www.askdavetaylor.com/how_to_program_comcast_cable_remote_control.html
Once the remote is programmed, hit the "info" button and watch your frustration disappear!
Dec 05, 2008 | Sanyo DS27510 27" TV
Cant get channel 03 off my scene of my tv
I dunno but i've got the same problem.. no matter what channel i'm on the green c03 or whatever stays up there... it's annoying.
May 08, 2008 | Sanyo DS31590 31" TV
Channel display
Aug 06, 2007 | Sanyo DS27800 27" TV
Televison & Video Logo
93 people viewed this question
Top Televison & Video Experts
Electro Med Services...
