Question about Rival Electric Food Slicer 1101G
Kenmore 67704 stopped
Operating then stopped suddenly. Blade will not turn
Why did it suddenly stop cutting?
Please provide the model of your machine.
Ok, it's a serger. Wondered why a sewing machine would be cutting unless it had the cut-n-sew accessory.
Most likely the blades are damaged or malfunctioning. Is the blade still moving when it is stitching? Is it just chomping away at the fabric but not cutting? If so, either or both blades need to be replaced. Consult your owner's manual. Usually only one blade can be installed without any technical knowledge. You can probably order the replacement blade and install it yourself. However, the other usually needs to be replaced by a knowledgeable technician because it requires some precision.
Has the blade stopped moving at all? If so, how long has it been since a thorough cleaning and oiling? Take it for service.
Mar 25, 2016 | Elna Sewing Machines
While mulching leaves mower suddenly stopped. I turn the key and nothing. Any ideas?
A riding mower has an interlock that prevents starting if no one is in the seat or if it is in gear or blade is engaged. Check these interlock switches. One of them may be shorted. Sometimes, the way they work is to kill the engine by shorting out the ignition. Other systems may prevent the starter from operating.
Nov 30, 2015 | Garden
Blade stopped
I feel you have a broken shear pin in your drive pulley. With the engine shut off see if you can turn the blades by hand with no or little resistance. If you can you have a broken shear pin and the pulley will need to come off and a new pin put in.
Jan 02, 2018 | Garden
MY ROCKWELL 10 INCH TABLESAW SUDDENLY QUIT WORKING. IT TRIES TO COME ON WHEN I HIT THE START BUTTON, BUT BLADE TURNS 1/4 INCH THEN STOPS. CONTACTOR STILL HUMS THEN THE BREAKER TRIPS. PLEASE HELP!!
If the blade turns freely by hand,check the motor brushes.Most high quality power tools have easily replacable brushes,and they usually only cost a few bucks.
Sep 15, 2012 | Delta Saws
Unit makes a loud rattling noise when operating
Hello, most likely the fan blade is either loose or cracked at the hub causing the blade to hit the fan shroud. You will either have tighten the fan blade or have to get a replacement.
Jun 20, 2012 | Kenmore 71121 Air Conditioner
My Skil Worm Drive Skilsaw Blade stops when cutting
If the blade stops it could be from a loose hex bolt, flanges missing or you have a gear problem. UNPLUG tool and check the blade first. I would remove the fill screw on the gearcase and see if the oil has metal shavings in it, if it does the gears are worn allowing the blade to slip. If not I would recheck the blade. Did this suddenly happen and if so what did you do prior to your problem
Mar 12, 2012 | Saws
Honeywell digital thermostat stopped working
Sounds to me like you have a low voltage short. If the stat had no display until you installed the battery means there was no voltage for the stat to work. Putting the battery in proves the stat works, no motors turning on probably leads to a blown low voltage fuse generally a blade fuse on circuit board in indoor unit. Good Luck
Jun 11, 2009 | Honeywell Programmable Thermostat Heater
Rival Electric Food Slicer 1101G Logo
116 people viewed this question
Top Rival Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Ric Shull
Ric Shull
Level 1 Expert
Craig Butler
Craig Butler
Are you a Rival Kitchen Appliances - Other Expert? Answer questions, earn points and help others
