Question about Panasonic Lumix DMC-FZ7 Digital Camera
Panasonic Lumix DMC-FZ7 Digital Camera lens problem
Think i hit the lens is there a way to fix it myself with a new lens ? ..
Is there a long lens for the Panasonic DMC-F27?
Camera is currently equipped with a Leica 12X zoom lens. I would like to be able to take pcs. from a greater distance than this lens permits. Can you recommend a lens that I can attache to the Panasonic DMC-F27 that will enable me to do so? Thank you!!
Apr 14, 2013 | Panasonic Lumix DMC-FZ7 Digital Camera
Picture not focused at 12x zoom
It's probably something to do with a lag or jam on your shutterspeed. so when you hit the button, and move you get a little blur. If its not this you might need to have your lens cleaned inside and out due to the camera zooms and catches the blurs on the lens after zooming so far in. I would recommend taking it to your local camera shop for adjustments and cleaning.
Sep 19, 2007 | Panasonic Lumix DMC-FZ7 Digital Camera
Panasonic Dmc lumix fz7
Did you lose your button?, Or are you new to the camera and need instruction aon how to use it?
Apr 25, 2010 | Panasonic Lumix DMC-FZ7 Digital Camera
DMC-FZ7 Panasonic digital camera won't focus when zoomed
Your camera focus problem mostly deal with machanical parts. So changing them easily will solve the problem. But unfortunately you may not do it yourself. Because it is highly complicated process. In deed it needs lots of repairing devices which are found only in services. According to me the service had given you the best answer. Please accept their advice. Good luck.
Mar 04, 2010 | Panasonic Lumix DMC-FZ7 Digital Camera
Optical zoom and flash not working on Panasonic DMC-FZ7
None of what you describe sounds good. Any chance you can get your money back?
Dec 08, 2009 | Panasonic Lumix DMC-FZ7 Digital Camera
Flash not working on panasonic lumix fz7
Go into menu, setup function, turn OFF "conversion lens" or anything like that. NOTE: a conversion lens is a lens that screws onto front of lens of your camera and the flash would get blocked by it, so there is a function in the menu that turns the flash off when a conversion lens is attached to the camera. If this works, STOP PLAYING AROUND WITH THE MENU TILL YOU READ THE MANUAL. LOL.
Sep 24, 2009 | Panasonic Lumix DMC-FZ7 Digital Camera
Lumix DMC-FZ7 won't flash
Thank you anyway, but I am going on tomorrow to buy a new camera.
Searching the web now for the best kind and in my price range.
Thank you again.
Jun 18, 2008 | Panasonic Lumix DMC-FZ7 Digital Camera
Replacement lens cap for Panasonic Lumix DMC-FZ7 digital camera
Please see below for a link to the Lens Cap with String. This is an original part direct from Panasonic. Used specifically with this camera.
Lumix DMC-F27 Lens Cap with String
Mar 26, 2008 | Panasonic Lumix DMC-FZ7 Digital Camera
Panasonic Lumix DMC-FZ7 Digital Camera Logo
96 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
