Question about Roland GX-24 Vinyl Cutter
My gx-24 is not responding to my laptops commands, im using windows vista and have installed the drivers, this was checked and my computer says it is installed and working correctley but no joy when i
In the print status ive noticed that the heading "Page" seems to be saying there are multiples of the single item im trying to cut and it just seems to keep clocking up the page numbers in thousands.
Bootmgr is missing plz slove this problem
Need install disk to enter recovery console
http://techblissonline.com/vista-recovery-disc-download-and-create-to-recover-windows-vista-32-bit-x86-and-64-bit-x64-editions/
Vista's System Recovery Console
First, Boot from your Vista installation CD.
Select your Vista Install from the list in Windows Boot Manager
· Microsoft Vista Setup (x86)
· Microsoft Vista Setup (x64)
Press enter.
You will then see Windows is Loading Files.
Next, the Language Screen will come up. Since you have already selected this option when you installed Vista, just click on Next.
Now you will see the Vista Installation Screen.
DO NOT CHOOSE Install Now
Instead, towards the bottom left of the window you will see.
· What to know before installing Windows
· Repair your Computer
Choose and click on Repair your Computer
You will then come to the System Recovery Options. Choose Microsoft Windows Vista from the list. Then click Next.
You will now have the option to choose which Recovery Tools you wish to use.
This list provides details to the five tools that can help you repair your Vista installation. These tools are:
1. Startup Repair
Automatically fix problems that are preventing Windows from starting:
Startup Repair is an automated repair process that scans your Vista installation for problems and attempts to automatically fix them. When you select to repair Vista from the Vista setup screen, and Vista detects problems, this process will be started automatically. You can cancel this process at any time to access the other repair tools described below. The Startup Repair process has already been introduced above when we discussed performing an automated repair.
2. System Restore
Restore Windows to an earlier point in time:
System Restore allows you to restore your computer's configuration, driver information, and programs to a previous state while leaving your existing data intact. Using this option can typically fix a installation's problem if it is not associated with faulty hardware. In order to use this option, you must have had System Restore enabled in Vista so that there are restore points available to restore to.
3. Windows Complete PC Restore
Restore your entire computer from a backup:
Complete PC Restore is a feature that allows you to restore your entire computing environment from a backup image that you created previously. The ability to create backup images for Complete PC Restore is only available in Windows Vista Business, Ultimate, and Enterprise. If you have tried all possible steps to repair your computer, and have a Complete PC Restore backup image available from when your computer was operating properly, then you can use this repair option to restore that image.
4. Windows Memory Diagnostic Tools
Check your computer for memory hardware errors:
Windows Vista comes with a diagnostic tool that allows you to check the memory installed in your computer for errors. This will allow you to determine if the actual memory (RAM) hardware installed in your computer is creating errors.
5. Command Prompt
Opens the Command Prompt window:
The Command Prompt repair tool allows you to open a command prompt that you can use to access the files and registry information on your computer. This is an invaluable tool for removing security threats such as worms, rootkits, and other malware from your computer and to be able to access files when Vista fails to boot up.
Command Prompts
To help get you started with using the Command Prompt. Here are listed a series of console commands that work in this environment. To get the help information for each of these programs you can type the program name followed by /h and press the enter key. For example, to see the help information for the copy command you would type copy /h and then press the enter key. As more programs and commands are found they will be added to the lists below. Each of the console commands must be typed into the console in order to execute them.
Console Command Description
Copy - Copy a file to another location.
Move - Move a file to another location.
Rd - Remove an empty directory.
Ren - Rename a file or directory.
More - Show the contents of a file one page a time. Typically used to read text/ascii files.
Type - Show the contents of a file all at once without pausing at each page like the more command. Typically used to read text/ascii files.
Xcopy - Copy a folder and all its contents to another location.
mkdir - Make a new directory.
Diskpart - Load the Windows disk management program. From this program you can create, delete, shrink, and expand your existing partitions as well as get information about partitions and hard drives.
Dir - List the contents of the current directory or the directory you specify as an argument.
Cd - Change your current directory to another one.
Attrib - Change the file attributes on a particular file or directory.
Del - Delete a file
Bcdedit - Displays and allows you to change how Windows boots up. This command is useful for people who are having trouble with the Windows Boot Manager.
Chkdsk - Scan your hard disk for errors and fix them.
Choose the above options that best fits your computer problems.
The first option (Startup Repair) will run automatically. And will fix or repair Vista’s MBR and check for any corrupt files and folders.
NOTE: This option will also remove any installed program(s) that could be causing Vista not to start, or run correctly.
Note: If you are running a RAID array, if this does not help and you are receiving errors. Check in your BIOS and make sure the BIOS did not convert back to IDE. Vista needs to see the complete MBR, In a RAID setup the MBR is split between two drives.
for xp
http://www.freedownloadscenter.com/Utilities/Disk_Maintenance_and_Repair_Utilities/HDHacker.html
copies for all versions
http://www.freedownloadscenter.com/terms/windows-7-fix-mbr/mbr.html
Imageburn
http://download.imgburn.com/SetupImgBurn_2.5.2.0.exe
Burn ISO CD instructions
http://pcsupport.about.com/od/toolsofthetrade/ht/burnisofile.htm
^^^^ HOW TO BURN ISO IMAGE
Oct 29, 2010 | Computers & Internet
C language is not running in full screen mode
Windows Vista takes away a lot of support and convenience for the sheer attractive of flashy user interface. One major feature is the ability of open full screen window for command prompt shell in Windows Vista. When you attempt open or run DOS .com applications, .bat batch scripts or games that relies on command prompt, and including cmd.exe itself, you will encounter the following error message:
This system does not support fullscreen mode. Choose “Close” to terminate the application.
The lack of support for full screen DOS command prompt in Windows Vista is a big annoyance especially for those who still playing games for DOS and Windows 3.1/9x era, use legacy software such as WPDOS or programmers who frequently switch to command prompt to use DOS based programming language such as PASCAL.
There is no simple solution to this no support for full screen window in Windows Vista. In almost all possible workarounds, you are almost guaranteed that your Vista will be broken in some way, at least on the part on Windows Aero. You will lose the nice Aero Glass interface if you attempt any of these trick, plus other unknown side effects.
Workaround to Run or Open Full Screen Window Mode
Workaround 1: Use XDDM driver instead of WDDM driver for video graphics adapter
In another word, install the Windows XP video card driver for use in Vista. If the video graphics card hardware supports Windows XP driver, you can download the Windows XP driver for your video hardware and install it under Vista. However, be warned that using XP driver on display adapter may crash your Vista system randomly, so save your works before proceeding and use with care.
Note: This solution has been recommended by Microsoft in KB926657.
To install a Windows XP video driver under Vista, just follow the procedure listed in the guide below. The steps should work for both NVIDIA and ATI video graphics accelerator card.
Download the Windows XP driver installer for your graphics card from NVIDIA or ATI. Run the installation setup program just downloaded. Confirm any User Account Control permission warning when prompted. The installer will first extract and unpack the files required by installation to proceed to a folder/directory. Note down the path to the folder. For ATI, the folder for these installation files usually located in a directory with a name that resembles C:\ATI\SUPPORT\7-5_xp_dd_46743\Driver or C:\ATI\SUPPORT\7-5_xp_dd_ccc_wdm_46743\Driver, with the only different been the number to indicate the version and build number of the driver
Jul 31, 2009 | Computers & Internet
Sound drivers
Please download from the link given below all drivers including sound drivers for your laptop :
http://esupport.sony.com/US/perl/swu-list.pl?mdl=VGNCR220EP&LOC=3#div_pos_5
Jul 16, 2009 | Sony VAIO VGN-CR220E/P Notebook
Cant get scanjet 2100C to work with Windows Vista
Unfortunately, HP doesn't support Vista for that scanner model.
However, some have reported success using windows 2000 drivers on Vista.
You can give the windows 2000 drivers a try here:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&lang=en&product=59554&
Be sure to unplug the scanner from the computer BEFORE installing the driver / software.
Jun 07, 2009 | Microsoft Windows Vista Anytime Upgrade
Optiplex GX520 with vista
There should be no problem, if the sound doesn’t work try uninstalling the the Drivers and Reinstalling after you installed Vista im pretty sure that Vista will install the Drivers automatically.
Jun 01, 2009 | Dell OptiPlex GX520 PC Desktop
V Sony NW-S205F
Check whether its compatible with Vista. Also if you are trying to use a "cracked' software in Vista, it simply wont respond to any command or recognize the devices its supposed to because Vista does not allow any extra drivers to be added other than those preset in the OS driver database....sodeep
Oct 25, 2008 | Sony Walkman Sport Series NW-S205F MP3...
Install Vista on Dell optiplex gx 260
The big problem you will ever face with Windows Vista using optiplex gx260 is the screen resolution...This is a great hurdle in the upgradation of Windows...You're also to keep in mind that there are some softwares which are not compatable with Vista like folder lock etc...So I'd suggest not to shift to Vista...XP is still the best option...allowing multiple tasks to perform securely, faster and without any compatability issue...Enjoy using Windows XP...
May 08, 2008 | Computers & Internet
Printer will not respond to Windows Vista
This printer model _does not_ have wndows vista support at this time. Check the manufacturers website for updates
http://www.lexmark.com/lexmark/sequentialem/home/0,6959,204816596_920309141_0_en,00.html
Feb 14, 2008 | Computers & Internet
Roland GX-24 Vinyl Cutter Logo
347 people viewed this question
Top Roland Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Debbie
Are you a Roland Craft and Hobby Expert? Answer questions, earn points and help others
