Question about Ovens
I have a rational oven in an emergency mode code 10 what does it mean
After instaling my used rational oven it said de scale I bought the pucks de scaled then it went into emergency mode code 10
2 Suggested Answers
  • 360 Answers
SOURCE: Temperature Display
Press and hold CUSTOM BROIL for 5 seconds. A
tone will sound and “°F” will appear on the lower oven display for
3 seconds.
A complete owners manual can be downloaded from
http://shared.whirlpoolcorp.com/product_literature/search.jsp
Thanks for using Fix Ya, please take the time to rate this solution.
clarkco
Posted on Feb 07, 2009
My kitchenaid works fine however I have hit something and when I press the bake button it shows 180 degrees instead of 350 all of a sudden. How do I reset it? I tried shutting off the breaker but that...
you neglected to mention the model this is , but most of the ovens made by them , when switched to bake , 1st show the temp you adjust then after thrirty seconds or so show the actual temp of oven (this number will change) the set temp function can be adjusted to anything in the ovens heat range 100-450) using the arrow keys anytime in the bake cycle , just touching a arrow key will change display to set temp screen , from actual temp display
Mar 07, 2015 | KitchenAid Ovens
My rational combi oven keepwanting a gas reset when not in use why is it happening all the time
It looks like one or both (62G) or the three (201G) gas burners fail to light. You may want to check you have gas supply at the correct pressure. If you do, next is to check the gas valves, the ignition electrodes, the gas blowers, and the flame sensors.
Mar 06, 2012 | Ovens
My rational selfcooking center says service34-2- no function please help
You really need a specialist repairer to resolve this but this generally relates to a main fan motor defect or a failure elsewhere in the bus circuit.
Sep 03, 2011 | Ovens
How to turn fan to oven
First of all, here is the main DACOR ONLINE SUPPORT page for your model:
http://www.dacor.com/Our-Products/Wall-Ovens-Single/Distinctive-Single-Wall-Oven.aspx
And here is a direct link to the ONLINE USER'S MANUAL for that model:
http://www.dacor.com/WorkArea/showcontent.aspx?id=18137
To view the Support Page or the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents.
You can download this free at WWW.ADOBE.COM if necessary.
Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
See page 10 of the manual for detailed instructions on how to use the various cooking modes of your oven including the convection fan feature.
I hope that was helpful to you, good luck.
If you choose to rate this solution using the Thumbs Up scale provided, I thank you very much for your time and consideration.
Joe.
Jun 13, 2011 | Dacor DO130S Oven
My power went off today and when it came back on, my Kenmore oven shows error code "PF 5 AB". None of the buttons work that I press. Burners turn on, but can't turn on oven. Suggestions?
Could that be PF power failure 5AB in the Sabbath mode. That's a new one.
Your model number is useless. Sears has a big 3 digit product code followed by 8 digits.
But let me dig up my 5AB notes:
Here is what I have:
To
provide sabbath feature (or to cancel this setting):
1. Push the PREHEAT pad and set the oven
temperature to 500°F/260°C or more using the UP
ARROW pad.
2. Push the PREHEAT pad within the next 2 seconds
for 3-4 seconds. A beep sounds and a number
appears in red to the right of the display. For the
conversion, "3" must be displayed. If another number
is displayed, push the PREHEAT pad and select
"3".
3. Push the UP or DOWN ARROW pad to change
from 12 hour to 9999 in the display, for no 12 hour
shut-off.
4. Push the CANCEL pad to confirm your choice.
Other Displays:
When proceeding through steps 1 and 2 in the
Temperature Scale Conversion or in the elimination
of the Sabbath feature /12-hour Shut-off time limit,
two other words can be seen in the display. One is ESC
with O in red. It cannot be changed. The other is USE or
SALE with 3 in red. This one is for factory use and should
stay on USE.
Hope this helps
Mar 19, 2011 | Kenmore 40494 / 40495 / 40499 Electric...
Cooling fan seems to be making a very loud noise , is it easy to replace
on a scale of 1 to 10 / it's a ( 7 ) / takes about 1 hr . and helper for wall oven . .
Jul 13, 2010 | Hotpoint SY36 Style Line Stainless Steel...
I bought an oven thermometer and it indicates that the oven temperature is approximately 100 degrees lower than the temperature set on the oven. Is there an adjustment to make so the set temperature is...
It sounds as if an element in the oven is not working do check again that the oven thermometer is on same scale as the oven settings farenheit or centigrade.Most likely it is an element fault.
Hope I helped.
May 07, 2010 | GE Profile JT915 Electric Single Oven
Rational combi oven service manual
Alarm beeping control board not working
Apr 28, 2010 | Ovens
Temperature Display
3 seconds.
clarkco
Feb 06, 2009 | Whirlpool GBS277PD Electric Single Oven
Ovens Logo
350 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
