Question about Linksys Wireless-G WRT54G Router
Network has suddenly dissapeered
Hi. I've had my linksys wrt54g router for about 2 years now. I have a Dell Desktop, Acer Laptop, and recently added an Xbox 360 about 2 weeks ago on to the network. Everything has been working fine, but yesterday my network basically dissapeered, and all 3 have lost connectivity. I cannot find my network when I search for nearby networks in range. Whats funny is that I can connect my computer wired into the router and everything works fine.
  • Linksys Master
  • 6,487 Answers
This is just a problem with the wireless settings of the router, you can try first to reset the router by pressing the reset button for 20 seconds while power is ON and then after that you should be able to find the default wireless name of the router which is linksys, after you reset the router just need to reconfigure it back...
Posted on Jan 04, 2009
Router upgrade?
A new router is just one piece of the network. The components work with one another and depend on ALL the components working in harmony, you might say. One piece will not guarantee improvement in a network. Do more research, what are the Network adapters connecting? What is my ISP speed, remember, your speed will differ, sometime greatly for advertised ISP speeds. The factors are infinite, unknown, and sometimes out of your control. That said if you are using a 802.11 N or AC Wireless in your Home Network, depending on the Computer, Printer, etc. Network Adapters, etc. I use 3 different Access Points, 2 Linksys wrt54g's, 1 wrt160n , all with different SSID's and channels, connecting to 2 printers 2 Laptops, 2 desktops, iPad, Smart HDTV/Netflix, Phone, all work quite well. As I move about the devices will switch to the best signal. Remember the old saying, "If it ain't broke, don't fix it". But I always try, with different levels of success . You may learn a new way not to do something, I do. Some people call it a mistake.
Apr 30, 2013 | Computers & Internet
Need to find ssid number for my Linksys Wireless-G WRT54G Router
This Utility program will help you locate few details of your network like :
1. SSID ( network name )
2. WEP/WPA Key ( Your network security key )
3. The PC/Laptop IP Address
4. Router IP address
5. Which all Devices are connected to your Router/Network Wireless
6. Which all Network are available nearby your place
7. Let you access the Router Configuration
Click here to Download the HP Network Diagnostic Utility
Download the file on Desktop and Run the program ( Ex. File name = HPNDU.EXE )
Follow the Instructions on the Screen and do accordingly
* Please rate this solution with Thumbs up and comment to help us improve providing support
Nov 12, 2010 | Linksys Wireless-G WRT54G Router
My WRT54G router has been functioning flawlessly for three years... until today. All of a sudden, neither my laptop nor my Blackberry don't see the wireless network... although the 2 PCs that are...
If you have a modem unplug it then unplug your router, wait for 2-5 min then plug in your modem then router. It always seemed to work for me. If it dont work call Linksys.
Oct 15, 2010 | Linksys Wireless-G WRT54G Router
Network/router problem
Is your router wep or wpa encrypted if so you need to put that wep key into your new laptop so you can connect to it.
Oct 17, 2009 | Linksys Wireless-G WRT54G Router
My Dell laptop won't connect with my Linksys G wireless router
First check in your laptop wi fi switch is turn on if you have laptop.
Then check in computer that wi fi network adapter driver are installed correctly and enabled .
You can check it in my network places right click on it thne go to proeprty then you see there wi fi network driver then enable it.if disable.
Then you can see search for available networks.
If not works then post here so i give you assistanse for router configuration.
Let me know if you need more assistanse.
Aug 31, 2009 | Linksys Wireless-G WRT54G Router
Need to setup Laptop wirelessly thru Linksys WRT54G
The default password of Linksys device is admin without username.
Jun 06, 2009 | Linksys Wireless-G WRT54G Router
Linksys router problem
Try a factory reset on the router, in most cases this can be done by holding the reset button on the unit down for 10 or more seconds. Once this is done you may have to enter any settings into the router again.
Also, try download the latest firmware from and upgrade the firmware on the router.
Dec 08, 2008 | Linksys Wireless-G WRT54G Router
Cannot connect to WRT54g
think you have to connect a cable to the ethernet adapter of your desktop in order for you to connect to the wrt54g. uless you have a wireless lan on your desktop. also check your channels. and manually config your router through
Aug 31, 2008 | Linksys (WIFIDESKTOP) Wireless Adapter
Connecting WUSB100 to Wireless G WRT54G
laptops have a wide range reciever built around the screen and tend to be far better than a normal usb dongle.
The fact that your pc is downstairs will be effected a lot because the signals from the router will be bouncing around in an area around the antenna and above, signals below will be effected by floors, doors and wall partitions.
Your best solution would be to place the router on a phone line downstairs and see if the signal is increased.
Aug 18, 2008 | Linksys WUSB100 Wireless Adapter
Linksys Wireless-G WRT54G Router Logo
101 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
