Question about Telex AUDIO DUPLICATORS: Mono 1-2-3 Single Dual Cassette Deck
Replaceing Fuse in Telex Acc-4000 tape duplictor
No power when turned on Can not find location of the fuse (1.25 slow blow)in Telex Acc-4000
Where can i find Telex ACC 4000 manuel plz urgent
Posted on Mar 13, 2008
Ea falcon turn ign on to acc blows wiper fuse
sounds like a direct short in the wiring between the fuse and the wiper switch
Aug 18, 2014 | Cars & Trucks
How do i modify the telex acc-4000 to run at slower speeds?
Generally either inside the drive motor or on the circuit board where the motor draws it's power will be a speed preset. You can adjust the speed of any deck with this. If it's on the motor you will see on the underside of the motor a small slot. Inserting a screwdriver in that should adjust it. Sometimes a sticker has been placed over the speed slot to prevent people fiddling with the speed.
Jun 01, 2014 | Audio Players & Recorders
Everytime I try to copy a tape, there's a big noise on the duplicate ones, even if the recording level is zero! I cleaned the heads with alcohol, but the problem remains. I have a TELEX ACC-4000. Many...
Is this a big bass hum?
Are you in the USA?
These are all mostly pretty old units by now but pro equipment none the less.
It's got circuitry problems but may be worth repair as I'm not sure anything like this is made anymore.
Sep 21, 2011 | Telex Copyette 1-2-3 Single Dual Cassette...
Need fuses for janome 4000
You can get the fuse at Radio Shack. Part number 270-1065. It is a 3.15 amp 250 volt slow-blow fuse.
If you replace the fuse and it blows again, you need a new A circuit board part number 829606005.
Nov 03, 2010 | Janome Memory Craft 4000 Sewing Machine
Driving down the road the s10 2000, died. Found that the 40 amp fuse was blown replaceing it and just keeps blowing, I cant find the short.
thats the hard part, if the fuse slows then how to locate the short , they make a short finder but its over $200,00, replace the fuse with a test light then start doing a visual inspection , look for any frayed or koose wiring that may have chaffed
Sep 07, 2010 | Chevrolet S 10 Cars & Trucks
3amp fuse is blowing.
Disconnect the yellow wire from the thermostat and tape off the end. Turn the power back on. If the fuse blows, it is not in your wire nor the compressor contactor. If the fuse does not blow, turn off the power, reconnect the wire, and replace the fuse. Then, disconnect the wire from the compressor contactor and tape it off. Turn the power back on. If the fuse blows, it will eliminate the compressor contactor coil and will likely be a "short" in the wire itself. The yellow wire goes from your T-stat to your air handler and from your air handler, it goes to the oudoor unit's compressor contactor.
Apr 07, 2010 | Weather King 10PJA2501AH Air Conditioner
My radio and cd player or lighter doesnt work. but my clock does.....what is wrong!
Change out your ACC Relay. It is located on drivers side behind kick panel in fuse box. It is Black and rectangular shaped. Check for moisture. Many times water comes off driver door Chanel right into fuse box. Open driver door look for holes in front panel. ACC Relay is under 10 bucks at auto parts store.
Jul 04, 2009 | 2003 Ford Escape
All 4 windows won't go down
_________________________________
Passenger Compartment Fuse Panel
Fuse Location: 11
Fuse Amp Rating: 10 Amp
Description: Ignition (START) - ON/ACC (window and decklid) relay coil and Police ON/ACC relay coil (Police vehicles only)
Power Distribution Box (Under Hood)
Fuse Location: 304
Fuse Amp Rating: Full ISO Relay
Description: RUN/ACC relay (windows and decklid) (police vehicles only)
Fuse Location: 602
Fuse Amp Rating: 20A Circuit Breaker
Description: RUN/ACC relay feed (windows and decklid) (police vehicles only)
Mar 26, 2009 | 2005 Ford Crown Victoria
Side A led volume indicator is low when duplicating tapes
This is not a PrintWise burner problem. I posted incorretly. Henry
Jan 29, 2009 | Telex PrintWise 2000i (2000I) Burner
Blown fuse 1.25amp Board pos. 1452
The main fuse should be a 4 amp fuse not a 1.25 amp.
Jan 26, 2007 | Philips 32PT6441/37 32" TV
Telex AUDIO DUPLICATORS: Mono 1-2-3 Single Dual Cassette Deck Logo
364 people viewed this question
Top Telex Audio Players & Recorders Experts
Ben Armstrong
Gerhardus Stroebel
Livewyre Studio
Livewyre Studio
Are you a Telex Audio Player and Recorder Expert? Answer questions, earn points and help others
