Question about Music
How to factory reset a Yamaha p155 piano - Music
  • 3 Answers
Turn off the p155 power.
Press & hold down the rightmost key (C7) while turning on the power. Once the power is On release the C7 key. It should reinitialize to the original factory setting
Posted on Nov 03, 2012
  • Kevin Nov 14, 2012
    Thanks that seems to have worked
  • Michael MacKay Apr 19, 2014
    Just did it on my DGX-650 keyboard and it reset to normal. Kept the bank settings as well!
Sustain Pedal works intermittently.
To start with always best to use the correct power supply these should be readily available from any good Yamaha store. Is the sustain pedal a Yamaha pedal? The plug end of the pedal connect a multimeter across the two connectors and set meter to show continuity. If there is no continuity press pedal, hopefully this will now respond. If not then the break is in the pedal. If meter idea works then it could be the socket on the keyboard, these can work loose on the pcb they are mounted to if they are used a lot.
You could open up the keyboard and look inside checking the solder joints on the socket or simply take to a Yamaha service centre.
You could also try a master reset of the keyboard, hold down the highest note whilst turning on, this will reset to factory default.
Let me know how you get on.
Nov 02, 2015 | Yamaha NP-30 Portable Grand Piano &...
Sounding a half step too high
Use the factory reset
Hold down highest white key whilst turning on
This should return to factory settings - pitch should now be back at A440
If you need to adjust then see page 19 of the user manual where it explains fine tuning.
Mar 14, 2015 | Yamaha P95 Digital Piano
How do I reset as some keys wont play
The reset procedure is to hold down the very top key while turning the keyboard on.
Once it clicks and starts up ( about 15 seconds) you have carried out a factory reset.
Jul 29, 2014 | Yamaha Used Arius Ydp140 Digital Piano...
How do i reset the keyboard to factory settings? It sounds really weird right now
You can normally reset Yamaha keyboards by holding down the highest note while turning on. If you want to do a full factory reset see below - remember this may delete all songs etc you have saved to the keyboard memory.
decdbba2-706f-4a8a-afd1-ac3a6264c7f4.jpg dcd670d5-cf98-45e6-87a4-0591820eb4ef.jpg 2c144414-99a6-4025-960d-eaef496036a3.jpg
Jul 20, 2014 | Yamaha DGX-230 Portable Grand Piano
Factory reset yamaha p85
1) Try a partial reset by holding down the last white key while turning the unit ON.
2) If you haven't recorded any performance(s), for a full reset, hold down on the last white key AND THE lst three black keys while turning the unit ON.
Dec 14, 2013 | Yamaha P85 88Key Portable Digital Piano
How do I reset factory settings on Yamaha p155
Turn off P155
hold top C key down (furthest white key on your right)
while holding this key down, turn on power,
keep holding key down for 3 seconds, then let go.
should default to grand piano 1 setting
Nov 14, 2012 | Yamaha P-155 Electronic Piano
Reboot instructions for a Yamaha YPG 625 piano? One fingered chords won't function, nor will the sequencer start from the keyboard. Thanks! ****
Read about initialization on page 61 of your user manual. This is a factory reset. There are two procedures there. If you don't have the manual download it here:
www.yamaha.com/yamahavgn/.../ypg_525_eng_manual.pdf
May 04, 2011 | Yamaha Sk88 Keyboard Survival Kit For...
Yamaha P155 wont power up, replaced power supply w correct one. Any ideas?
Double check the supply... it should be a PA301 which is 16 volt DC at 3.5 amps... fairly hefty one.
Download these schematics:
http://elektrotanya.com/yamaha_psr-1500_3000_sm.pdf/download.html
and
http://elektrotanya.com/yamaha_p-120_s.pdf/download.html
A lot of Yamaha have similar circuits between different models.
When you go to these links, scroll down the page looking for a small link "Get Manual". They will only let you download two a day without registering.
The first of these has the power entry on page 154... the second is on page 60. Both use the 16 volt power adapter. See if one of these schematics is not close enough to your unit to troubleshoot it.
Mar 26, 2011 | Yamaha P-155 Electronic Piano
Looking for music stand that fits on top of p120
These are sold online at Kraft Music
Yamaha WB53080R Music Rest
Replacement Music Rest for P120, P140, P155, PF500, PF1000
Jun 24, 2010 | Yamaha Music
Music Logo
1,589 people viewed this question
Top Music Experts
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
