I have a Carrier Weathermaker Model 58SXAO80-GG. I turned on the heat earlier and I could hear the unit start, but there was never any warm air coming through the registers. I looked at the unit and the little blue flame igintes when I turn on the unit, but no air is forced through the ducts.
  • Joe Troxtel
    Joe Troxtel Feb 08, 2013
    I am having the same problem. I have replaced almost everything on this furnace but still it won't light. I did figure out that I can manually light the pilot when the fan turns on and that will allow the main burners to light. the furnace seams to run normally until it gets up to temperature and shuts off normally. but when it comes tiem for it to turn back on and light, it wont' so I have to manually light it again. Sure would be nioce if I could get some suggestions on what the problem could be.
Heat exchanger replacement for carrier weathermaker 8000
After 18 years of service, it is not cost effective to just replace the heat exchanger. Go the complete replacement route. There may be a utility company incentive to do it.
Jun 06, 2016 | Carrier Weathermaker 8000 Gas Furnace 125k...
I have a weathermaker sxc 060- gg. Last year the heat would come on but not get that hot, this year the heat won't come on @ all, just blows cold air. I can smell a faint gas smell when I take off the...
The gas line has air in it, Turn the unit off, at breaker or unplug it. Bleed the air out of the gas line, It should take about 5 seconds to bleed. Tighten gas line, Plug or reset breaker and unit should fire.
Nov 22, 2013 | Heating & Cooling
Weathermaker 8000 not enough heat
Are the tips of the flame blue? You might need to adjust the air mixture sleeve on the burner.
Feb 05, 2013 | Carrier Weathermaker 8000 Gas Furnace 125k...
Where does the 3 prong inducer plug into? Carrier Weathermaker Model 58SXAO80-GG Serial 1490A02296
Hi, it would either plug into the circuit board/control board, or have a connector of the same, either male or female it would plug directly into. This is a 120 volt inducer motor. Look for the other end of the plastic plug.
Sincerely,
Shastalaker7
A/C, & Heating Contractor
Sep 29, 2010 | Heating & Cooling
I have a new home 1 yr and when the furnace kicks in, I am assuming the fan it makes a noise but as soon as the heat starts the noise is gone, could this be the furnace blower
Check by turning the unit off and turn the fan to on. Do you hear the noise now? The noise your hearing could be coming from your combustion fan assembly instead. Newer furnaces have a in-shot burner and are nosier than the old style of heater.
Jan 04, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
Knock Noise When Carrier Furance Starts Up
have the ac company check the actual blower wheel itself it may be slowly coming apart
Apr 20, 2009 | Carrier Heating & Cooling
NO HEAT???? freezing
go to the furnace, there should be a service switch on the outside of the unit.  make sure the door is on good, does the blower motor come on?
Nov 15, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Carrier Weathermaker SX model 58SX060-CC Blower runs all the time
Remove all power from the furnace, it is likely the brain in the furnace is need of being reset, from the battery replacement, why did you change the battery, was there an indicator telling you to change it?
Many times just removing all the power to the furnace will do the trick with a reset, if not let me know and we will go from there, but it sounds like the main brain is confused or bad, more likely confused, so try the power removed first.
Than let me know wbwill@sbcglobal.net
Oct 22, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
