Question about KitchenAid Kitchen Ranges
Kitchenaid superba range kgst307hbl6 smells like gas while trying to light oven. Ignitor bar glows, won;t reach temp
Sometimes late ignition, smell of natural gas throughout cycle. Never reaches temp.
SOURCE: KitchenAid gas range superba not reaching/registering right temp.
kitchenaid superba electric double oven "takes too long to heat up"
Posted on Dec 06, 2009
  • 3315 Answers
SOURCE: Amana AGDS902SS Gas Range Oven. Replaced ignitor.
Hi not that i can think of try google the range see if they have problem with this range
Posted on Feb 09, 2010
heatman101
  • 43501 Answers
SOURCE: KitchenAid KGRT607 - Oven won't light reliably, can smell gas.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Oven Problems Replacing the Igniter http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
Posted on May 15, 2010
marka19
  • 1430 Answers
SOURCE: Both oven glow bars stay
The problem is usually the igniter not reaching the correct amp draw .When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. Sometimes the igniter glows but still does not reach the correct amp draw to fully open the gas valve. The igniters are inexpensive and easy to replace. This video will walk you thru the correct procedure for testing an oven igniter. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
Posted on Dec 11, 2010
SOURCE: Oven will not reach desired temperature and slight gas smell
Just had same problem it was nice it waited until christmas dinner, all i did to resolve the problem was switch the upper broiler igniter with the lower one for the oven. I tuned on the oven & it fired right up i never use the broiler on my oven so itll buy me some time. So if you can get the broiler to light try that but i did have the same low temp. & the smell of gas. Good Luck
Posted on Dec 26, 2010
I have a GE Hotpoint stove/range model num 317B6641P001 that the oven will not ignite nor will the igniter turn on.
It sounds like the ignitor is bad...you will not or should not smell gas if ignitor is bad...gas valve is not supposed to open until the sensor by the ignitor has reached a certain temp. It's a safety feature. If you replace the ignitor, it should work like normal.
Jan 31, 2013 | GE Profile JGSP44 Dual Fuel (Electric and...
The oven seldom lights. Igniter is working, there's usually no smell of gas, burners and broiler are working properly, replaced dual gas safety valve with no help. When it does light, it won't maintain...
Just because it glows that does not mean it is not bad...
heatman101
Sep 07, 2010 | Maytag Kitchen Ranges
Jul 29, 2010 | KitchenAid KGRT607 Gas Kitchen Range
Kitchenaid KGRT507FWHO gas range not firing or not getting hot
your ignitor is either cracked or bad
gotto sears type in your modle numbber and look for ignitor in parts search reletivley easy repair
Oct 07, 2009 | KitchenAid Cooktops
heatman101
Aug 29, 2009 | KitchenAid KGRT607 Gas Kitchen Range
The oven of GE Profile range simply stopped igniting
If it is a ge it would have a glow bar ignitor, either a flat rectangle shaped or a round ignitor. That is want the problem is 95% of the time. It is pretty easy to do. The floor of the stove will come right out and it probably has two screws in the back corners you can see. Remove them and the floor will lift out and you can see the burner and the ignitor.
Jun 17, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven won't light on low settings (170), no trace gas smell.
Igniting bar located on the inside of the oven it is a rectangular piece with one or two screws. It is basically a heating element that also controls the gas. Change that ignitor and it should fix it no problem.
May 03, 2009 | Frigidaire FGF326AS Gas Kitchen Range
Always preheat your oven and let it cycle at least 2 times. Your unit may show 350 but the manufactures know that it is not 350. When it registers preheated, it really means that it is at an acceptable temperature to start cooking. If you think that it may not be calibrated correctly, your owner's manual will have instructions on how to recalibrate your oven. You will be able to raise or lower the temperature by + 25 degrees or - 25 degrees. As far as the gas smell, you will from time to time smell a gas smell with a gas oven especially if you are right at it when it ignites. If you are smelling gas when it is not in use then you should be extremely concerned.
Mar 14, 2009 | KitchenAid KGST307 Gas Kitchen Range
The oven doesn't work ,the ignator doesn't light up. no gas coming oven doesnt work. it wont ignite. i smell no gas coming in. burners work fine
ok try your broiler if it lights change the glow bar in the lower oven the glow bar acts as a safty if it doesnt reach a certain temp the safty valve wont alow gas to enter the broiler and bake are on seperate ignighters if neither work change the safty valve
Feb 11, 2009 | Amana ARGS7650SS Gas Kitchen Range
Burner flame shuts off during use and then you smell gas
all ovens, when they reach temperature they go off and on to kip the temperature, but if you smell gas the oven ignitor needs replacing, the ignitor gets red hot to ignite the burner ,but when ignitor does not get hot enough, it will have a delayed, that's the reason you smell gas.
Dec 10, 2008 | KitchenAid KGST307 Gas Kitchen Range
Kitchen Ranges Logo
65 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
