Question about Whirlpool WFW8300SW
Whirlpool (WFW8300SW) Front Load Washer heavy vibration
Have a 1 yr old front loader. Over the past 3 months, its become louder and louder, when spinning there is a loud banging coming out of the right rear (it seems).
Machine is level and firmly sitting on floor. If I push in on the right side or top, it sometimes goes away. It feels like something (of plastic, not metal) might be hitting the inside of the case.
This happens no matter how heavy or light a load is run.
  • 1 more comment
  • willie999 Jan 12, 2009
    Same problem. Repair guy said new bearings and inner tub. Repair exceeded the cost of the washer. Sorry.
  • Anonymous Feb 27, 2009
    I have the same problem with WFW8300SW, machine isn't even a year old. Repair man was here Feb.16, 2009 said machine needs a new tub. As of Feb. 27 they can't seem to find one. Part may ship March 6, from who knows where. I will NEVER buy another Whirlpool product!!!!
  • Anonymous Mar 21, 2009
    Heavy vibration and shaking. I found a copy of the Whirlpool service manual and disassembled the washer. The cross arm that supports the drum at the rear had a broken arm. Additionally, it has rubbed a hole through the front of the washer tub. Total cost for repairs from online parts sources is about 350.00. Whirlpool knows of the problem as per a phone conversation with their service line. No resolution from them. Good luck to all. Don't buy the Duet Sport Washer (WFW8300SW02)
catriver
  • 878 Answers
SOURCE: Whirlpool Duet Washer
dc, drop the front bottom panel and make sure the 4 shocks are connected to the tub and bottom panel, then check the front and rear counterweights. They may have loosened up. Remove back panel or top to check the rear counterweight. The top removes by removing the 3 screws in back and it slides off. If all this checks ok then I would suspect the rear bearing wollowing out. Catriver..post back.
Posted on Apr 02, 2007
  • 1462 Answers
SOURCE: Whirlpool washing machine
check that the machine ramps up to spin speed reasonably and distributes the clothes- ie doesn't spring straight up to spin speed. if this is ok then the fault may well be the shock absorbers located at the bottom of the machine and going from base to tub. check also that the counterweights are intact
Posted on May 09, 2007
Coldcut
  • 1554 Answers
SOURCE: Whirlpool LHW0050PQ Front Loading Washer VERY NOISY during spin cycle
remove the top access panel 3 screws in top rear.
now look around and push on the drum from top
it has suspension shocks and springs like your car they should resist any movements.
look/wiggle the concrete balance blocks , no cracks or loose.
inside the tub are the arm solid /not loose.
run it with the top open what do you see/hear and where
look under the rubber flap in front did anything get under the tub
Posted on Mar 04, 2008
  • 3 Answers
SOURCE: Whirlpool Duet Washer (GWH9100LW1) Bangs Loudly during spin
I have a Kenmore which is the same as the Whirlpool. I dismantled the unit, it was only 3 years as Sears stated its was not under warranty. Upon review the stainless steel tub tripod assembly which is connected to the flywheel was cracked in three places which caused the knocking and vibration. Even though the warranty states lifetime on the Stainless steel drum, there is a ploy on words as the failure was not the stainless steel, so these machines are good for the scrap heap as the cost to replace the parts is more expensive than a new washer.
Posted on Apr 14, 2009
t00nz
  • 4738 Answers
SOURCE: Vibration during spin cycle - "walking" across floor
Front loaders are prone to vibration problems. Don't want to go into the technical details of why, but it's important that they're placed on very solid surface (preferably concrete), and checked that their feet have been adjusted so that the machine is level. Unfortunately, most people don't have a concrete pad for their washer. The next option to consider is to provide dampening of the vibrations. This can be done very simply as this one fellow demonstrates. The main thing to keep in mind with this solution is that it is merely trying to dampen the vibrations. Don't be too forceful in your own solution (think lightly touching the top of a vibrating tuning fork with your finger to stop the tone).
Posted on Sep 18, 2009
My 4 yr old Whirlpool Duet front load washer is leaking water onto the floor from the bottom of the machine. It seems to be coming from underneath or back, it is not coming through the door. It's not...
The most frequent place for a front-loader to leak is on the door connector boot. The boot connects the drum to the door. You can often remove it and replace it upside down and that will give you a few more months' use.
Jan 23, 2015 | Whirlpool Washing Machines
I bought the Whirlpool Duet to replace my old standard washer & dryer and I find that the wash time is longer than the old washer. Even the quick wash takes about 1 hour. Am I doing something wrong...
I assume from your comment that your old washer was a top loader. Yes, front loading machines typically have longer cycle times than top loaders. There are several contibuting factors... first of all, the wash action of a front load is to oscillate the drum back and forth as well as provide a slow tumbling motion whereas a top loader w/ agitator or impeller has a more aggressive action. The more aggressive action rolls and tumbles your clothes more often and therefore cleans faster. Also, because front loaders spin very fast (up to twice as fast as top loaders) to reduce the amount of moisture left in the clothes, they need to have balanced loads. They accomplish this by testing and rebalancing your load several times during each cycle before beginning to spin.
That was a long answer to your question- no, you are not doing anything wrong.
Good luck.
Jan 28, 2011 | Whirlpool Duet GHW9150P Front Load Washer
An extreme vibration in spin cycle. It makes the
Because front load washers are VERY HEAVY, they shake if you have a wooden floor. If your front loader sits on concrete and it still shakes, then you have to make sure all is balanced. If it still shakes, then inside the system there are shock absorbers that need to be checked.
Nov 12, 2009 | Frigidaire Affinity ATF7000ES Front Load...
Service light is on my whirlpool washing machine and won't allow the wash to start, can I override this as it's only 18 months old?
The main motor in the whirlpool front loaders has brushes. These will wear out eventually. Does the drum try and turn when a load is started? If not the motor deserves a check. 18 months sounds short but possible. Mine took 4 years to wear down.
Apr 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore front load washer that's noisy when it spins
on most kenmore front loader after some time the bearing start to wear and the washer will get louder and louder,it is a big repair job!-mike
Mar 23, 2009 | Kenmore HE2 Plus Front Load Washer
Washer vibrates during spin cycle
Front loaders have to be situated on solid flooring such as a basement or they will vibrate.
http://tclaundryrepair.com/
Feb 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
MAYTAG WASHING MACHINE FRONT LOADER, VIBRATION
Hi jill_perigo
I have a couple of question, 1. did you remove the block? 2. is the machine on a concret floor? 3 how old is your machine?
brent
Sep 30, 2008 | Maytag EPIC MFW9700S Front Load Washer
Whirlpool Duet Sport? Front Load Washer WFW8300SW
hate my duet sport also! You cant presoak in this machine, very little water to wash with, very noisy, and everything stinks when it comes out of washer. Mine also smelled like mold but i figured out if you pull out the little tray that holds the detergent it is filled with stinky black mold. would never buy again
Jun 18, 2008 | Whirlpool WFW8300SW
Whirlpool front loader staining..
i have the same washer and i am some times perplexed about stain that appear after washing> i always blamed colors tranfer from other items .I'll keep a closer eye and see if i can find any more. does your washer have any oders that bother you mine does. for the price i feel cheated
Mar 13, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool WFW8300SW Logo
375 people viewed this question
Dan Webster
Dan Webster
Sal De
