Question about Nokia E7 (16 GB) Smartphone
How to unlock that nokia e7 of f-secure ?
There has locked by f-secure so wolud you please tell how to ?
  • irvan_jordan
    irvan_jordan Jul 08, 2013
    my nokia e7 has wipe with f scure, how to unlock? serial number 354864040692320
  • dylan
    dylan Mar 11, 2014
    i have the same problem with mine can anyone help me please serial code is 354864045967164
  • 580 Answers
Default 4 Digit user code: 1234 or 0000Default 6 Digit Security code: 123456 or 000000Master reset code:1122
Type *#06# at the mobile screen to know IMEI no of your mobile.send the IMEI no to me and i will reply you with unlocking code.IF Problem not Solved SoPlease New Software install in the Phone Problem will Solved
Posted on Nov 04, 2012
  • 205 Answers
SOURCE: my nokia 1110i phone security code locked
plsae your iemi no , your country , your network reply
Posted on Jul 13, 2009
aledinesh
  • 7 Answers
SOURCE: Forget security code for Nokia 3110C
hello friend
as i know that nokia didn't publish their master code,,,,
as i found on internate that it's master code is 123456789,10
but it dosen't work on my phone
go to the repair center and ask for unlock...
or buy dongel your self and unlock programme too then unlock your self
gud luck
Posted on Nov 11, 2008
Murphybanton
  • 2004 Answers
SOURCE: need unlock code for nokia 2600c security code
What is your IMEI number? i will generate a master code for you.
Posted on May 29, 2009
SOURCE: i have locked my nokia 2626 security code please provide me with
please tell me security code nokia 2626, which serial no. is 353083024115650.at present time i use BSNL.
Posted on Sep 04, 2009
jibins
  • 67 Answers
SOURCE: Keypad locked with unknown security code
take the mobile to the nearest nokia service center. and tell them to reinstall the os of the phone. u can find the nearest nokia center from www.nokia.com
Posted on Apr 05, 2010
Need more solutions on how to reset my security code of a Nokia E7
How to Perform Soft Reset of Nokia E7 with Secret Security Code:
Soft Reset Nokia E7 is the recommended try for user who get problem with Nokia E7. Doing the soft reset will not delete any important data, it only will restore the setting files with ini extensions to default on. The default ini files is saved in Nokia E7 rom, so it will not deleted event you already doing the hard reset or format Nokia E7. Do the soft reset easily by Press *#7780# with dial pad to Soft Reset Nokia E7. Please enter 12345 for security code
Mar 23, 2014 | Nokia E7 (16 GB) Smartphone
Forgot my security code n i dont know how to reset it
Option 1, How to Hard Reset Nokia E7 with Software Menu:
  1. Turn On Nokia E7
  2. Go to Menu: Menu > Settings > Phone > Phone management > Factory settings > Delete data and restore
  3. Nokia E7 will ask the default security lock code is: 12345
  4. The rest will do by itself to master reset Nokia E7, this process will erase or wipe all important data
#Option 2, How to Hard Reset Nokia E7 with Hardware Button Combinations Key:
  1. Before doing the master reset and format Nokia E7, you have to backup any important data
  2. Battery Nokia E7 should full charge
  3. Turn Off Nokia E7
  4. Press and hold together: Volume Down Button key + Camera Button key + Menu Button key, after that continue with press Power Button (do not release the first three button)
  5. The process will do format to factory default Nokia E7
#Option 3, How to Hard Reset Nokia E7 with Secret Security Code:
  1. Make Sure Nokia E7 is already charge properly
  2. Turn on Nokia E7
  3. Press at Dial pad: *#7370# and wait
  4. Nokia E7 will ask for default security code, enter: 12345
  5. Nokai E7 will do format to factory default
How the Right Step to Flash and Restore Nokia E7 Unlock?
Have a good smartphone should know how to restore especially while the smartphone of Nokia E7 got problem. First step is do the soft reset first, if the Nokia E7 still get the problem, second try by doing the hard reset or restore to factory default with some options step above.
What should I do to Fix forgot or Lost Password of Nokia E7 Default Security Code?
If you never change the Nokia default security code is 12345, maybe sometime you every change the default security code and you forgot what you have change, in this case you have to go to nearest authorize service center for repair Nokia E7.
How to Restore Clean Setting at Nokia E7 Reinstall the Operating System?
Restoring the Clean setting of Nokia E7 can be done with doing the soft reset without delete any important data. If you want to reinstall clean operating system for Nokia E7, this can be done with doing the hard reset, but your data important will be deleted.
Help for Slow Respond Nokia E7, How to Make Nokia E7 Run Faster?
It will hurt to use slowly Nokia E7 smartphone, maybe it have a lot of applications or you ever try to setting the Nokia E7 with wrong way. This problem can make our Nokia E7 running slowly, so to make Nokia E7 run faster, you can try to do the soft reset and also hard reset. It depend on what the main problem with your Nokia E7.
How to Fix Forgot Nokia E7 Pin or Password ?
If you assign a pin or security password for Nokia E7 and forget about it, you have to do the hard reset of Nokia E7 with step above
The information from this page describe about nokia e7 hard reset,hard reset nokia e7,how to hard reset nokia E7,how to format nokia e7,how to reset nokia e7,e7 hard reset,hard reset e7,nokia e7 format code,nokia e7 hard reset button,how to unlock nokia e7 security code. If you need another resource for hard reset, use search function at this homepage or find from our related posts.
I want a unlock code for my nokia e7 my imei number is 354864044624543
Hi, it depends on what network and country your Nokia is locked to, check the unlocking service here: http://www.fastgsm.com/en/nokia/e7-00/network-unlock
Jan 26, 2014 | Nokia E7 (16 GB) Smartphone
I need to unlock mij nokia E7 i need to put everything on another simcard
You can unlock your Nokia E7 phone from Network lock using unlock code.Unlock code is the best and safest way to unlock phone. You can get the unlock code for your phone from your Network service provider or any third party online vendors like ClassicUnlocking.com here you need to specify your country, Network name to which it is locked, IMEI number of your phone. Then they deliver unlock code to you through mail with unlocking instructions. By using this you can unlock your phone easily.
Sep 15, 2013 | Nokia E7 (16 GB) Smartphone
My nokia e7 lock code
What kind of lock are you asking for? If it is a phone lock, Try to do a master reset. This would restore your phone with default factory settings.
If it is a network lock, You can get the unlock code for a Nokia E7 from www.Classicunlocking.com at affordable cost with easy step by step unlocking guide. All the best mate.
Jul 04, 2012 | Nokia E7 (16 GB) Smartphone
Forget security code nokia e7 how to unlock
The default security code for Nokia is 12345 or 00000 you can use it.
If you want to unlock your Nokia E7 you can use the codes ie the
unlock codes. Get the unlock codes using the site Onlinegsmunlock.com
and unlock it easily.
Apr 21, 2012 | Nokia E7 (16 GB) Smartphone
Somtimes my nokia e7 stuck for more than half hour
help meeeeeeee plz my e7 stucked
Sep 24, 2011 | Garden
Nokia E7 (16 GB) Smartphone Logo
227 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
