Question about Cell Phones
I can't open my xtuch x704 when i charged it it
  • 580 Answers
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Posted on Nov 04, 2012
HOW TO UNLOK THE A1136 IPOD
click start control panel scroll to folder options tick in the box to show hidden files and holders
connect your Ipod to your computer
click start click click on you Ipod to open
then go Ipod controls device there should be a folder saying locked
right click select rename to open or delete the folder your Ipod should now be open
or you might do a factory reset
The iPod A1136 is the fifth generation iPod from Apple that uses a click wheel to scroll through your device's media library, and may occasionally lock up when you attempt to play a song or display a photo.
This error error occurs when the hard disk is unable to access the information and stalls while opening a file.
A reset of the device usually corrects the problem, as it clears the device's memory and any errors.
Check your iPod's buttons to determine if the cause is due to a hardware error before resetting the device, as the problem may be due to the iPod's hold switch.
Slide the hold switch at the top of the iPod to the right, and slide it back to the left to ensure the switch is in the off position.
Hold down the center button in the click wheel, and at the same time hold down "Menu" on the click wheel.
Continue to hold the iPod's buttons until the device's screen shuts off, turns back on and shows the Apple logo.
Plug the iPod's connector cable into the dock connector on the bottom of the iPod.
Plug the other end of the cable into your computer's USB or FireWire port to charge the iPod.
Wait at least two hours for the iPod to charge. Launch iTunes on the computer, and click "Controls" of the iTunes menu.
Click "Eject iPod" in the sub-menu to disconnect the device.
The iPod takes four hours to completely charge its battery.
hope this helps
Oct 18, 2012 | Apple Ipod Video 5.5 Gen Black 30gb Mp3...
hope this helps
Oct 18, 2012 | Apple iPod MA446LL/A MP3 Player
Lost my blackberry main menu
If you have tried everything, I would recommend a hard master reset:
This is a really simple way to hard reset the BlackBerry Bold smartphone. If your BlackBerry Bold is frozen or for some reason you need it to have it hard reset then here's how:
1. Pull out the battery from the device and wait for a while around 10 seconds should do.
2. Now put back the battery and it should be resetted. Replace the battery.
If you are lazy and don't want to remove the battery you can also try a soft reset first.
Here's how to do a soft reset.
Press alt+shift+del all the same time.
Another way is to do it via the menu
1. Select Options.
2. Select Security Options.
3. Choose General Settings.
4. Then tap on Menu key.
5. Select Wipe Handheld.
This will wipe out all the data on the device.
Sep 18, 2012 | RIM BlackBerry Bold 9000 Smartphone
How to upgrade xtouch x704 android 4.0 to android 4.1
xtouch will release soon 4.1 for 4.0 users. if u want to update now.. u need to do root ur device.
Sep 17, 2012 | Car Audio & Video
RESET DELL MONITOR E1709WC
Instructions
    • 1 Push the "Menu" button on the front or side of your Dell monitor. The button's icon resembles a miniature monitor. This will open the main monitor setting menu. Push the button again to exit the main menu and open the OSD menu.
    • 2 Push the "Down Arrow" button on the monitor to scroll through the OSD menu. Stop at "Factory Reset." Push the "Menu" button to open the factory reset menu.
    • 3 Push the "Down Arrow" button to select "Position Settings Only" to reset the monitor's horizontal and vertical screen settings. Press the "Menu" button to activate the setting changes.
    • 4 Push the "Down Arrow" button to select "Color Settings Only" to reset the monitor's red, blue and green color settings. Press the "Menu" button to activate the setting changes.
    • 5 Push the "Down Arrow" button to select "All Settings" to restore the monitor to its original factory settings. Press the "Menu" button to activate the setting changes.
    • 6 Push the "Up Arrow" button to select "Exit" to leave the monitor reset menu. Press the "Menu" button to exit the OSD menu. Push the "Menu" button again to exit the main settings menu.
Aug 02, 2012 | Dell Computers & Internet
When i turn it on, it stays black, cannot see anything, and yes i took the lens cover off.
hi let me ask you little more beside your description. would you check if you can see menu on lcd. if yes, then might has two cause. first is shutter doesn't open at initial power on position due to sand damaged or oil contaminate on blade. second is ccd unit or main pcb defective( more open to main pcb defective.) you could bring to your local repair shop. they will charge you around $85 to 135 if it is the problem... Good luck with you!
May 22, 2011 | Canon PowerShot SX100 IS Digital Camera
My samsung corby wifi's SMS messages does not open. it just says initializing and then returns to the main menu everytime i click on the icon.
my samsung corby wifi's SMS messages does not open. it just says initializing and then returns to the main menu everytime i click on the icon.
Apr 24, 2011 | Samsung S3650 Corby / S3650 Genio Touch...
My Samsung YP-T9 MP3 Player wont turn on!!
I think holding down menu and the record button at the same time should fix it. I read the best solution and it just turned on. I was having the same problem, mine would not turn on either but just try pressing and holding down the record and menu button for about 5 seconds.
Oct 18, 2009 | Samsung Yepp YP-T9 Digital Media Player
Can't get back to main menu
switch it off and try to start it again
Jul 11, 2008 | Coby MP-C7085 MP3 Player
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
