I have tried to charge it after it abruptly went off, I presume because of low battery. Nothing happened when I try to charge it. I also cannot turn it on. I have tried to use the reset button. Nothin
  • kimp80 Nov 03, 2012
    i havent drpped it in anything, i was listening to it in bed and it went off, for low battery and when i tried to charge it up it wouldnt
    Problem Solver:
  • 16 Answers
Have u dropped it in anything? such as water or any liquid? or dropped it at any time?
Posted on Nov 03, 2012
    no i was just listening to it when it went off
  • Emily Wyant Nov 03, 2012
    hmmm. go and try to get it repaired or buy another one
SOURCE: Samsung K5 trouble shooting
When you deinstall the driver for the k5 in the hardware manager and then reconnect the k5 with your pc, he will charge. When he is charged you can turn him on. Sometime he shows that he is fully charged but this doesnt matter he charge and charge and charge... after that you can turn him on the usually way. This must be a MTP driver problem. No better solution found
sorry for my bad english, hope that will work and help a few people.
Posted on Nov 20, 2008
ozzfest666
  • 10 Answers
SOURCE: sony walkman nwz-s18f froze
I had this problem a few days ago and now my sony nwzs18f has different problems, the way i got it to charge back up was by using a usb charger that plugs into a socket rather than into your computer this should hopfully charge it back up and also it should unfreeze the screen.
hope this helps
Posted on Jan 12, 2009
SOURCE: Creative ZEN (4GB) not turning on (battery fully charged)
I had the same problem but it powered up after I removed the cover and wiggled the battery.
I hope this helps.
Martin
Posted on May 29, 2009
Just4help
  • 145 Answers
SOURCE: unresponsive (and dead battery) zune o' saddness
Power sources that are supported loadTOCNode(2, 'moreinformation'); To charge the battery in your Zune device, you must connect the Zune device to one of the following supported power sources:
  • A computer’s USB port that you can connect to by using a Zune Sync Cable.
  • A Zune AC Adapter that you can connect to by using a Zune Sync Cable. Note The Zune AC Adapter is sold separately.
  • A Zune Car Charger or a Zune FM Transmitter/Charger. Note These items are sold separately.
  • An Xbox 360 console's USB port that you can connect to by using a Zune Sync Cable.
  • A “Designed for Zune” mobile battery pack
http://support.microsoft.com/kb/927348
Posted on Jun 02, 2009
webmaster21
  • 803 Answers
SOURCE: creative zen microphoto 8gb stuck on locked
Try reflashing the firmware for your device you can find the latest firmware and flashing utilities from the manufacturer?s website. Make sure that you back your music up first because when you do this you are setting it back to factory settings.
Posted on Sep 30, 2009
2013 Sonata electrical freaking out
Battery is weak. Most auto parts stores can perform a battery diagnostic for free and even charge it if it is just weak. Take the battery out of the car and take it to tour nearest at parts store.
Jul 07, 2016 | 2013 Hyundai Sonata GLS
Yamaha wont turn over
Hi. Yes more than likely it is the battery. Even when boosting it the battery can drain all the power from the boost battery. You could try topping up the acid then charge it.
May 07, 2014 | 1981 Yamaha XJ 650
Camera does not turn on
Rosa, I think the only thing you did was get out the batteries and tried to charge them and then jut put them back in the camera.
Only a few things could have gone wrong.
One or more cells could have died, during charging. It can happen, special with batteries that have a uneven use. Like once or twice a year the camera comes out the box and then the batteries are charged. Even when you don't use he camera, make it a habit to charge the batteries every few months.
Then it could be your batteries are still in good shape and fully charged, but you put in one or more calls the wrong way around.
Please check carefully if all the cells are inserted correct.
If nothing works, and you can't check the voltage of your batteries, try another set of batteries.
Dec 30, 2013 | GE Cameras
My Coolpix S2500 wont turn on or charge. I've only used it once till the battery went flat and didn't charge it for 2 wks n now when i try to charge ti nothing happens
Easy.
Remove memory card
turn on
re-charge
shut down
re-install memory card.....
If it does not turn on with memory card removed, connect to charger and turn on
Jul 18, 2011 | Nikon Cameras
NAVIGON 7100 WON'T TURN ON
your battery is gone requires new one.
Aug 20, 2009 | Navigon 7100 GPS Navigator GPS Receiver
Zen V Plus locked up, will not shut off
After 3 1/2 hours, the battery went dead. I waited a couple of minutes, then plugged it into my computer to see if the battery would charge. It started charging. A few hours later I went back to check on it, and it showed a full battery. I disconnected it from my computer, and turned it on. It came on, but the screen just said "Low Battery". I then plugged it back into my computer, and the screen said "Rebuilding Library". I left it for about a 1/2 hour, and it was done. I unplugged it from my computer, turned it on, and it works now!! Hope this helps out everyone else who has the same problem.
Feb 12, 2009 | Creative Labs ZEN V Plus MP3 Player
My phone wont turn on!!!
Your battery might be dead. How long have u had the phone?? i had mine for 1 year and like 2 months b4 i had to buy a new one because it wouldnt hold a charge
Apr 07, 2008 | T-Mobile Dash Smartphone
PSP no power
Try taking the battery out and plugging it into the wall with only the charger and see if it turns on. does The green light came on?.
Jan 01, 2008 | Sony PlayStation Portable (PSP) Console
Battery not charging
In my opinion everything you done was right. I believe that the warranty is still valid and you should try to contact service partner. Maybe is the power charging electronic defective. Sorry but I don’t see any other possibility that you can do alone.
Sep 08, 2005 | Toshiba e800 Pocket PC
 Grubhead
Grubhead
