Question about Sewing Machines
How do you attach the embroidery foot on the model 1730 white quilting machine
  • Sewing Machines Master
  • 1,564 Answers
Do you mean darning and stipling foot?
http://www.singerco.com/uploads/download/711_white-1730-x.pdf
Posted on Nov 06, 2012
Trifect7
  • 57 Answers
SOURCE: How do I attach a walking foot
Okay let's get started.
  • First let's look at the walking foot.
  • Turn the bulky body so that it's away from you.
  • On the left you see a groove that is going to be where you attach the foot to your machine.
  • On the right is a u-shaped arm which you can move up and down. It will go over the needle clamp
Now, let's remove your present foot from the machine and look at it.
  • Loosen the foot screw until it almost comes off. (if it does come off, screw it back on a bit.) The screw is on the left of the foot-bar.
  • On the right you'll see the needle bar with a needle clamp (what you tighten when you replace a needle) on the right of the needle-bar.
Okay the walking foot business.
  • slide the walking foot into position so that the foot screw is in the slot on the right and the u-shaped arm is over the needle clamp, with the needle clamp in the middle of the u-shaped opening.
  • Tighten the foot screw securely, it's going to be under more strain than normal.
  • While you're at it, check that the needle-clamp is nice and tight as well.
Okay, then! There you go... Happy sewing.
Are you happy? Than please vote
Here are a few helpful pictures.
Posted on Mar 02, 2008
  • 192 Answers
SOURCE: Presser foot wont raise and lower
Does the presser foot move at all when the machine is first turned on?
Do the needle and feed teeth calibrate when the machine is first turned on?
You probably need to locate your nearest authorized repair center.
Posted on Jun 12, 2008
SOURCE: stitches
Usually a walking foot is for straight forward stitching only.It keeps the many layers from shifting for you. The "hand-look" quilting takes a couple stitches forward then one back. If you look close, you will see about every other stitch is thicker and stands out more.
Posted on Sep 23, 2008
  • 40 Answers
SOURCE: Looking for Janome 2003P model manual. It is
visit www.janomestuff.com
Posted on Sep 15, 2009
bargainbox
  • 1388 Answers
SOURCE: Is this machine a high or low shank?
High Shank Machines are all the Janome Embroidery models MC 8000, MC 9000, 10000, 10001, 11000, 200E, 300E, 350E....etc
If yours is not an embroidery machine, it has a LOW SHANK .....the higher shank allows for easier access for the embroidery hoop.
Posted on Nov 12, 2009
How do I set the Husqvarna 300 sewing machine to do free motion embroidery. Do I need the embroidery attachment and get the machine to embroider with or with out the card
You can do embroidery or you can do free motion. If you're quilting a quilt sandwich (fabric, batting, backing fabric), you probably want to do free motion quilting. Embroidery would work better on fabric (with a stabilizer) but without the batting and backing fabric.
For free motion, you want a free motion foot--your machine's manufacturer probably provided one in the accessory kit (called a darning foot) or there are many generic free motion feet available for purchase (ie Big Foot quilting foot...). The BIG difference with a darning foot or free motion foot is that the shank is shorter than other presser feet because there needs to extra space between the presser foot and the needle plate so the quilter can easily manipulate the fabric. Usually, free motion quilters will drop the feed dogs to avoid feed dog interference with the fabric's movement, however, some quilters don't drop the feed dogs--just whatever works best for you and your machine. In addition, I use a Supreme Slider on the sewing machine surface--a silicone mat that provides a slick surface to help the fabric move.
There are a lot of web sites and video tutorials on free motion quilting. Take some time to watch them and then practice, practice, practice! It's an acquired skill so the more you practice, the better you will be.
Feb 09, 2018 | Husqvarna Sewing Machines
I don't know how to use the darning on my bernina 950. Can you advise
You need to use a darning presser foot--there are several designs of darning feet made by Bernina or generic brands (be sure the generic model has the appropriate attachment for your particular Bernina). You can find metal or plastic, clear or solid foot, open or closed toe, spring-loaded hopper or not, etc. Drop the feed dogs. If it is thinner fabric (lighter weight than denim), it sometimes helps to put the fabric in an embroidery hoop (upside down with the fabric next to the needle plate). If the hole is small, you can use the little hoop that should have been included in your Bernina accessory kit. Then you manually move the fabric back & forth, up & down under the presser foot while stitching.
12 BERNINA presser feet Darning foot 9
How to Use the Big Foot Darning Quilting Embroidery
Choose Your Darning Foot Quilting Foot and Learn to Machine Quilt
Aug 08, 2017 | Bernina Sewing Machines
How do I avoid breaking a needle on a 26 foot beginning a free motion project after programing the foot choice and lowering the foot?
#26 is an embroidery foot. Why are you using an embroidery foot for free motion quilting? A #24 free motion embroidery foot will work but not the #26. Try using a darning foot that is just a smidgen shorter so there is space between it and the needleplate for you to freely move the fabric. (Adding a Supreme Slider sheet to the work surface of your machine helps make the fabric glide much smoother.) A standard presser foot is made to press the fabric against the feed dogs so the feed dogs will move the fabric. When free motion quilting, you would drop the feed dogs and move the material with your hands.
Depends which model Bernina you have (new or old style presser feet), which will work on your machine. There are also many generic darning/FMQ feet available that will work on your machine.
12 BERNINA presser feet Darning foot 9 (old style)
Quilting foot 29C (new style)
Bernina 530 53 Free Motion Quilting
Top 5 Tips for Successful Free Motion Quilting WeAllSew BERNINA USAs blog...
Seven Steps to Free Motion Quilting
Dec 31, 2015 | Sewing Machines
I lost my Manual to the white quilt and sew no. 1730 is there any way that I can purchase one?
Go to singerco.com and under support download a free one. Just put in the model #1730
Sep 22, 2010 | White Sewing 1730 Mechanical Sewing...
I am searching for an instruction manual on how to use the White Quilt' N Sew 1730 sewing machine. When I purchased the machine the only instructions included were on a VCR tape, and face it, no one has a...
Manual in PDF of 44 pages is here for free:
http://www.hammerwall.com/Download_Manual/70246/
If you have the VHS tape it can be converted to DVD, I do them as well but you might find someone near you that offers video conversion, or tape to disk or VHS to DVD. Contact me if you have the VHS tape and need it converted cheaply.
Jun 13, 2010 | White Sewing 1730 Mechanical Sewing...
How to attach a quilt guide
You have to unscrew the screw for the presser foot first. The walking foot will then fit. Use the same screw to attach the walking foot. Before you insert the screw, take the white handle on the walking foot and slide it on the screw arm for the needle. Now tighten the screw.
Mar 21, 2010 | Singer Sewing Machines
I WOULD LIKE TO TRY MACHINE QUILTING WITH MY ROSE MACHINE. DO I NEED A SPECIAL FOOT ATTACHMENT OR COMPUTER CARD?
If you want to piece quilts, I recommend a 1/4" piecing foot. Husqvarna make several different types that may be used on the Rose.
If you want a dual feed or walking foot, check out the new Interchangeable Dual Feed foot.
You only use card with the Rose for embroidery, which you can do on a quilt, but not necessary.
Feb 04, 2010 | Husqvarna Sewing Machines
Is this machine a high or low shank? I'm trying to buy a 1/4" quilting foot or seam foot and not sure which foot to buy.
Nov 12, 2009 | Janome 8080 Computerized Sewing Machine
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
