Question about Toshiba 46H83 46" Rear Projection HDTV-Ready Television
Infared sensor not receiving
The first symptom was no control of tv with remote control. We bought a second Toshiba remote, didn't work. I have some electronics experience, so I ordered a remote sensor, upon getting part figured out where it goes to find that the original part has four (4) leads.
the new part has only three(3). Virtually have no test equipment(VOM)
I am assuming the problem is on Toshiba board 23599707 or possibly PD1280-1 these are possible part numbers. I could live with this not working but have not determined how to switch from TV to Sat without the remote.
  • 1694 Answers
SOURCE: Toshiba 50H82 blown fuse f470
Solder jumper wires for prevent maintenance.....on signal
board = 008,010,017,048,600.............................T.
Posted on Dec 19, 2007
AvioriX
  • 689 Answers
SOURCE: Toshiba 43" 43H70 Projection TV - Remote Sensor not working
It might require a qualified hands on tech. But by my experience remote sensor at the TV side wont have malfunction easily. You can still think about the Remote. You can test remote control by your own. How? You need to have a portable AM radio (MW). while pressing the buttons of the remote control you can move the tuning dial (Remote control should be close to the radio within 5inches). If you hear patterned sound it shows remote control is working. The AM radio method is well known and it has over 85% success rate for all kind of IR remote controls fail isolation. You can also try with known working remote control of other devices to understand the method. If remote control test shows that it works contact to service. Please send new posts if you need further assistance.
Good Luck
Posted on Dec 30, 2007
clusterfx
  • 67 Answers
SOURCE: TV remote control sensor
yeah,it's very easy.
pull out the bottom part(where the speakers are) - they are held with plastic hooks on the inside, they are =on the left and right side and a few at the top. just pull one end and the rest will come off easily.
remove a couple of screws holding the buttons assembly and the bottom of the screen.
slide the screen carefully upwards and when you reach about half way then it will come off.
behold...the sensor is infront of you, it's a small pcb with a light sensor on it. (if you see sensors at the very top or side...they are probably focus sensors)
sure it's not the remote?
Posted on Feb 23, 2008
jerryg50
  • 1689 Answers
SOURCE: Toshiba 43H71 - remote sensor not working
The sensor is not the only fault that can cause the remote control to not work. The sensor is only one part of the circuits involved.
Between the sensor, there may be buffer amplifier stage, and then there is the main uPC.
What we do is send a remote IR data signal to the sensor, and on the circuit board in the set I follow the data signal along its path using a scope in reference to the service diagrams to see where the data loss is.
Personaly, I would not blindly buy a new sensor based on a guess without doing the proper tests.
Jerry G.
Posted on Jun 13, 2008
SOURCE: Toshiba md12m1 tv/dvd, original remote needs reprogramming
i have a toshiba tv how do i reprogram it ,evry time the electric goes out the tv goes out to be reprogram and i for got how and do not have i book.
Posted on May 12, 2009
Bought new Vizio 55"
Had same problem - turned off Adaptive Lumina, Backlight control, and Ambient light sensors on the Vizio advanced picture settings and the Dish remote now works. Vizio was emitting an infared signal that interfered with the Dish remote signals with these settings on. TV still works and looks just fine... But best of all Dish remote works too.
Nov 08, 2010 | DISH Network IR Remote Control
Blind TV
If you provide model and chassis number, we will provide you with more detail info.
The IR sensor could be defective if It does not respond to any remote control.
Apr 04, 2008 | Toshiba 36HF12 TV
TV does not detect remote control.
Remote control receiving sensor circuit problem in the TV. Mostly due to degradation of the sensor over a period of time.
Go close to the TV and see whether you get a response. If it responds try determining the distance back wards. If the remote works up to certain distance, the problem is weak sensor (TV).
If totally not operative it is sensor circuit problem. It could be sensor or it's associated parts.
May 24, 2010 | Toshiba MW27F51 27 in. TV/VCR/DVD Combo
Remote sensor
Bad connects at sensor inside TV or bad sensor.......
Toshiba part # 23009490............T.
Sep 21, 2007 | Toshiba 36A60 36" TV
Having problem with the remote control
have u tried a new remote or universal remote? if the tv doesnt respond to anything you might need a new infared sensor your remote control part number is AH301805 AH302260 is the remote control board for the set hope that helps
Jul 04, 2007 | Toshiba 19HLV87 19 in. LCD HDTV
Remote Sensor Repair
Before condemming the infared remote receiver, make sure that you have tried and original toshiba remote control. Sometimes universals do not always work. If you do have to replace the (IRR), the main circuit board or the button assembly must be removed. The part is soldered in and has only three wires. The approximate cost of the part is around $20. You local service center would probably charge you $80 to $100 for the repair. If you have already tried a number of universals, the chances are that the(IRR is defective). Also try the code search on the universal remote sometimes this will work. Scrivitron
Jun 19, 2007 | Toshiba 36A41 36" TV
Receiver not taking commands from the remote
Point the remote at a digital video camera to see if you can see the small blue infared light comming from the end of the remote when you aim it at the camera and press a button. if you do see the light then your receiver has a system control problem I'm afraid. You see your eyes cannot see the infared light but the camera optics can. Good Luck
Jun 07, 2007 | Onkyo TX-DS989 Receiver
Sony Trinitron 30" no remote seems to work
If you want to test the voltage you can do so at connector CN002 on the main board. You should have 5 volts DC at pin 4 and at pin 5 marked SIRCS (sony infared remote control system)should be 5 volts as well but, will drop to about 2.5 volts when any button is pressed on the remote. If it doesn't change then you should change the HR board wich houses the IR rec. and associated components.
Jan 25, 2007 | Sony FD Trinitron WEGA KD-36FS130 36" TV
My remote control does not work
You could have a defective IR sensor in the tv set that sends the infared signal to the MIcroprocessor IC. These are something you cant just replace, as it needs to be trouble shot with a scope to see if theres a data signal comming out of the sensor and if there is it could be a bad solder connection somewhere between the sensor plug to the Main IC. Also could be the B+ that supplys voltage to the sensor. Unless you have had electronic repoair experience, You should have a pro assist you with this repair. Sorry I couldnt assist you more with this . Good Luck
Jul 06, 2006 | Toshiba MD20FN3 20 in. TV/DVD Combo
Toshiba 46H83 46" Rear Projection HDTV-Ready Television Logo
87 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
