Question about Kodak EASYSHARE 5500 All-In-One InkJet Printer
Printer will not print all information /missing information
When using the printer not all information is printer /some areas is blank
    President:
  • 8,637 Answers
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 26, 2009
When i print it is leaving blank spaces horizontally across the page, 50% of the document is missing. I thought it could be ink so i changed all the cartridges, that hasn't resolved the issue. I have
It looks like you have blocked nozzles.
On your computer locate your printer in control panel.
Right click on your printer and select printer preferences.
You should find maintenance and try printing a nozzle test.
If you have blank areas I suggest a head clean or two.
NEVER do more than 3 in a row!
You may damage your print head.
If more is required, wait 5-10 mins after doing 3 cleans.
You may overheat your print head as it heats the head while performing a clean to try and clear blockages.
Jan 13, 2015 | Epson Office Equipment & Supplies
HP OfficeJet 5610 leaves large blank areas
can be a problem on the thermal roller, have you try to clean print head first..?
Aug 30, 2008 | HP Officejet 5610 All-In-One InkJet...
Document missing printer using epson stylus office tx300f
  • Make sure you selected the correct paper size settings in your printing program and printer software.
  • Run a print head nozzle check to see if any of the nozzles are clogged. Then clean the print head, if necessary.
  • If a blank page exists in a document you are printing and you want to skip printing it, selectSkip Blank Pagesetting in your printer software.
    1. Do one of the following:
      • Windows 7: Clickwindows_start.gif, and selectDevices and Printers.
      • Windows Vista: Clickwindows_start.gif, and selectControl Panel(or point toSettingsand then selectControl Panel). SelectPrinter(underHardware and Sound) orPrinters.
      • Windows XP: ClickStart, and selectControl Panel(or point toSettingsand then selectControl Panel). SelectPrinters and Other Hardware(if available) and thenPrinters and Faxes.
    2. Right-click your printer icon, and then selectPrinting Preferences.
    3. Click theMaintenancetab, then select theSpeed & Progressbutton.
    4. In the Settings area, click on theSkip Blank Page.
    5. ClickOKas necessary to save your settings.
  • Hope It's resolve all Your Printer Problem,
    Or Still having Problem Then follow Us ForEpson Printer Support
Mar 27, 2014 | Epson Stylus Office Equipment & Supplies
Hp designjet 500 plus42" print miss some area
1- CHUECK THE HARDWARE OF PRINTER SHAFT
2-THE INK VAT PAPER HAS BEEN TORED
Dec 16, 2012 | HP DESIGNJET 500 InkJet Plotter Printer
My hp deskjet 6940 inkjet printer doesn't show me level of ink in cartridge
Print a diagnostic page If the steps above have not helped, print and evaluate a diagnostic page to see if the cartridges or the printer is causing the problem.
  1. Make sure the printer is on and loaded with unused, plain, white paper.
  2. Press and hold the Power button and then press the Cancel button. Release both buttons. The diagnostic page prints. Figure 1: Power and Cancel buttonsc00584735.gif 1 - Cancel button 2 - Power button
Step 4: Note which cartridges printed which areas of the diagnostic page You must identify which cartridge printed which part of the diagnostic page, so that if you find defects on the page, you will know which cartridge is the problem. However, you can install different combinations of print cartridges in your printer, and different cartridge combinations print different diagnostic page patterns. Your diagnostic page may not look exactly like the picture below, but the right and left cartridges will print in the same areas of the page no matter which cartridges are installed. Figure 2: Diagnostic page layout (the patterns in each area may look slightly different on your page)c00584715.gif 1 - Printed by the right cartridge 2 - Printed by the left cartridge NOTE: If you are printing in reserve mode (one cartridge is missing), the missing cartridge's area of the diagnostic page will be blank. Step 5: Check ink levels NOTE: If you have installed a refilled or remanufactured ink cartridge, or a cartridge that has been used in another product, the ink level indicator is inaccurate or unavailable. Look in the middle of the diagnostic page. The bars with "E" (for "empty") and "F" (for "full") at each end show the ink levels in the cartridges. As ink is used, the solid color changes to a faded color. Figure 3: Left (tri-color) cartridge almost full - right cartridge emptyc00235259.gif Figure 4: Both left and right cartridges almost fullc00235260.gif
Feb 22, 2011 | HP Deskjet 6940 InkJet Printer
My HP laser 2420d will not print. Meaning, it will not display information in the screen from print preview not will it display any of the information on paper. It prints out a blank sheet of typed...
Clarification please.
"It prints out a blank sheet of typed information"
Is it printing out a blank sheet or is it printing out typed information????? It can't do both.
"it will not display information in the screen" What screen are you talking about?
Nov 09, 2010 | HP LaserJet 2420 Printer
New ink cartridges installed and sometimes prints with missing horizontal areas(blank lines about 1/8 inch thick 20 plus randome down the page. The next time printing may be fine. Color is washed out...
Replace the print heads for the coloured inks you replaced, run the align printer head diagnotic from the printer menu. This should correct the print problem.
May 21, 2010 | Kodak EASYSHARE 5100 All-In-One Printer
Pages printing blank
Resolving white, light lines or streaks (eliminate light stripes)
From the printer, print the Troubleshooting Print Quality Pages.
With Troubleshooting highlighted, press the OK button.
Scroll to Print Quality Problems by pressing the Up or Down Arrow button. Press OK.
Scroll to Troubleshooting Print Quality Page. Press OK.
Evaluate the Light Stripes Test page for missing printhead jets (missing cyan, magenta, yellow or black color bars).
Clean the maintenance unit's wiper blade and empty the waste tray. A dirty maintenance drawer wiper blade can cause white lines and weak or missing printhead jets. Using a clean lint-free cloth or a paper coffee filter, gently clean the blade with a wiping motion across the entire length of the wiper blade.
Dec 20, 2008 | Xerox Phaser 8400 Laser Printer
I have blank lines through my printouts
Run the cleaning cycle. If that doesn't work, try to use an alcohol soaked swab on the print head. Some of the jets are clogged.
Oct 27, 2007 | Canon PIXMA MP130 All-In-One InkJet...
Horizontal lines
Depends on whether the "lines" are colored or just blank areas missing in the print . If it is blank areas , then most likely the laser scanner is dirty and the glass needs to be cleaned . If it is colored lines , then you most likely have a defective drum .
Jul 18, 2017 | HP LaserJet 1500L Printer
Kodak EASYSHARE 5500 All-In-One InkJet Printer Logo
18 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
