Difficulty charging the battery
When charging does power on the player have to be on or off?
  • 32,281 Answers
It does not matter if it is on or off.
Posted on Nov 04, 2012
  • Chris Hingee
    Chris Hingee Nov 04, 2012
    If it is turned ON it may indicate the charge level of the battery.
Samsung 3262 charging paused for battery
Since you are experiencing difficulty in your charger since your Samsung 3262 won't charge although it is showing it is charging battery then we will be solving this matter so to fix battery and charger problem. • Performing a power reset. •Hold the power button for 30 seconds without it being plugged in. •Then place your Tab on a home charger for a couple minutes. •After a couple minutes, press the power button again for 30 seconds with the charger plugged in. This is usually a charger issue But in a small amount of cases it can be the battery. If recently purchased you can just return it and get a new phone.
Sep 29, 2014 | Cell Phones
No problem just bought a mpd-1760 from someone its brand new never even been used ,but no instructions/need to know how long to charge battery for first time or at all //charging time for battery to watch...
To charge the battery back you want to
  1. Turn the power off the DVD player first as the battery pack will not charge with the power on.
  2. Attach the battery pack to the player.
  3. Connect the AC power adapter and the power cord to the player.
  4. Charging will now start and the Power/Charge indicator should now be orange.
  5. Do not unhook either cord until the Power/Charge turns off.
  6. Time of charging is approximately 4 1/2 hours.
  7. The battery pack will more than likely get warm while charging. This is normal. Keep it as much in the open as you can for the best ventilation possible.
  8. You will get a low power indicator on the screen when the battery has a low charge.
As for playback time you will get about 2 1/3 hours of actual playback and about 4 hours of standby with the DVD player actually on.
Regards, Tony
Apr 12, 2011 | Mintek Televison & Video
My mp3 player doesn't turn on even if I charge it. Do you think I need a new battery?
Make sure the player is fully charged. 1. Connect the player to the PC. 2. Make sure the computer detects the player.
NOTE: If needed, switch the player to MSC mode, to switch the player to MSC mode
1. Turn device OFF. 2. Slide the Hold switch down to Lock (orange color showing). 3. Press and hold the center button while connecting the device to the PC.then connect it to the PC. Skip this step if you think it is charged. Next Be sure the battery is charged 1. Leave the player connected for approximately 2 hours to charge. 2. Disconnect the player from the PC. 3. Verify if you can turn on the player. 4. Reset the player if necessary. To reset the player: 1. Press and hold the Power/Menu button for approximately 20 seconds. 2. Release the Power/Menu button. 3. Press the Power/Menu button again to turn on the player.
If that does not do it, re-seat the battery: Here is how to get to the battery, 1. Press the battery compartment in while sliding to the right. 2. Remove old battery. 3. Insert new battery or reset the old battery. 4. Close the battery compartment. Then try and see if it will come on with out the battery hooked to your computer. 1. Remove the battery. 2. Connect the player to the PC to verify if it turns on. 3. Re-seat the battery to ensure proper connection. 4. Verify if the player turns on.
Jan 30, 2010 | SanDisk Sansa m230 MP3 Player
No power
Make sure that the battery is fully changed. Now, you need to test it to see if there's a problem with the battery or with the power switch.
Charge the player and turn it on while charging. If the player turns on while charging, then there could be a problem with either the battery or the wiring inside.
If the player will not turn on even if it's charging, then it could be the power button or some other components inside the player.
Hope this helps and have a great day!
Aug 12, 2009 | Sony Walkman Video NWZS615F MP3 Player
Sansa clip wont power up unless hooked up to usb
http://www.sandisk.com/media/175960/clip_um_0608_eng.pdf
Windows XP SP2
• Windows Media Player v10
• Intel Pentium class PC or higher
• CD-ROM drive
• USB 2.0 port for hi-speed transfers and charging
Make sure HOLD button is not on.
Battery
The Sansa
Clip player comes with an internal rechargeable battery. To use the player for
the very first time, remember to fully charge the battery. You can charge your Sansa
player through the USB port of your computer, a car adapter (not included) USB port, or AC
adapter (not included) USB port.
Charging
To charge the battery, please follow these steps:
1. Connect the larger end of the USB cable into an available USB port on the
computer.
2. Connect the smaller end of the USB cable into the Sansa
Clip player.
3. The computer must be on for most USB ports to charge your battery. Your
Sansa
will show connected and the yellow charging indicator will appear.
The battery level indicator will blink while charging. You will not be able to
play while connected to the computer USB.
4. To stop recharging, simply disconnect the cable.
The battery can also be charged using an AC adapter (not included) or a car adapter
(not included) and you will be able to play your device while charging with one of the
adapters.
NOTE: Some low-power USB ports may not be able to provide enough charge
power. Also note that the rechargeable batteries are not replaceable.
Feb 26, 2009 | SanDisk Sansa m200 SDMX3-512 MP3 Player
Charging difficulty
go get a new one that one is busted
Jan 14, 2009 | RCA OPAL M4001 MP3 Player
Power source.
Well I am not a technical person, but i imagine it should be possible to use all such products while they are charging.
Aug 12, 2008 | Philips PET702 Portable DVD Player
Battery charge
Simply plug the included power cord into the power input on the DVD player. Leave the unit "off". Allow to build a charge. The included power supply items are:
Flexible power supply: up to 2.5 hours rechargeable Li-ion battery,
12volt car cigarette lighter adapter and AC/DC power adapter
Jan 08, 2008 | Mustek PL-510 Portable DVD Player
15 people viewed this question
 Grubhead
Grubhead
