Question about Zanussi FJD1466W Front Load Washer
Zanussi jetmaster paddle broke - Zanussi FJD1466W Front Load Washer
How can I replace the drum paddle on my zanussi zwf16070w1
Insert a screwdriver into the fourth hole in the lifter (paddle) and
bend back the anchor tabs. Pull the lifter outwards (towards the door) and detach from the drum. To insert the new lifter into the drum is needed to disconnect the tube between the tub and filter housing, than tighten the screw (through the hole in the tub) to secure the lifter to the drum.
Dado
Nov 29, 2014 | Zanussi Washing Machines
Paddle in drum broke
Hi friend, thank you for your post!
Based off the information you have provided the paddle (vane) inside your Frigidaire washer broke. I would recommend having a technician come out to diagnose and repair your appliance due to some of these intricate parts requiring precision and patience. When replacing such components or removing them from your appliance I suggest seeking professional assistance. One must be very careful as these replacements can lead to potential harm. Hope this helps. -Matt
Aug 12, 2014 | Frigidaire Washing Machines
Water dispenser for gsh25JSTA BROKE can I fix
All of you guys are wrong. What that person is saying is that the physical paddle used when you place your glass in the dispenser bay and press against the paddle....That's what's broken the paddle......
Jan 05, 2013 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
I have a Kenmore 500 series dryer. The dryer just stopped working but the light stays on when the door is closed.
the door switch is broke.when you push on the paddle of the door switch the lite should go out,if you don't see the paddle it most likely broke off,you need to send the full model number next time,it will start with 110.or similar.the door switch is a safety so the machine won't run until the door is closed,if the switch is broke no power will go to start the dryer
May 10, 2011 | Kenmore 500 6953 Dryer
How do i fix a paddle on the drum? I have zanussi machine. Paddle broken off. If i buy a new paddle how do i fix it on? Have tried to glue old paddle with no success!!
With some of these machines now they have sealed drums.On some models you can access through the bottom sump hose and others you may be able to get access through the hose by the soap box.There are a couple of drums where you can drill a hole in the top to get at the tags on the paddles and some drums where you cannot do without changing the complete tub.
Hope this helped.
May 17, 2010 | Zanussi FJD1466W Front Load Washer
I replaced the water paddle now neith ice or water work
either a wire/block is not plugged in good or the micro swicth is not being activated. possibly the cup/glass cradle not in correctly. Recheck instilation
Mar 02, 2010 | Kenmore Refrigerators
The inside of my drum has paddles and they keep coming off and i dont know why or how to stop them coming off
If the bars (paddles) are not cracked around the screw holes, use Duco cement (or other glue) on the threads of the screws (all of them) to lock them in place. If the threads in the bars seem to be stripped out, the screws may be too short (don't use screws so long that they poke out of the bar). The top must be opened to work on the mounting screws. Hope this helps
Feb 21, 2010 | Zanussi ZWF1430W Front Load Washer
The paddle broke off in my Maytag Atlantis Dryer
you need to remove the frt cover 1st and then the screws will be accessible to remove top cover
Sep 19, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Drum paddles falling off
until you post the statement again and include such vital details like make model year type of equipment etc and photo then nobody has any idea of what you are on about
May 05, 2017 | Zanussi ZWF1420W Front Load Washer
Zanussi FJD1466W Front Load Washer Logo
26 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
