Question about Smeg 24 in. DWF614SS Stainless Steel Free-standing Dishwasher
E3 error code on smeg dishwasher
I am getting an E3 error code on the dishwasher, can anyone advise how to fix it the error means that the appliance is unable to pump out the water, however there is no water left in the machine !
  • 641 Answers
SOURCE: smeg dishwasher wash cycle freezes ,
Thanks for the information.
Posted on Jul 24, 2007
  • 1462 Answers
SOURCE: E2 error in smeg dishwasher
e2 is overfill or flooded base.
take the bottom front panel off and see if there is water in it and if so, mop it out. if it reoccurs, then you have a leak.
you will see a float device in the front approx middle and this is what actuates e2. if fault is intermittant, try putting a small weight on this - a washer for example.
if e2 is being caused by overfill and not a flooded base, then the water intake moulding needs replacing
Posted on Nov 20, 2008
ginko
  • 19396 Answers
SOURCE: SMEG Dishwasher - Water fill level is too low
Hi, I found your problem stuck here from one year ago.
I will post my solution the same, as reference for you and more users with same problem, apologies.
Re: smeg dishwasher fails to fill with enough water to sucessfully wash. It does put some water in.. but nowhere near enough.
Before checking parts inside the machine, ensure that water is coming from the faucet at the back with regular pressure.
To start check the water level sensor.
This is usually a floater sensor located on a side inside the dishwasher.
Check if water level is working properly, if the floater is getting stuck then that is the problem.
If the water level is OK, then the responsible is usually the inlet valve, or clogged inlet lines.
From description it looks more like a faulty water level.
Posted on Apr 07, 2009
SOURCE: Error message on Smeg dishwasher
i have error 1 on our dishwasher any clues ?
Posted on Aug 11, 2009
rickead1
  • 1998 Answers
SOURCE: I am getting an E6 error on my Smeg dishwasher SA
usually you would press the canel button for three seconds to get the unit to go into drain According to SMEG, there are 3 causes for this fault :
kinked drain hose
Pressure Switch Fault (£18 )
Drain Pump Fault (£39)
on one occasion i had to repair the problem by traceing the fault to a broken wire between the electronic module in the door and the pump. The point at which the door opens and closes on the cables has frayed the insulation and broken through the wire. As this was the live feed to the pump and a potential short from 240VAC to the chassis its dangerous!!
Repairing the wire break and re-insulating fixed the problem
The code means no drain detected in the time allowed, so the pressure switch may have failed in the closed position, or there is a blockage in the chambers or pipework preventing the switch from de-pressurising.
if you have any further questions message me back and please remember to rank this opinion when our chat has fully concluded it allows me to help others in similar situations in the future Thanks Rick
Posted on Jan 29, 2011
Kettle does not heat. What does the E2 message mean
SMEG DISHWASHER ERROR CODE E2? - How To Mend It
howtomendit.com > Kitchen Appliances, Electric Kettles
Free repair help - smeg dishwasher error code e2. ... Q & As - mend, repair, fix kitchen appliances, electric kettles, kettles, water, not, plug ... Search for - error, e2 ...
Oct 15, 2015 | Oster 1.7 L Variable Temperature Electric...
Error 8 light on. I think all lights flash, then far right light stays on. Recently had issues with it. Not emptying properly. How do I fix it??
6. Troubleshooting
In case of a malfunction, the dishwasher will identify the program by switching on a combination of lights.
When an alrm is present, all the PROGRAMS lights (4) come on, while the PROGRAM PHASES lights (7) identify the error code:
E2
The system which limits the water level inside the dishwasher (safety unit) has been tripped.
E3
The appliance is not able to pump out the water.
E4
Temperature sensor disconnected.
E5
The appliance is not able to take in water.
E6
The appliance is not able to pump out the water from the tank.
E7
The appliance is not able to measure the amount of water loaded accurately (on models with turbine flow-regulator only).
E8
Anomaly in the system which distributes water to the basket (where installed).
56
CODE
E9
PHASES LIGHTS
DESCRIPTION
E1
The anti-flooding system (if installed) has been tripped.
The maximum level of water for loading has been exceeded (on models
Jun 02, 2015 | Smeg 18 in. DWD409SS Built-in Dishwasher
Error 8 . How do I rectify it?
6. Troubleshooting
E2
E3
E4
E5
E6
E7
E8
56
CODE
E9
PHASES LIGHTS
DESCRIPTION
E1
Thjere is something wrong with the distribution. Check for blockages.
Error code E3 on Samsung DMS500TRW dishwasher
3E error in Samsung dishwashers normally relates to high temperature error. This means the dishwasher is detecting over 80deg C water temperature. However if it is 5E that means drain error. If your dishwasher is draining correctly then please check the error again.
Apr 14, 2014 | Dishwashers
E3 Error
the E3 error is a result of water temperature not getting to a nominal value within a particular time. This could be caused by several factors like heater faulty, wash pump not working well, wash arms not circulating water as required. Need model number to help you further pin point if possible.
Refer this site for 60 inch dishwasher and this site for 45 inch ones.
Jan 02, 2013 | Smeg Dishwashers
Smeg DW167.1 error code
I HAVE A SMEG DW167.1 AND IT COMES UP WITH A E9 FAULT, DOES ANYONE KNOW WHAT I CAN DO TO SOLVE THE PROBLEM ,THANKS
Jun 22, 2012 | Smeg Dishwashers
Is there a quick fix to a flashing e3 on a Danby DDW497W?
Refer the user manual for your dishwasher. Error codes are given on page 7.
e3 means the heater is not working or the thermostat (which checks the water temperature) is faulty.
Not sure there is any quick fix other than to replace. If the heater is showing some reading on an ohm meter then it is likely the thermostat is faulty. In any case it will be easier and cheaper to replace the thermostat first.
You will need to call Danby service closest to you for advise on getting the parts or servicing it.
Please rate this solution to help fixya serve you better in future.
Oct 06, 2010 | Dishwashers
What does E3 mean?
E3 not hot enough. This defect can be caused by, but not only, a defective element or clogged spray arms.
Sep 29, 2017 | Dishwashers
Apr 23, 2007 | Smeg 18 in. DWF410SS Slim-Line...
Smeg 24 in. DWF614SS Stainless Steel Free-standing Dishwasher Logo
217 people viewed this question
Top Smeg Dishwashers Experts
Starnley Johnwells
Starnley Johnwells
Are you a Smeg Dishwasher Expert? Answer questions, earn points and help others
