Question about Lexmark X63 InkJet Printer
Add cartridges message on display lexmark x63
The ink carts are installed, however the dispaly on the printer says add carts. when I try to print, message says device is busy try later, there is nothing in que the software is installed correctly, I have taken the carts in and out but the display says carts not changed then after I hit start it says add carts.....I have had this for 6 years never had a problem??
  • 14 Answers
SOURCE: Lexmark X63 all-in-one printer shows
try powering off the printer for 30+ sec.... then turning it back on...
unplugging/replugging the cartridge and doing maintenance cycle
the printer's sensor are acting up and Lexmark won't really share how to reset these things, neither offer "logical" tips... The info given here was pretty much the Lexmark troubleshooting steps...
HTH
Posted on Oct 23, 2008
SOURCE: printer ot ready device is busy
i've downloaded the install disc twice, when attempting to print, i get the "busy at this time" and after troubleshooting on my own, i get a message that reads "no spooling".
Posted on Nov 20, 2008
taran_2005
  • 10515 Answers
SOURCE: lexmark X63 and when I
 Your problem is already discussed in one of the forums available on net.
 The link for that webpage is :-
http://www.fixyourownprinter.com/forums/inkjet/19217
Thanks.
Posted on Jan 30, 2009
  • 43 Answers
SOURCE: lost my printer lexmark x63 software disc. Need
http://downloads.lexmark.com/perl/downloads/downloads.cgi
Posted on Mar 30, 2009
SOURCE: LEXMARK X63 NOT RECONIZING LEFT CART.
I did find a procedure online to clear the memory and that did the
trick. Here it is, may help someone in the future:
Open lid, take both cartridges out. Physically remove the power cord from outlet or back of unit. While pressing the Stop/Clear button, plug cord back and kee pressing until a message saying "clearing memory" comes on. Reinstall ink. You're done, the message should go away.
Posted on Jun 22, 2009
The message "change all ink" displays even when there is ink in both cartridges. The printer will not print.
remove cartridges from printer and put it back again and give new cartridge to the software it will accept
Sep 28, 2009 | Lexmark X63 InkJet Printer
Installed a new Lexmark ink cart and got an incorrect message
take out the cartridge , turn off your printer and take out all the cables behind your printer and wait for 5 minutes and put everything back in.. if the same error shows.. im sorry but your printer needs to be replaced.
Aug 15, 2009 | Lexmark X2500 All-In-One InkJet Printer
Lexmark X5470 software rejects generic ink cartridges
Yes this may be the trick for it.
Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad...
1 - try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
or
2 - when error shows up, shut the printers power off; wait one minute and turn it back on press copy.
Jul 21, 2009 | Lexmark X5150 All-In-One InkJet Printer
May 03, 2009 | Lexmark X63 InkJet Printer
Fix system error
Please click on the below link or copy the URL and paste it in your web browser. Follow the steps..
http://support.lexmark.com/perl/support/support.cgi?ccs=229:1:0:93:0:0&docid=ENUS547
OR
If you are getting any type of 'CLEAR SYSTEM ERROR' on the LCD screen of the printer, please follow these steps:
1) Remove the power cable for 2 minutes and the USB cable from behind the printer.
2) Press and hold down the stop clear button and reconnect the power cable back to printer.
3) The printer LCD screen should clear the memory error.
4) If the same error message persist on the LCD screen, please follow the instructions below.
5) Unplug the power cable for 2 minutes and USB cables from behind the printer and open the printer cover and remove both ink carts.
6) Repeat step 2 and Install both cartridges then the screen will display Cartridge's clean, press start.
Thank you........
Sep 28, 2008 | Lexmark X63 InkJet Printer
I have a Lexmark X3430
If you had brought original lexmark cart you can get it exchanged as it comes with one year warranty you need to contact lexmark support to get your cart exchanged ....
Good luck...
Aug 24, 2008 | Lexmark X2500 All-In-One Printer
Refilled cartridge does not work
First of all lexmark doesnt support refill carts. but what u can do is reseat the carts & then press the options button till u see cart new both. & then select both the blk & clr as new. it should work other wise buy new carts
May 27, 2008 | Lexmark X125 All-In-One InkJet Printer
Printer Ink is Low
If had refilled the ink then this printer as in build sensor which works only once , that reasons your getting this message if your using original Lexmark cart then if your getting this message then you can contact lexmark get the cart replaced as the cart comes with 6 months warranty.
May 16, 2008 | Lexmark X3470 All-In-One InkJet Printer
My X63 printer is not working.
Try clearing the print queue under printer preferences and then try turning unit off and wait, then on again to reset it.
Feb 14, 2008 | Lexmark X63 InkJet Printer
Inputting new ink cartridges
Error 1102 means cart error. Try cleaning the copper contacts on the cart and the contacts in the printer also. If still fails, then put old carts and check if u still get same error. If u dont get the error then there is a problem with the cart itself. But if you have bought a refilled cart then the print heads on the carts are bad. Needs replacement.
Sep 19, 2007 | Lexmark P4350 All-In-One InkJet Printer
Lexmark X63 InkJet Printer Logo
18 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
