Question about HTC Wildfire S Smartphone
8 digit security - HTC Wildfire S Smartphone
  • 580 Answers
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Posted on Nov 04, 2012
Bike will not turn over, security icon flashes alone with the turn signals. Battery test OK.
Have you used the new PIN to manually disable the security system?
Do not turn handlebars, straddle seat or lift motorcycle off the jiffy stand. During a PIN disarm, if the security system detects motorcycle motion the system will activate.
Turn ignition to IGN.
If armed, the odometer window display will read: ENTER PIN and the security lamp will be flashing at a fast rate. The headlight will not be on.
Press and release the left turn signal switch.
In the odometer window, a flashing 1 will appear.
Increment the digit by tapping the left turn signal until the odometer window displays the first digit of the PIN.
The first digit in the odometer will be the first digit in the PIN.
Press right turn switch 1 time.
The first digit is stored and the next digit will flash.
Increment the second digit using the left turn switch until the digit reaches the second digit of the PIN.
The second digit in the odometer will be the second digit in the PIN.
The second digit is stored and the next dash will flash.
Increment the third digit using the left turn switch until it reaches the third digit of the PIN.
The third digit in the odometer will be the third digit in the PIN.
The third digit is stored and the next dash will flash.
Increment the fourth digit using the left turn switch until it reaches the fourth digit of the PIN.
The fourth digit in the odometer will be the fourth digit in the PIN.
The fourth digit is stored and the next dash will flash.
Increment the fifth digit using the left turn switch until it reaches the fifth digit of the PIN.
The fifth digit in the odometer will be the fifth digit in the PIN.
The fifth digit is stored. The security system indicator lamp stops blinking.
Smart Security System is disarmed.
If a mistake is made while entering PIN, turn the ignition Switch to OFF before entering the last digit and then start the procedure from the beginning.
If the procedure fails to disarm the security system, wait two minutes before attempting another PIN disarm.
The security system will remain disarmed until the ignition is turned to OFF.
Apr 04, 2014 | 2005 Harley Davidson FLHTCUI Electra Glide...
Free Unlock Phone Codes HI I NEED ALL MY HIPTOP Q700 UNLOCK CODE MY IMEI IS 357712011128138
To unlock your phone from security code, follow the information from this link.
Also, try these default codes:
Default 5 Digit Security code: 12345 or 00000
Default 6 Digit Security code: 000999 or 1122
To unlock your phone from network loc, read the information from this link.
Feb 13, 2011 | Motorola Cell Phones
Security code
To unlock your phone, follow the information from this link.
Also, you may want to try these default codes:
Feb 12, 2011 | Nokia Cell Phones
I forget my security code now i want to refresh it plz send the code 12345 i try it but donot get the result nokia 6020
Feb 10, 2011 | Nokia 6020 Cellular Phone
My phone is look and i need the security code
If you have not yet changed your default security code, try one of the following codes:
12345 or 00000
Default 6 Digit Security code: 1122 or 000999
Jan 27, 2011 | Nokia X3 Cell Phone
The speaker volume is too low...please can you let me know...as to what the correct settings should be to obtain the loudest sound out of the speaker...as it is too small
Reset your mobile factory setting .
Go>setting >security>factory setting>
First Try it:
Defalt phones codes(NOKIA) is 12345 or 00000 u can use it
Default 4 Digit Security code(LG) 0000
Default 5 Digit user code(SAMSUNG): 00000
Default 6 code for (MOTOROLA)000000 or 888888)
Default 6 Digit Security code: 123456 or 000000 or 888888
Default 6 Digit Security code(SONY ERICKSON) no number
Good by
Jan 06, 2011 | Cell Phones
I need the formatting code
Try these default security codes:
Jan 05, 2011 | Nokia 6111 Cellular Phone
Factory setting password nokian82
These are the default password codes you can use:
Jan 05, 2011 | Nokia N82 Handheld
PNY Optima SD HC Card cannot be read in HP Photosmart 8150 printer.
  1. Verify that the printer is turned off.
  2. Remove the Secure Digital memory card from the printer.
  3. Examine the Secure Digital memory card:
    • Is the lock switch in the unlock position?
    • Are there any visible discolorations or defects such as crack or nick in the card?
    • Are there any contacts missing from the end of the card?
    • Are there any deep scratches in the card contacts?
    • Is there any heat discoloration on the card? NOTE: If all of the above questions result in No , proceed to Step 4.
  4. Check if the HP Photosmart printer supports the file format. NOTE: In order to know which file formats are supported by the different HP Photosmart printers, please refer to the manual of your printer.
  5. (Saving the pictures on the PC, if possible) Insert the Secure Digital memory card in the camera (or another device) and format it following the proper instructions to perform it.
  6. Capture an image.
  7. Review the image. If the image is corrupted or an error such as Unsupported Image File is displayed, the Secure Digital memory card is suspected to be defective and should either be replaced or referred to the manufacturer for further troubleshooting.
  8. If the images are read properly, turn on the printer. Insert the Secure Digital memory card in the Secure Digital slot.
  9. If the printer display continues to show the Card Not Recognized error, try using another Secure Digital memory card, if one is available.
  10. If the printer is still unable to read a functional and compatible Secure Digital card, contact HP to obtain additional troubleshooting information.
Oct 05, 2010 | PNY 4GB Secure Digital High Capacity...
Nokia 3585 security code lost and how to unlock network ?
Check out this link below to download a PDF manual, software, and more for your phone. Just copy and paste into your browser.
http://www.nokiausa.com/get-support-and-software/product-support/nokia-3585
SECURITY CODE from page 54 of your manual:
Your phone prompts you for a five-digit security code for certain features and commands.
Access is granted only after the correct security code has been entered successfully.
The default security code is 12345. It is recommended that you change this code at once,
write it down, and store it in a safe place away from your phone.
Important: When entering your security code, ***** is displayed on the screen to
keep others from viewing your code.
You can delete the last entered digit by pressing Clear (or by pressing and holding Clear to
delete all the digits more quickly). Enter the correct code or press Back to exit. If you enter an
incorrect security code (Code error will appear) five times in a row, your phone won’t accept
any entries for the next five minutes.
Change your security code
1 Press Menu 4-5-2-4 (Settings > Security settings > Access codes > Change security code)
and press Select.
2 Enter existing (or default) security code and press OK.
Security and System settings
3 Enter new five-digit security code and press OK.
4 Re-enter your new five-digit security code for verification, then press OK.
Your phone displays the confirmation message Security code changed.
Important: If you change your security code and don’t remember the new code,
contact your service provider. Once you change your security code, the default code
is no longer valid.
Hope this helps, let me know if I can help you with anything else. It would be very kind of you if this does work for you to please rate me or leave a short note. I would really appreciate it. Thank you for your time.
JimmyC
Oct 19, 2009 | Nokia 3585
HTC Wildfire S Smartphone Logo
41 people viewed this question
Top HTC Cell Phones Experts
Ashutosh Khandelwal
Level 1 Expert
D. E. Hev
Tech Leprechaun
Tech Leprechaun
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
