Question about Intel Motherboard
The computer loads up but the screen stays black with a green line down the side
  • Intel Master
  • 3,606 Answers
Hello you have a bad screen.
The screen must be replaced, and it cost around 200 dollars.
A computer repair shop, can do the repair for you.
Good luck
Posted on Jan 23, 2013
It appears something is wrong with the green tube. The picture comes on and then the green tube flashes and the TV shuts off and the LED blinks 8 times
This set has a history of bad picture tubes but there is an adjustment you can try to see if it will buy you some time to use the set further.
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Here is what you need to do.
1.) You need to remove the entire plastic piece below the front of the screen. You most likely will find 3 screws on either side in back that you have to remove.
2.) The grill will not come out easy, pull from one side and then when it starts to come loose from the other side(there are several plastic pegs that hold it in.) Then from the bottom pull out( most of these sets have square plastic tabs at the top that tuck in.)
3.) With the grill removed locate the inspection plate behind it (it usually has 6 screws.) You will have to tilt the grill to the left and on its side as several cables are connected to it--they are held in place with trash bag like ties that you can release to get some room.
4.) With the inspection plate removed you will see a fairly small (about 3 inch square) BLACK PLASTIC BLOCK WITH SIX CONTROLS-usually they are marked with whiteout so someone can tell if they have been adjusted.
5.) You need to look very close at the block with a flashlight----usually the top three controls are FOCUS--don't touch those.
The lower three are usually marked Screen and if you look very close you will see b, g, r(blue green red)
6.)Usually the GREEN will be in the middle.
7.) Once you locate the GREEN screen control have the set on and turn it down--if the set is shutting down you may have only a few seconds to try to turn it down---usually to the left with the Screen control.
8.) Best way to do this if the set is on is on a video input clip_image001.gif with nothing connected--you turn the Blue screen down until the set stays on and then very slowly turn it up until you see a slightly Blue screen with or without diagonal trace lines----turn it down slowly until the GREEN screen and trace lines just disappear.
Let me know if you get it to work--Like I said if it is shutting down you may have to slowly turn the screen down a few times to get it to stay on.
Regards, SD TECH
Apr 03, 2010 | Sony KP-51HW40 51" Rear Projection...
I have a kp65ws500 that turns on for about 5
These sets have a history of bad picture tubes-the tubes are only available on a rebuild basis and very expensive.
there is an option:
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} SONY SCREEN ADJUSTMENT:
7.) Once you locate the green screen control have the set on and turn it down--if the set is shutting down you may have only a few seconds to try to turn it down---usually to the left with the Screen control.
8.) Best way to do this if the set is on is on a video input clip_image001.gif with nothing connected--you turn the green screen down until the set stays on and then very slowly turn it up until you see a slightly green screen with or without diagonal trace lines----turn it down slowly until the Blue screen and trace lines just disappear.
Regards, SD TECH
Mar 08, 2010 | Sony KP-57WS500 57" Rear Projection...
Turn tv on screen goes green and turns itself off in seconds
you may have a bad green picture tube, it is something this model is prone to but there is something you can try....
8.) Best way to do this if the set is on is on a video input clip_image001.gif with nothing connected--you turn the GREEN screen down until the set stays on and then very slowly turn it up until you see a slightly GREEN screen with or without diagonal trace lines----turn it down slowly until the GREEN screen and trace lines just disappear.
If this has helped you rate this solution as I do this here for free.
Regards, SD TECH
Dec 22, 2009 | Sony KP-51WS500 51" Rear Projection...
TV has Green Background instead of Black
6.) GREEN will be in the middle.
8.) Best way to do this if the set is on is on a video input clip_image001.gif with nothing connected--you turn the green down until the set stays on and then very slowly turn it up until you see a slightly green screen with or without diagonal trace lines----turn it down slowly until the green screen and trace lines just disappear.
if this information has helped you, rate this solution as I do this here for FREE.
Regards, SD TECH
Nov 27, 2009 | Sony KP-51HW40 51" Rear Projection...
Ds lite flashes on but fuses are ok
One or both your screens have blown.
Try removing the motherboard from the screens and attach the battery the green light should turn on and stay on.
Now attach the lower screen and turn on. If the screen is ok the screen and green light will flash and then turn off. (if the screen doesn't flash the bottom screen is you're problem and will have to be replaced)
If this happens the problem is then you're top screen which you will have to replace.
Jul 26, 2009 | Nintendo DS Lite Console
I have an inspiron green lines running down the start up screen
You need to try to log into safe mode. if its running win xp please hold the f8 key down and it should prompt you to go to safe mode. If safe mode lets u in all the way. you need to update your video drivers.
Apr 15, 2009 | Compaq Presario M2000 Notebook
Screen seems to be not working properly
try using a different monitor, borrow one if you have to, if the monitor works on your computer, then it simply means you need a new monitor. As far as the computer shutting down, it may be recording the bad monitor as an error in the loading process and automatically shutting down.
Mar 15, 2009 | HP TouchSmart IQ770 PC Desktop
Screen is black with blue/green lines
please send me a solution for that i can get to the menu and i can take th volume down it is stay up
Nov 15, 2008 | TruTech PLV16190 Television
Intel Motherboard Logo
53 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
