Question about Safety 1st Playard - Hartland Travel System Stroller
How to fix rail lock on pack & play
One side rail does not lock i can feel spring and hard plastic part inbetween material
  • Safety 1st Master
  • 1,629 Answers
This isn't a product available in the UK so we're unable to assist with your enquiry. Could you let us know what country you're in so we can direct you to the appropriate customer care team?
Posted on Mar 02, 2013
Graco posey pack n play side won't lock in
I've had this problem b4 and all I had to do was to **** it up really hard and fast, then it would catch and lock. Hopefully it will work for you too. Good luck! :)
Jul 11, 2012 | Graco - Pack N Play with Newborn Napper -...
The bottom drawer does not lock, the plastic spring catch on the right side rail (rear) is "sprung" before the drawer is fully engaged, suggesting that something is in the way and pushing closed the...
I am slightly unsure of the problem you are having with the bottom drawer.
Not sure which plastic catch you are referring to. There are no locks in the drawer. It slides on the rail and shuts against the face of the housing. On start (when ON is pressed) the lid seal decends from the top and locks the drawer so that water does not leak during operation.
Have you actually taken the drawer out from its rails? Are you please able to take a photo and attach to your comment.
Oct 10, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
How do you put up a graco pack play
Hi, to set up the pack and play, first latch each of the four sides together. (Each side rail latches together in the middle -- just straighten the rail.) Once all four sides are locked and straight, push down on the center of the pack and play bottom (it's probably red) until it snaps into place.
To fold the pack and play up, just follow these instructions in reverse -- pull the bottom up first, then press in the button on each side rail to fold up each side.
Always make sure the pack and play is completely set up and locked before putting a child in it!
Aug 02, 2010 | Graco 9445DOH Crib
How cani open graco play pen
To open the Graco Pack 'n Play from the folded position, you have to latch each side rail by pushing the two ends of each rail until they are horizontal and form a straight line. They will latch into place with an audible snap -- do this for each of the four sides. Then push the center of the Pack 'n Play's floor down until it is flat as well.
If you can't latch the side rails, the floor of the Pack 'n Play might be down too far. Push the floor up until its center reaches at least halfway up the sides of the Pack 'n Play. (You can do this by pushing the sides of the Pack 'n Play in toward each other.)
Were you able to open it using these instructions?
Jun 24, 2010 | Graco Pack 'n Play
How do you set up a pack and play?
Open it part way but do not push the center of the bottom all the way down. Raise each of the side rails and make sure they lock in place in the full up position, When all four side rails are locked in place, push the bottom center all the way down until it locks. Put the the bottom pad in place and secure it with the velcro tabs through the opening in the sides.
Jul 06, 2009 | Baby Gear
How do i get the sides to lock/ stay up on my Graco Pack and Play?
I think the problem is the way that the safety feature prevents the locking mechanism from moving while the bottom is flat Be sure that the bottom is raised about half way and the rails should lock (or unlock) for you. Hope that helps. wdeblancjr@aolcom
Jun 13, 2009 | Graco Pack 'n Play
I bought a pack and play at a rummage sale and
Believe it or not, the rails will not lock unless the bottom is slightly raised up. Then you can flatten the bottom. Unlocking works the same way, be sure that the bottom is lifted up partially. Hope that helps, I had the same problem.
Jun 12, 2009 | Baby Gear
Directions to set up a pack n play crib
you have to pull the sides up and lock them before you push the bottom down
Dec 27, 2008 | Baby Gear
Kinderkraft crib model 710
On the bottom of the front rail that drops (the drop rail), there are two plastic tension pieces (one at either end) that engage the two fixed, bottom rail slider hardware (the long, narrow pieces screwed top-and-bottom into the lower, inside portion of the tall, upright crib ends). These tension pieces are spring loaded, and the outer edge of each one rides along the outside (i.e., the parent's side) of the two bottom metal rail guides. Their purpose is to supply outward pressure against the lower part of the drop rail - that's what you push against when you press your lower leg upon the bottom of the drop side of the crib to lower it. They insure that when up, the drop side locks safely into place. I suspect these tension pieces are your problem. It sounds like they are improperly installed. Good luck.
Sep 10, 2008 | Kinderkraft Vermont Crib
Graco pack and play sport
I saw the solution on the Graco site. I was putting the bottom of the Pack and Play down first, I found out you need the do the sides firstl
Apr 27, 2008 | Graco Ultra Deluxe 5-in-1 4605 Crib
Safety 1st Playard - Hartland Travel System Stroller Logo
159 people viewed this question
Top Safety 1st Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you a Safety 1st Baby Gear Expert? Answer questions, earn points and help others
