USB HD no longer recognized by Vista or XP
I have a 250GB drive I used on Vista for a year its now on an xp and worked now neither can see it when you connect it. Vista found it after many tries yesterday, so I hooked it up to XP with no success. Now on Vista again it can see the drive but not the files. It reports the driver is working fine. I need to recover all the files on here and transfer them to another HD if I can get it to read them like yesterday.
  • 4 more comments
  • fasted_e Jan 04, 2009
    I've tested on two PC's one Vista one XP, both have other USB hard drives connected and working fine. This one worked for about a year. Yesterday after much struggling I managed to get Vista to read it, I should have copied the files then but neglected to.
    No software came with this drive, it's just plug and play. Vista recognised a connection in exporer but reports no files. When I unplug the USB and reconnect it reports USB device not recognized, yet reports the drivers for the device are OK?
    Thanks Marked, changed the USB cable and opened in my computer, no fix, it still doesn't see it? Any other ideas?
    Thanks coolguy 008. I'm testing on my Vista PC as it was originally connected to it and it was the only PC to find it after much struggle yesterday. Does you procedure work the same way on Vista or do I have to work off the XP?
    coolguy008, can you repost you fix, I rec'd another suggestion but can't backup and find yours?
  • fasted_e Jan 05, 2009
    I have a 250GB drive I used on Vista for a year its now on an xp and worked now neither can see it when you connect it. Vista found it after many tries yesterday, so I hooked it up to XP with no success. Now on Vista again it can see the drive but not the files. It reports the driver is working fine. I need to recover all the files on here and transfer them to another HD if I can get it to read them like yesterday.Coolguy008 can you repost your solution from yesterday. I've tried a different USB cable and all USB port with no success.
    Scholar:
  • 155 Answers
You can try to go to www.recovermyfiles.com
You can download the software and run a scan. The trial version allows you to see what files can be recovered. So dont buy the software unless it shows that you can recover your files.
Posted on Jan 05, 2009
  • Rachelle Aviles
    Rachelle Aviles Jan 05, 2009
    Of course it's only gonna work once the hard drive is detected. It sounds like a faulty drive and the only thing you can try to do is to save the data. If you cant get it to work even on another computer, you can try to contact Drivesavers (800.440.1904), Ontrack or you can google for other companies who specialize in data recovery. They're pretty costly, but if you're files are very important, it's the only way to go.
    President:
  • 846 Answers
If you are trying it on different PC's i don't see all the USB ports on both computers being messed up. I would think it was something wrong with the Harddrive itself.
Do you hear it spinning when its plugged up and powered on ?
If you have access to the Administrative Tools( In Start/ Control Panel), go to Computer Management. Under storage, there is a Disk Management section. This will show all of the drives found by Windows. My Computer and Windows Exporer only display drives that are initialized and ready for use. Drives found and recognized by the PC are listed in Disk Management. They won't show up elsewhere in Windows until they are properly initialized. This comes in handy for troubleshooting because if a HDD is not found in Disk Management or found in Disk Management but not Windows Explorer, then you are having a HDD issue. If the HDD is found in both, then you are likely having a windows issue.
You could try removing/deleting the USB controllers from Device Manager and reboot. This will force Windows to reload the USB devices and drivers. You could also verify and/or install the latest MB drivers, which should include USB drivers.
And then there is the obvious stuff, like a bad USB connector in the PC, a bad USB connector on the ext HDD, or a bad USB cable.
    Genius:
  • 1,239 Answers
Hi
Boot the pc with erd commander (the one with XP) with the hard disk plugged in, and so you should access the hdd, then erd has also a tool to administrate the plugin, uninstall all these hdd plugin you have installed, then reboot without the usb hdd plugged, and when XP loads, plug this HDD to another USB. This should force XP to install again the drivers (that generic from XP) that uses to work.
  • ABHISHEK.C
    ABHISHEK.C Jan 05, 2009
    maxtor is haivng simialiar issues but mine only shows up in device manager gor liek 2 secs after uninstallin and reinstalling. What have you tried maybe we can help each other. On XP i have these issues on vista maxtor just is not supported
  • ABHISHEK.C
    1. In C:\Windows\System32\DriverStore\FileRepository I had two folders
    named "usbstor.inf" but each one had a different set of numbers
    attached to the end of the folder name. - could this be where part of
    the problem lies?
    2. When i looked in my C:\Windows\inf folder i discovered the
    usbstor.inf and usb stor.pnf files were missing - this definitely had
    to be an issue.
    Once I discovered these anomalies, I proceeded to copy the pnf and inf
    files from the most recently updated usbstor.inf folder to C:\Windows
    \inf. I then went back to the update driver wizard, pointed to the inf
    folder and what do you know but they all started working again.
    Worked for me!
    Hope this helps.
    Novelist:
  • 176 Answers
I had the same similar problem before. It was because the actual HD connector inside the enclosure was loose and was not properly seated hence not giving full contact to the little system board which transmit electrical signals to the USB port
Posted on Jan 04, 2009
    Genius:
  • 2,920 Answers
You might try re instaling windows and then connect to the usb again,,,you should be able to do it on either computer if you have the disks that should have come with the comuters,
    Scholar:
  • 100 Answers
If you try another computer and it doesnt work, there's a last resort option which is the following:
inside the case that contains the HDD is a normal HDD which has an IDE connector just like any HDD used on desktops. open it up take out the adapter board which converts it from IDE to USB and then use the normal HDD inside that has an IDE connector. set it up as Slave using the jumper diagram drawn on it and connect it on a normal PC as a second HDD, start your PC and you should be able to read and back up all data on the HDD.
after you're done, make sure to back things up on DVD's or CD's and make regular renewed copies of those DVD's or CD's so that you make sure your data is safe.
  • 2 more comments
  • Anas Al-Mustafa
    Anas Al-Mustafa Jan 04, 2009
    did it come with an external power supply ? if it did, unplug the power cable from power socket and short the two or three leads on the power cable for 5 min while other side is connected to the HDD. this will discharge any extra charge on the capacitors inside the HDD electronics, then connect. it sounds funny but it works and happened to me with many USB devices. where USB DEVICE NOT RECOGNIZED keeps poping up.
  • Anas Al-Mustafa
    Anas Al-Mustafa Jan 05, 2009
    if non of the above solutions worked, make sure to read the last resort plan that i wrote for you :) let me know if you need any help with that !!!
  • Anas Al-Mustafa
    http://soft.softoogle.com/ap/easyrecover...
    this link is for Easy Recovery program. download it and try to recover lost data on Vista ( use Raw recovery option to get all file types back). for office files it has a file repair that you have to use after recovery to get them working.
  • Anas Al-Mustafa
    If all solutions fail. remember to do my last resort solution, it worked for me before and never trusted or used a USB HDD after that.
    President:
  • 1,952 Answers
There are several ways to retrieve data that has been deleted from a computer system, even if you've deleted them from the recycle bin or reformatted your hard drive.
When you delete a file, Windows only marks the file as deleted, but doesn't actually remove it from your system. Those files are only truly deleted (well, replaced actually) when other data is saved to the same location on your hard drive.
The reason our deleted files were recoverable is that no other data had been saved to those same places on the hard drive.
How to recover files that have been deleted: If you've accidentally deleted an important file or erased a folder containing files that you later realize you still need, don't worry. Chances are good that they're still on your system and in good shape.
You'll need a good data recovery program that can find files that have been deleted. I've tried a few different programs that claim to be able to do this, but have discovered that some of them are only able to show you what's still in your Recycle Bin. That's not much help if you've emptied your Recycle Bin, so I wasn't impressed.
  1. Delete a file or folder
  2. Empty out the Recycle Bin
  3. Run the data recovery program and see if it's able to find and recover the file.
I did this test with iRecover and discovered that it was able to not only find the test file I had deleted, but it also found hundreds of files from folders that I remember deleting several days ago.
iRecover is an advanced data recovery program that will help you recover data that was lost because of file system corruption, formatting, virus damage, partition deletion... or in my case - user error.
Here's a screenshot of iRecover that shows all of the files and folders it was able to recover after completely clearing out my Recycle Bin:
    Genius:
  • 3,422 Answers
Try connecting your drive to another USB port. Using one port all the time to connect and disconnect USB items a port can develop a range of files associated with configuring the USB connection. Some of these files might actually have been from your drive connected before, or some of these configurations could be from other USB items you connect to this port. Changing ports can often lead to an immediate good connection simply because ther are no conflicting configuration files. If this does not solve your problem, we can now entertain the next process to try.
THIS IS A BIG ONE. This is the last thing to do. Before you try this process, please complete a full back up of your system. This is important as the next step can have side effects you did not entirely expect. AND Second, you might need your XP Install Disk (not in all cases). What this process is about is renewing all hardware/software configurations relating to USB connections.
Here is what you do:
1. Right click MY COMPUTER
2. Select PROPERTIES
3. Select HARDWARE
4. Select DEVICE MANAGER
5. Select UNIVERSAL SERIAL BUS CONTROLLERS
6. Right click on each USB CONTROLLER and select Uninstall
7. Uninstall all entries
8. Reboot your computer
9. As your computer re-boots it will reinstall all USB connections it detects
THEN, when all other USB items have been configured and connected by the system, you then should try connecting your USB drive.
If these suggestions are implemented and you are still have connection difficulties with your computer, there are several other things to try. If you have another XP Computer you should try connecting your drive to another computer to see if the problem is a drive problem or not. If it still has this problem with the next computer, it maybe be a fault of the drive
IF YOU HAVE COMPLETED ALL the above mentioned and still have a problem, you should next contact the seller of this machine for further instructions of what to do next.
  • Priya darshan Jan 04, 2009
    Alright here it is again.please take a moment to accept the solution:
    Try
    try.
    THIS
    3. Select HARDWARE
    If
    fault of the drive
  • 6,487 Answers
If possible for you to change the usb cable that you;re using so we can check if this is only a problem with the usb cable, you can also right click Mycomputer and go to Manage and look there for the removable drive and check if its listed there ifits there open the drive from there....
  • Mark Gil
    Mark Gil Jan 04, 2009
    If its still not detected try also to connect it different usb port on the windows XP and Vista and while its connected restart the computer and hopefully it will be detected after you restart the computer while the drive is connected to it....if still no you can send that drive to the manufacturer and they cna still recover the file for you....
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 448 Answers
It is my understanding that Vista and XP don't like each other. That being said, If it came with software, reload it.
  • bob collins
    bob collins Jan 04, 2009
    Do you know how to get system to show up on your pc. If yes, Plug it in and see if system SEES it there.
  • 19,396 Answers
Test first the hard disk on a different computer, this sounds more like a faulty hard disk.
  • 1 more comment
  • Ginko
    Ginko Jan 04, 2009
    I quote from you: "Vista found it after many tries yesterday, so I hooked it up to XP with
    no success. Now on Vista again it can see the drive but not the files." that is a faulty hard disk.
    If the fault is logical (bad sector, damaged FAT etc, you can attempt using dedicated software to access the hard drives. This often does not work.
    If the fault is mechanical (motor, heads , etc) you need to spend at least $600 to recover the files, as to open an HD with internal faults we use a special facility that is very expensive.
    The first thing to do is extracting the hard disk from the USB caddy enclosure, and testing it on a different enclosure.
    If you are lucky enough the control board inside the enclosure had gone faulty, and the hard disk is still good, with all files inside.
    If not, files are usually lost, unless you are prepared to spend some big money for the recovery.
  • Ginko
    Ginko Jan 04, 2009
    Well that was the truth, I fix this things for living.
    " This one worked for about a year. Yesterday after much struggling I managed to get Vista to read it"
    That is either defective controller board inside caddy, or faulty disk with damaged FAT, surface problem, logical error.
    Test the disk on a different caddy, or inside a PC, if it does read recover files, if it doesnt, well I told you.
    You can refuse it but that is the truth .
    Goodbye.
  • Ginko
    Ginko Jan 04, 2009
    I am reposting coolguy fix, you find whole comment checking back your emails:
    3. Select HARDWARE
    That works when usb is defective. your usb is not defective.
My computer will not recognize the drive. Does it have to be connect to a power supply? I have it connected to a usb port
Windows 7 does not recognize SimpleTech 250GB external USB drive ...
answers.microsoft.com/...does-not-recognize-simpletech-250gb/f7ceccd0...
Just bought a new computer, running Win 7. Drive worked fine on Win XP. ... Windows 7 does not recognize SimpleTech 250GB external USB drive ... I find it hard to believe that a external USB 2.0 drive can't work with Win 7. There must be ...
SimpleTech dvi hdmi pc Hard Drives Questions & Answers ...
www.fixya.com > Forum > Tags > dvi hdmi pc > Hard Drives
Question about SimpleDrive 160 GB External USB 2.0 Hard Drive ... Question about250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive ... my PC does not recognize the external drive 96300-40001-001 Driver Problem: Check whether ..
Dec 18, 2015 | SimpleTech SimpleDrive 250 GB External USB...
Hp 250 GB Pocket Media drive having erratic behaviour under Windows 7 (Motherboard ECS G41chipset), Under windows XP front and back USB ports recognize disk as USB 2.0 device - able to read and...
XP is a dead OS.
100% dead. and not supported now. by MS or HP.
but XP needs SP3, or USB will be bad
XP always had bad USB for years until , all patches were done.
The USB on XP are horrible.
you need good USB so all devices are PnP recognized
and negotiated currents (power) is working
and USB2 currents are weaker than USB 3.
and is key to making any motor driven HDD work right.!!
Dead as a door nail and no more security patches ever again.445635a4-18b0-42a5-a249-084bb91c84b0.jpg
Apr 04, 2017 | HP 250GB Pocket Media Drive 250 GB Hard...
Simple Tech HD failing- takes 4 hours to tranfer 512 MB!?
Not exactly a solution but I have had the same problem with one of these Simple Tech Signature Mini 320's for a while. Real finicky. Will only be recognized on direct connected to MB USB ports and even then with Win 7 or XP I get the "This USB device can perform faster if you connect it to a Hi-Speed USB 2.0 port." no matter what ports I connect it to. While having this issue on this "main" computer I have previously connected it to some other computer (don't remember which, now) and it connected at 2.0 speed. What's going on??
Jul 16, 2010 | SimpleTech Signature Mini 250GB External...
My external hard drive does not work on windows xp
You might need to initalize it in XP and then assign a drive letter.
Aug 29, 2009 | Iomega 250GB Ego HD USB 2.0/FW Red 250 GB...
Verbatim portable hard drive not recognized by XP - works in 2000
Restart XP and connect e/hd and it should pick it up. Some systems are plain lazy after a while, so manually install it.
Aug 27, 2009 | Verbatim SmartDisk Firelite Portable USB...
250 GB Western Digital external HD not detected by Win 98 SE
If you installed SE on Win 98, then here is a link to a generic USB driver that should work with your HD. If at some point you decide to install a newer OS or go dual-boot, you can always partition the HD so you don't lose any storage. Best of luck.
Greg
http://www.technical-assistance.co.uk/kb/win98se-usb-mass-storage-drivers.php
Jun 14, 2009 | Western Digital WD Passport 250GB Portable...
Laptop Won't Recognize External HD
You can try opening the device manager in Window XP and uninstall the external hard disk (make sure you show unplugged devices).
Then replug the drive again, and it should reinstall the drivers.
Jules
Feb 22, 2009 | Beyond Micro Mobile / 250GB / 7200 / 8MB /...
Lacie 250GB Hard Disk is not being recognized by PC (Windows XP)
Some PC's cannot deliver enough power to the USB devices to function properly through the USB port.
Does your Lacie hard disk have a power input connector if so conect a power adapter to it before you put it into your USB port.
Another alternative, get a powered USB hub connect it into your computer then connect the Lacie hard drive to the powered USB hub.
Jan 03, 2009 | LaCie (300728U) 250 GB Hard Drive
Lacie 1tb hd
You can try to boot up with Linux LIVE cd and plug on the external HDD.
Apr 24, 2008 | LaCie d2 Extreme 250GB External with...
Computers & Internet Logo
David Payne
David Payne
