Kyocera cs305 Host Name does not exist. (0x1101)
Adjust the throttle on my echo cs305 chainsaw
Toni,
Can you give me a little more information on your problem. Are you having a problem with the throttle linkage or is it a carburetor adjustment question?
Dec 31, 2014 | Echo Cs305 Cs 305 Carburetor Intake &...
Copy and prints all black pages
Are you saying you installed the maintenance kit and then this started happening? My immediate reaction is the main charge corona is dirty, shorted, arcing down, or otherwise failing.
Aug 14, 2013 | Kyocera 300k Kit Copystar Cs305 Cs255...
Error 1101
This scanning problem usually referes to the printer not finding the host pc when try to establish contact before a scan is sent to the pc. Access the device through the browser and check in the profile for that pc in your address book whether the pc name is spelled correctly in the host field at smb scanning. Sometime it will be an option to use the pc ip address instead of the computer name ( provided it is a static ip address. ) this should resolve the problem
Apr 04, 2013 | Kyocera Mita Kyocera-Mita SCANNER RACK...
Failed to send via SMB
What model copier? What error code? What OS?
Jan 17, 2013 | Kyocera Office Equipment & Supplies
Kyocera 5050 error code 2202
This is an error is indicating a connection error when using the send feature.
Below I have provided some information or for more information download the users guide from the manufatcures website using this link. http://usa.kyoceramita.com/americas/jsp/Kyocera/resource_details.jsp?pid=16088&rid=16313
2101, 2102, 2103, 2201, 2202, 2203, 3101:
The network cable is disconnected or the hub that it is connected to is not operating properly. Check the cable and the hub. Otherwise, the server name or the host name of the SMTP server is
not set correctly. Use COMMAND CENTER and register the SMTP server name and the host name
correctly.
2204: The E-mail size exceeds the acceptable send data capacity. Decrease the size or resolution of the scanned data to be transmitted and resend the E-mail. 5101, 5102, 5103, 5104, 7102, 720f:
Turn the main power switch off and back on. If this error occurs several times, make a note of the displayed error code and contact your service representative.(Refer to the corrective action for the error message " An error has occurred.")
9181: The scanned original exceeds the acceptable number of pages of 999. Send the ecess pages separately.
Hope this is helpful,
Shawn
Mar 11, 2011 | Kyocera Mita KM-5035 Printer
I have a KM 4050 and when we scan it is giving a "send error 2101" Everything else is fine. We are able to print from our computers etc. so I know our connections are ok. Any suggestions?
The following errors are simalir;
2101, 2102, 2201, 2202, 2203, 3101:
The network cable is disconnected or the hub that it is connected to is not operating properly. Check the cable and the hub. Otherwise, the server name or the host name of the SMTP server is not set correctly. Use COMMAND CENTER and register the SMTP server name and the host name correctly.
The link below takes you to Kyocera's Scan to SMB setup guide on GFBM's website (they are a Kyocera dealer). The guide setup guide is good and gives pictures and examples.
http://gfbm.net/Documents/self_help/SCAN%20TO%20SMB%20PC%20setup%20R3.pdf
I hope this is helpful,
Shawn
Feb 11, 2011 | Kyocera Copystar CS-1820 Black and White...
I am getting an oracle error while trying to login. The error says: ORA-12545; Connect failed because target host or object doesnot exist. What could be the probable error?
ORA-12545: Connect failed because target host or object does not exist Cause: The address specified is not valid, or the program being connected to does not exist.
Action: Ensure the ADDRESS parameters have been entered correctly; the most likely incorrect parameter is the node name. Ensure that the executable for the server exists (perhaps "oracle" is missing.) If the protocol is TCP/IP, edit the TNSNAMES.ORA file to change the host name to a numeric IP address and try again.
Aug 16, 2010 | Computers & Internet
I want add a KM-2550 as a printer on an XP machine. I know what the host name of the KM-2550 is. The KM-2550 is definitely on the network because I pinged it from the XP. How do I find the name of the...
u can come to know from the server
where its physically installed
goto printers and faxes
then oen printer properties
and there is a tab named shared
see the name there
and write it
and then
u can add to the other macine
and can install
Jun 18, 2010 | Kyocera Mita KM-2550 All-In-One Laser...
I have Kyocera Mita KM-2050
you need to get the i.p address of your scanner and access it from your browser.
on the bottom left of the command centre menu you will see SCAN TO PC  "destination" .
put your details in new screen. if you are using a static i.p address for your pc put that in.
if you are running dhcp you should use the host name of your pc
Jan 13, 2009 | Kyocera Mita KM-2050 Printer
Kyocera FS1118 mfp
FS1118 scanning issue - this may sound like a long process but its easy...
Just create a folder called scans in your c:/ drive right click and share the folder
Go to the kyocera command centre (type the ip address of the machine into your browser, taking note your machine must be networked)
Once in kyocera command centre
Click on basic
on the left menu select address book, contacts
create a new contact and under SMB
only insert your computers IP address in the host field
and insert the file name scans in the path field.
Click submit...
Once complete go to your machine
insert a page to scan, select the send button
press the address key
select the contact you created
select ip address press enter
now press 2 on the keypad
press enter
press 2 again
enter again
and then press the green start button once complete..
The scanned document will appear in the scans folder
Aug 01, 2008 | Office Equipment & Supplies
2,080 people viewed this question
jasbo
jasbo
