Question about Cub Cadet Riding Lawn Garden Zero Turn Tractor
Drive wheels on my rzt 50 get stuck if i stop mowing and then try to start again
  • mark bertolami Nov 03, 2012
    i just fixed my own problem...I always assumed it was a expensive pump problem. the brakes were just getting stuck one side at a time so that was confusing me. if anyone has same issue let me know
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 107 Answers
Just needs slight adjustment very common
Posted on Nov 22, 2013
2 Suggested Answers
  • 146 Answers
SOURCE: I have a Cub Cadet RZT 50 mower. The left drive
First, check the level of the hydraulic fluid (usually the dipstick is right inside the fill cap, and you just raise the seat to access it). If it's low, fill 'er up with the right fluid.
If that's OK, test if the lack of 'pull' affects the left wheel in both forward and reverse -- try going up a hill forward, and backing up it in reverse. If it affects both directions, maybe you will be lucky -- the problem could be that the bypass for the left hydraulic motor has opened somehow. (The bypass is used to let you push the mower by hand in case of an engine failure, etc.) So look for a fat-headed bolt sticking out of the left hydraulic motor. Check that it's tight -- rotate it just like you would tighten a bolt, clockwise. If it wasn't tight, that may be the problem; just tighten it and try the mower.
If this doesn't resolve it, you probably have a problem in the hydraulic valves, hoses, or motor, and a trip to the dealer is needed. Probably won't be cheap, sorry my friend. Good luck, and please rate if this was helpful, thanks!
Posted on Jun 04, 2010
Why won't my mower mow? Replaced the clutch & pto switch on cc rzt 50 still won't mow
May have a safety switch problem. Check brake controls, or look for other safety switches. Check for voltage at clutch. Do so with engine off and seating on seat, turn on key to run position and engage blade switch, should hear clutch engage. If it doesn't then check for voltage at clutch and if no voltage work your way back from there. Follow wires back until you find your problem.
Aug 16, 2014 | Garden
New pto switch stoped working after 4 mowings
Maybe the problem wasn't the PTO switch. My Cub Cadet RZT PTO would disengage when I backed up and then failed to re-engage. I was able to isolate my problem to the safety switches at the base of the steering levers. I sprayed them with WD40 and they've been fine. Just a thought and worth checking. I hope this helps.
Jun 15, 2014 | Mustang Rzt 50" Zero Turn Riding Lawn...
Why when riding along mowing and the blades just quit turning, belt is not off?
If you hit a bump too hard, I believe it's equipped with a shock sensor that shuts down the blades or if you slightly lift off the seat the blades will shut off. If this is the case simply stop and restart the blade switch. Hope this helps
Jun 08, 2014 | Mustang Rzt 50" Zero Turn Riding Lawn...
The mower deck on our Cub Cadet RZT 50 mower stopped working while mowing. We have cycled the PTO switch several times with no change. The belt is in place and the mower blades rotate freely by hand. The...
You can check the clutch by taking a wire from the ground and a wire from the positive side of the battery and energizing the clutch directly with the belt off to see if thats it. It could simply be a wire loose in the connection on the clutch....their soldered on.
May 30, 2010 | Mustang Rzt 50" Zero Turn Riding Lawn...
Cub Cadet Riding Lawn Garden Zero Turn Tractor Logo
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
roeb
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
