Question about Whirlpool AWM8000 Front Load Washer
Whirlpool awm8000 will not start
Checked water supply turned off then back on disconnected power then reconnected
  • Simon Dickinson Nov 03, 2012
    No, nothing happens at all when I press the start button
Tengo una lavadora wirpool modelo AWM 8000 la pongo en funcionamiento y se enciende y apaga sola con lo cual el programa no camina
Posted on Nov 28, 2013
In-door water dispenser for Whirlpool ED25UEXHW00 stopped working
Sounds like the water valve for the water dispenser is not opening..You can search the internet for you model number and order a new valve online..I just order a duel water valve for my whirlpool and it was 80 dollars..Got it from www.partselect.com Hope this helps
Mar 16, 2017 | Whirlpool Refrigerators
I disconnected and reconnected the cobra 29 nw ltd classic and now my voice is heard very low and slow it was working fine just before disconnection. can you help
How did you disconnect it?? Antenna wire?? Power supply?? Microphone?? May be that you have a short in your coax in back of radio. Try taking it loose and screw it back in. Try new coax. Turn up Mic gain knob or change microphone. Make sure power wires are connected RED to RED(+) and Black to Black(-). Try grounding radio to metal ; if inside house ground to metal water pipes, filing cabinet, breaker box or meter box or 8 foot rod into earth. Measure SWR it should read 1.1 to 1.5. Measure power supply with Voltmeter it should be 12 to 15 volts. Check antenna plug in back of radio is my guess or microphone itself.
May 09, 2011 | Cobra 29 LTD CB Radio
I cleared my outlet pump (Whirlpool AWM8000) area of coins, etc. Since as it was come up with error FP (drain fault). It drains during wash, but the last part of wash (last 5 min) it make a noise and error...
I would still suggest you go through the whole action all over again JUST to make sure that something hasn't been 'released' into the filter or the pump area. As the pump is managing to drain most of the water I wouldn't think that it is at fault. I would be interested to know if the 'error' is the same- 'FP'(?).
Here are my pre-typed complete (sorry!) guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
John C
Mar 30, 2011 | Whirlpool AWM8000 Front Load Washer
Orange light 3 flashing
Check your power supply cables Your power supply cables may not be fully secured. Let's unplug and reconnect your power supply
  1. Disconnect the power cord from the back of your console. Unplug the power cord from the wall outlet and the power supply unit.
    Reconnect the power cord to the console. Then plug the power cord back into the wall outlet and the power supply unit
  2. Make sure that all three connections are firmly secured.
  3. Turn your console back on.
Check the light on the power supply. If this solution worked, your power supply light will be green
Dec 29, 2010 | Microsoft Xbox 360 Console
My xbox has a three light red ring
    Reconnect the power cord to the console. Then plug the power cord back into the wall outlet and the power supply unit.
    Check the light on the power supply. If this solution worked, your power supply light will be green and the power button will look like this:
My older xbox 360 has 3 segments of the red ring appearing. Can this be fixed? My son thought this could be fixed by microsoft at no cost to me. Is this true? If so, how can I accomplish this?
  2. Reconnect the power cord to the console. Then plug the power cord back into the wall outlet and the power supply unit.
  3. Make sure that all three connections are firmly secured.
  4. Turn your console back on.
Check the light on the power supply. If this solution worked, your power supply light will be green and the power button will look like this: xboxconsolevertical.jpg
Dec 28, 2010 | Microsoft Xbox 360 Console
No water coming in to the 333900033377461971401651
Was it coming in before? Do you have a blocked pipe or filter? Try taking off the water inlet hose by unscrewing nut at entry point on back of machine and check filter is clean. If you live in a hard water area this often gets blocked up with cal.
Dec 09, 2010 | Whirlpool AWM8000 Front Load Washer
Main remote control is not working can you bypass the remote temporarily
No. However you may be able reset the thermostat to its factory setting.
Turn the thermostat off.
Shut of the gas and water supply to the unit.
Unplug or disconnect the unit from its electrical power source. Disconnect the thermostat from the heater.
Wait approximately 5 to minutes, and then reattach the thermostat wires to the heater.
Turn the water supply on and open the tub faucet to its hottest setting for about a minute.
Turn the faucet off and make sure no water water is flowing anywhere in the house.
Turn the gas supply back on.
Reconnect the thermostat wires to the heater.
Connect or turn the power supply back on.
Wait at least 2 minutes before turning the thermostat power button back on.
After the thermostat power button has be pressed, wait an additional 2 minutes before running water.
Test the heater at this time. Turn the water on at the farthest faucet to its hottest setting. measure the temperature with a cooking thermometer.
If you need to make adjustments to the water temperature, either up down, shut all the faucets off first.
The thermostat should read 100 degrees Fahrenheit when it first starts.
If you are receiving an error massage, consult with the manufacturer.
If the thermostat is reading the correct water temperature but the unit is not operating, there are other issue need to deal with. Let us know if this works or you need further assistance.
Sep 26, 2010 | Rheem Tankless Water Heater Main Remote...
Whirlpool Microwave error F3H
F3H Humidity sensor failure 1. Unplug microwave oven or disconnect power.
2. Connect a new sensor to the board (at P5).
3. Plug in microwave oven or reconnect power.
4. If no failure code appears when starting sensor function:
 Replace old sensor.
5. If failure code appears when starting sensor function:
 Replace power supply board.
6. Plug in microwave oven or reconnect power.
Aug 04, 2010 | Whirlpool GH5184XPQ Microwave Oven
Model 110.81860110 will not run hot water
The hot water valve is not working or clogged. Disconnect the washer from the power supply to avoid electric shock. Turn off the water supply and remove the hot water fill hose from the hot water valve. Check the valve for lime scale clogging and clean it. Check the flow of hot water in the hot water fill hose by placing it in a bucket and opening the hot water supply valve. Reinstall the fill hose and turn on the water supply. Proceed below if the problem is not resolved.
Disconnect the washer from the power supply. Remove the screws from the front corners of the console then lift and flip the console to the back of the washer. Disconnect the lid switch wiring harness from the body of the machine by prying the connector lock and pulling it off.
The cabinet is held on to the back panel by two retaining clips. Insert the blade of a flat-bladed screwdriver into the lip of the clip then pry back to release it. Repeat this to the other clip.
Lift the lid and grab the front rim of the cabinet. Rock the cabinet towards you and lift it all the way. You now have access to the water inlet valve. Disconnect the wiring harness from the hot water valve terminals. Measure the resistance of the solenoid coil using an analog multimeter (set it to X1). Replace the entire valve assembly (part number 285805) if the multimeter reads it open.
Remove the fill hoses and the inlet hose from the valve assembly then remove the mounting screw. Install the new valve assembly and connect the fill hoses and inlet hose. Connect the wires to the proper valve solenoid terminals. The red connector goes to the hot water valve.
To reinstall the cabinet, line up the front bottom rail of the cabinet up and under the rail on the base of the washer. Place the cabinet back into position and put the retaining clips in the slots provided on the back panel then push it down into the slots on the cabinet. Reconnect the lid switch wiring harness and put the console back into place.
Feb 11, 2010 | Washing Machines
Whirlpool AWM8000 Front Load Washer Logo
120 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
